TRD sport 2012 with minimal lift is dangerous on dirt road...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stranger, Jun 8, 2015.
  1. Jun 8, 2015 at 12:21 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    I have a 12 TRD Sport with auto-LSD and it uses the braking system to direct power to the non spinning wheel. It can only be activated by the switch. I have never heard of Toyota using the style of diff you're referencing here
  2. Jun 8, 2015 at 12:22 PM
    stranger
    stranger [OP] Active Member
    General Grabber At2: 3,415 lbs. Stock OEM dunlop was 2,271 lbs. i think.
  3. Jun 8, 2015 at 12:23 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Try running about 35 psi in those tires
  4. Jun 8, 2015 at 12:38 PM
    stranger
    Ok, so the tire doesn,t have enough load to stick on the ground and the suspension is compensating ? which is causing wheel hops ?
  5. Jun 8, 2015 at 12:39 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Ding ding ding!
  6. Jun 8, 2015 at 12:40 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Or it has too much air pressure. It's safe to run them at a lower PSI
  7. Jun 8, 2015 at 12:41 PM
    stranger
    Great, i will test it tonight for sure, going back to cabin on friday and i don't want to feel that anymore, specialy when i drive beside the mistassinni river...
  8. Jun 8, 2015 at 12:42 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    On street I'm at a good 32 psi off road I'm at maybe 15 with 200 pounds of tools in the back at all times
  9. Jun 8, 2015 at 12:45 PM
    stranger
    what's your tire load rating ?
  10. Jun 8, 2015 at 12:45 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    If your going that fast I'd say lower it down to 20-25 psi
  11. Jun 8, 2015 at 12:46 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    I have Goodyear duratracs I believe they are load e if I remember correctly
  12. Jun 8, 2015 at 12:51 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    I shall have to check because from what I've read my side walls on the duratracs are quite weak
  13. Jun 8, 2015 at 1:06 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    I've read in numerous places that most oem generic shocks lose over 50 percent of their dampening ability between 0 and 10k miles and by 40k miles they're at the end of their life, no matter what a dealer says. I'm sure a lot of new truck/car owners can attest to this from real experiences. I can. People just get used to riding on shitty suspension components. Replace your shocks.
  14. Jun 8, 2015 at 1:35 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I think this is it right here... a combination of a few things. If the road has washboard then the best you can do is slow down. I have a family member who lives out of town on a road filled with washboard and while lower PSI is going to help, low speed is what is really needed to keep everything under control. I would think a little weight in the back may help some though.
  15. Jun 8, 2015 at 3:03 PM
    #35
    stranger
    currently reads 37/38 psi....
  16. Jun 8, 2015 at 3:05 PM
    #36
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Id try like 26-28 if you do a lot of dirt roads or 30 - 32 if you do alot of highway driving. I run mine at 32 unless I know im doing alot of highway driving then I bump it up to 36. offroad I lower it down to 15-20
  17. Jun 8, 2015 at 3:06 PM
    #37
    Mademan925
    Nick
    Discovery Bay, CA
    and those are cold tire pressures
  18. Jun 8, 2015 at 3:21 PM
    #38
    stranger
    Doing over 900km each weekend this time, and 220 is a dirt/log road. I'll have to inflate/deflate when i leave/enter that road. But i will definitaly reduce my every day pressure to 32. The problem is with any washboard or bumpy zone
  19. Jun 9, 2015 at 1:17 PM
    #39
    stranger
    the actual pressure was 33 psi, took it down to 27 and tried it on a local dirt road, wasn't able to reach 80kmh but the slippery feeling on washboard seems to be gone, replaced by a feeling of sticking to the road ;) Ultimate test on friday.
  20. Jun 9, 2015 at 1:37 PM
    #40
    Mademan925
    Nick
    Discovery Bay, CA
