TRD Skid Plate on 5 Lug?
Discussion in '5 Lug' started by FlightMedic178, Jun 22, 2014.
  1. Jun 22, 2014 at 12:29 PM
    FlightMedic178
    FlightMedic178 [OP] Well-Known Member
    Nate
    Phoenix
    2020 SR Utility, 2013 Land Cruiser
    Bone stock
    Does anyone know if the holes line up for the (2nd gen) TRD skid plate on the (2nd gen) 5 lug under side?
    Thanks!
  2. Jun 22, 2014 at 6:56 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    From what I've read they do not.
  3. Jun 24, 2014 at 6:22 PM
    Half Caf
    Half Caf Well-Known Member
    Philadelphia, PA
    2009: 5 Lugs, 5 speeds
    x2 for them not being a bolt on. Somewhere on here was a guy who got one and drilled out new holes to some success. Couldn't tell you who though...
  4. Jul 15, 2014 at 5:22 PM
    iflyboeing
    iflyboeing Member
    2014 Access Cab SR-5
    I wanted one too. Primarily to protect lower engine bay from road spray and debris. Carefully evaluated both TRD and standard plate found on all 6 lug models, and determined that they would not fit. I finally elected to fabricate my own. Since I don't own a metal break I decided to use 1/4" polyethylene (think cutting board material). This is easily obtained from any plastics supply house on line.
    There are two breaks(bends) required. One of the great things about PE is that it's thermoformable. I used a heat gun along the line of the break and then bent it as needed. You gotta get it really hot.
    I then attached it using existing holes in the frame rails beneath the front part of the engine bay. Used all stainless 1/4" hardware with fender washers and nylock nuts.
    TacomaFitz and T4RFTMFW like this.
  5. Jul 15, 2014 at 5:25 PM
    iflyboeing
    iflyboeing Member
    Another pic
    Newfiebruh, TacomaFitz and T4RFTMFW like this.
  6. Jul 30, 2014 at 3:43 PM
    endlesstacoma
    endlesstacoma Member
    Yia
    Fort Mill, sc
    dog loves trucks
    Got a guy that own a machine shop thinking about making me one but I can't seem to find the design specs can any one or I'm I gonna have to wing it????
  7. Jul 31, 2014 at 9:57 AM
    iflyboeing
    iflyboeing Member
    There are no published specs for this. I used a mechanical protractor to measure the angles. There are two angle "breaks". They're the same (I believe 17 degrees), but you'll need to measure it to make sure. Then I measured ,the distance from the back of the frame rail I was attaching to, to the first "break". The I measured the distance to the second break. Then there are just a couple inches forward of the front break. Width is designers preference. Just ensure that it doesn't interfere with steering. If your guy uses steel or Aluminum, I would either powder-coat (steel) or anodize (Aluminum). Keep us posted.
  8. Aug 3, 2014 at 10:52 PM
    rademan11
    rademan11 Well-Known Member
    DFW TEXAS
    4X4 trd off road
    Ranch Topper, Bull Bar.....Yes, I know everyone thinks they are crap, I like the look
    Slick idea, very creative!
  9. Oct 5, 2014 at 2:19 AM
    808tacomas
    808tacomas Well-Known Member
    kingrob
    oahu
    2011 toyota tacoma 4door 4 cyl.
    working on it..need some advice
    Nice truck. What's your mods??
  10. Aug 13, 2015 at 2:31 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    What size sheet did you get?
    TacomaFitz likes this.
  11. Dec 24, 2018 at 9:05 AM
    TacomaFitz
    TacomaFitz 2nd Gen 5 Lug
    Rion
    North Bay CA
    2013 2.7 Manual Tacoma base model
    Shackle flip Add a leaf Spacer lift 3/4" bora wheel spacers 265 75 16 Mickey Thompson A/T LCE Header LCE Clutch Power Inverter Yellow Top Battery Air compressor install Hood struts Plasti dip Skid plate Bull Bar Waterport
    Yeah I was wondering the same thing...2'x4' would be my guess before actually measuring
  12. Dec 24, 2018 at 11:39 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
