TRD S/C Came in Today! Question...
Discussion in 'Performance and Tuning' started by 2wheelnut, Mar 7, 2014.
  1. Mar 12, 2014 at 3:12 AM
    2wheelnut
    2wheelnut [OP] Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Thanks for all the help guys, redid all the vacuum lines and such, covered the boost port and had Toyota clear the code. Shes running like a top and no codes at all. Appreciate the help!
  2. Mar 14, 2014 at 7:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Booooooooooooooost
