TRD SC rebuild, questions
Discussion in 'Performance and Tuning' started by CadCamMan, Jul 24, 2016.
  1. Jul 24, 2016 at 12:52 PM
    CadCamMan
    CadCamMan [OP] Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    Have a couple questions for anyone who's done their own full rebuild on their blower (replace all bearings) or have seen it disassembled.
    Are there holes drilled in the case behind the needle bearings that are usable for removing the bearings with hydraulic pressure? or is removal a hack & pull job? I thought I read somewhere there may be holes there. Holes would be nice, however I have a shop in my garage so I can design and turn/mill/mig weld whatever tooling is needed to remove and install.
    Looking at this full rebuild kit from Jonbond:
    http://jonbondperformance.com/index.php?main_page=product_info&cPath=10_47_120&products_id=68
    it says the bearing retainer for the rotor pack needs to be welded. Is this how the bearings are retained on the TRD SC? The kit fits multiple blowers so I'm hoping welding is not required on the TRD version.
    If anyone has pics that would be great. Thanks.
  2. Jul 24, 2016 at 8:57 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The trd blower is a m90 so i bet there are a few videos/pics out there. The internals should be relatively the same as the trd version. zzperformance.com is a great site for our supercharger. I would talk with stiegemeier.com as they have taken apart quite a few trd superchargers for rebuild and port services. Good Luck :thumbsup:
  3. Oct 7, 2018 at 3:01 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    If anyone looks at this.Thehighspeedlab. Are great people helped me out with my issues...
    1997tacomav6 likes this.
  4. Oct 15, 2018 at 8:11 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I just did this rebuild a few months ago. No, there are no holes to place a greese fitting like there are on the typical m90 housings. And no you ahould not be welding anyhthing in this rebuild unless its damaged and needs it.
    You can rent from nappa a blind needle bearing puller to get those inner bearngs out. Just make sure you line the inside of the housing with somethng soft so you dont damage it then the bearing comes out fast.
    Also, just realised how old this thread is. Sorry for the late reply......
  5. Oct 16, 2018 at 1:03 AM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    No welding At All! A blind bearing puller gets the rear bearing out.They say to Lightly heat the house to pull them out .I did with supercharger still on the truck.Put new bearings in the freezer overnight.Get a tight fitting socket with a long extension.Pound in till you hear a difference in sound and are flush with rear housing.Call TheHighSpeedLab People.....!!!!
  6. Oct 16, 2018 at 6:07 AM
    CadCamMan
    TRD SC, suspension
    Forgot all about this post. Thanks for the replies guys.
  7. Nov 8, 2018 at 3:46 AM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    Good info here..
  8. Nov 16, 2018 at 7:38 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
