TRD S/C - 10psi of boost
Discussion in 'Tacoma Videos' started by XrunnIT, Jun 1, 2009.
  1. Jun 1, 2009 at 2:26 PM
    XrunnIT
    XrunnIT [OP] Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
  2. Jun 1, 2009 at 2:49 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    HaHa. Glad to see you got it going man. Is your AFR thingy hooked up as well, it jumps to 15.1 for a sec.
    I bet it is so ballin. Does it feel much more awesome-er?
  3. Jun 1, 2009 at 3:35 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Even with the outside temps in the 80's-90's, I'm still able to spin 2nd gear from a roll. Its instant boost.
    When I took you for a spin, i was about 5-6psi, I hit 5-6psi at 50-60% throttle now. So go from half throttle to WOT.... I can't wait for cooler weather!
  4. Jun 1, 2009 at 3:48 PM
    Untamed_SS
    Adam
    Haughton, Louisiana
    LoL. I could only imagine how it would be if all you showed me was half throttle. When is your next trip to the track? Probably after temps go down huh?
  5. Jun 1, 2009 at 3:53 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Ya, i need to upgrade my fuel pump, as my fuel pressure is dropping at the high rpms.
  6. Jun 1, 2009 at 5:16 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Might want to tune a little richer when under boost, just to stay on the safe side until it gets cooler. Dont want any detonation!
  7. Jun 1, 2009 at 6:08 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    LOL, the AFR gauge isn't hooked up. I'm not really running that lean.
    My AFR is 10.9-11.2 depending on the engine load. Well protected with the X-1.
  8. Jun 1, 2009 at 6:36 PM
    dually
    dually Low and slow
    haha good thing! id be scare being lean under boost!
  9. Jul 30, 2009 at 2:06 PM
    Blue07Taco
    Blue07Taco Well-Known Member
    Nick
    Iowa
    Its blue
    TRD intake/ exhaust
    15.1..isnt that a bit lean?? It will get worse with cooler air
