TRD sport 2012 with minimal lift is dangerous on dirt road...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stranger, Jun 8, 2015.
  1. Jun 8, 2015 at 9:53 AM
    stranger
    stranger [OP] Active Member
    Hi, here's my first post. I have a 2012 TRD sport double cab with 6 feets bed that has a minimal lift spacers lift 1.5 front and 1 rear. I just came back from a trip to our cabin and the places where the dirt road was a bit loose, when it became bumpy the rear end of the truck wants to slip on the right side, the feeling is not fun at all and can't get over 80kmh because i can realy lose it.... The tire are oversized a bit on 16 inches rim, General Tire Grabber A/T2 265/75r16. I had over 300 pounds in the bed at that time....
    A shop that i've contacted told me about axle wrap, but the symptoms i found here on the forum are not close to what i experienced....
    Thank you for your advice !
  2. Jun 8, 2015 at 9:55 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    What was your tire PSI? Sounds like the age-old "too fast for conditions" situation.
    Justn868 and CamoNBlaze like this.
  3. Jun 8, 2015 at 10:03 AM
    stranger
    I will check this out after work. But what's strange, my previous truck as the same but not TRD, just the entry level (double cab, 6 feets bed, non trd) with 2.5 front and 2 rear, and i was going 100kmh on the same road whitout that feeling, evreything was stable and stuck to the road...
  4. Jun 8, 2015 at 10:06 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Hard to say it's safe to travel that fast on any dirt road. But good luck.
  5. Jun 8, 2015 at 10:11 AM
    stranger
    It's a large dirt road for oversized log truck, not that bad. At 80kmh, i was getting passed by other trucks ;) My point is there'S sometthing different/wrong that i didn't have with my previous 2012 double cab non-trd :(
  6. Jun 8, 2015 at 10:13 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    How old are your shocks?
  7. Jun 8, 2015 at 10:13 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    Hmm... that is odd. Any VSC lights/warnings on the dash?
  8. Jun 8, 2015 at 10:32 AM
    stranger
    No light in the dash, everything seems normal.
    The truck was sold on april 2012, original shocks, 68k km on the vehicule
  9. Jun 8, 2015 at 10:34 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Tire pressure to high would be my first guess. Second is the spacers and blocks are causing a harsher ride and increasing axle rap under a 300 pound load.
  10. Jun 8, 2015 at 10:39 AM
    stranger
    Thank you Mademan, i will lower the pressure tonight and give it a try on a local dirt road
  11. Jun 8, 2015 at 10:40 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Like stated, spacers, and old ass shocks are your cause for issues. And lower your psi and you will be amazed!
  12. Jun 8, 2015 at 10:43 AM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Washboard road + high tire pressure +poor shocks = wheel hop which = side slip which = 'oops' Solution softer, tire better shocks, lower speed or run 4 wheel drive even if you don't need it for traction.
    12TRDTacoma likes this.
  13. Jun 8, 2015 at 10:43 AM
    Hennessy
    Hennessy Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    the 2012 Sport had the e-LSD rear end on it and does tend to get a little interesting on gravel. I think I would have preferred a standard old LSD rear end.
  14. Jun 8, 2015 at 10:45 AM
    stranger
    Always on 4x4 on that road, with my previous tacoma i found that i was sticking on the road pretty well..
    currently it's scary....
  15. Jun 8, 2015 at 10:53 AM
    stranger
    yes, i got 2.5 inches front puck and 2 inches rear block on my previous tacoma, it was very stable. Yes my current tacoma was properly aligned, and verified again last week, everything was in the green but the front wheel has a bit of positive camber (but still in the green).
  16. Jun 8, 2015 at 10:54 AM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    http://www.aam.com/Technology/Front-Rear-Wheel-Drive-eLSD-119.html
    I came from the old "posi" to this new one and it seems like some times when it engages the back end does brake loose.. but only under high speed dirt road runs it might be what is causing the issue.
  17. Jun 8, 2015 at 11:04 AM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Lower tire pressure and slow down no reason for doing 60 mph with a stock truck in the dirt get a real lift with decent off road shocks that can handle the dirt lower your psi and you'll be fine
  18. Jun 8, 2015 at 11:13 AM
    stranger
    Yeah i might need to slow down a bit, but my previous truck was handling it perfectly ;)
    Thank you for all your answers, i'm surprised how quick you were to answer.
  19. Jun 8, 2015 at 11:51 AM
    OrangeTexan
    OrangeTexan Well-Known Member
    San Antonio
    2012 4X4 TRD OR
    Things that are different that would contribute: shocks are different. Wheel size and tire are different (16" vs 17").
    What about the load in the truck (including passengers)? About the same as last time?
  20. Jun 8, 2015 at 12:08 PM
    stranger
    OrangeTexan, load about the same. Info to add, when i had my ATV in my trailer 3 weeks ago, i didn't notice that slippery. I had like 300 pounds in the bed + a trailer with 600 pounds in it....
