trd sc, and no cats = new sort block???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011supercoma, Jul 9, 2013.
  1. Jul 9, 2013 at 8:36 PM
    2011supercoma
    2011supercoma [OP] Well-Known Member
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts with rigid industry D2 spot lights,
    anyone running a trd sc, cai, dtlt headers, and and exhaust with no cats??
    if so have you had any problems, with blown head gaskets, or the truck running too rich and washing out the piston rings, or even fouled plugs?
    the trd sc has the stock pully, the ecu is the reflash from yota, and I have an aeromotive 340lph fuel pump, I also have the o2 sim from gadget for my front cats.
  2. Jul 9, 2013 at 8:57 PM
    2011supercoma
    nola
  3. Jul 9, 2013 at 9:00 PM
    mr2mki
    mr2mki Well-Known Member
    That wouldn't surprise me. It's been a while since I reviewed the theory, but if I recall, lower exhaust pressure caused by doing something like removing the cat increases exhaust velocity and can fool the o2 sensor into thinking you are running lean.
  4. Jul 9, 2013 at 9:01 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    TRD sc.....
    Thorley long tubes
    Urd y pipe
    02 Sims
    Afe stage 2 si
    MK2 urd 3" exhaust.
    No cats..... No issues
    OEM fuel pressure regulator mod
    Haven't upgraded the fuel pump yet
    Stock pulley
    Driven extremely hard most of the time
  5. Jul 9, 2013 at 9:04 PM
    mr2mki
    Wait, what does the ECU expect as far as fuel rail pressure and lph? If the ECU flash is based on a pump with lower pressure or lower flow, that could explain it...
  6. Jul 9, 2013 at 9:05 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    here for bewbs...
  7. Jul 9, 2013 at 9:07 PM
    2011supercoma
    nola
    as far as I know, its expecting the factory pump.
  8. Jul 9, 2013 at 9:07 PM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Yup Yup and as long you've got the O2 sensor simulator your good to go! I have not ran into any issues what so ever being cat-less!
    If you wanna find out the parts I've got check out my first post on my build for the exhaust & parts!
  9. Jul 9, 2013 at 9:10 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I got 1 pending code about "cats not working at optimum capacity" or some crap like that
    .... Well no shit they aren't working at their peak lol.
    Turned off pending codes on ultragauge.
  10. Oct 9, 2013 at 12:51 AM
    Flight Risk
    Flight Risk Member
    Tony
    WV
    2011 TRD Off-Road
    3" ToyTec Suspension Lift, Alpine INE-S920HD, Devil Horns by Andres, 255/85R16 BF Goodrich KM2's
    I'm a little confused here. You don't have front and rear cats, but you do have front and rear o2 sensors. You don't have the simulator hooked up to your front (primary) o2 sensor wiring do you?
  11. Oct 9, 2013 at 4:44 AM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    I have everything you mentioned except for the headers and I haven't had any problems.
    As far as the fuel rail pressure, that is controlled by the factory FPR and it doesn't have anything to do with lph from fuel pump.
    But I would check the spark plugs and made sure they are properly gapped and not causing some sort of detonation in the cylinder(s). Has the gasket always blown around 1 or 2 cylinders?
