TRD Sport into TRD Off Road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Someone, Jul 24, 2015.
  1. Jul 24, 2015 at 12:34 PM
    Someone
    Someone [OP] Well-Known Member
    2015 TRD Sport DCLB
    Hey Everyone,
    So I got a 2015 TRD Sport DCLB and was wondering if there is a way to convert the Sport into a Off Road. Basically what I want is a RR Diff Lock. Toyota does not offer that option on a Sport Long Bed. Has anyone looked into this?
    I've read threads where some people wanted to install a back up camera and all they did was buy a camera. All the wiring was there. Just plug and go. I am guessing Toyota has all Tacomas pre-wired and only adds the options that you can afford.
  2. Jul 24, 2015 at 9:10 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Mechanically the main differences are the entire diff (sport is a larger diff) and a bit of computer stuff. Add a locker to the sport and it will do about as well as a stock TRD OR in most situations. Easier to make an OR be an OR that looks like a Sport than it would be to make a complete OR from a Sport.
  3. Jul 25, 2015 at 7:34 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Atrac yo!
    KN likes this.
  4. Jul 25, 2015 at 8:12 AM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Add ARB rear locker and you're just about there. Add front and rear lockers and you're more capable than the OR but still drop dead sexy with the skewp and matched parts
    ODNAREM and Lord Helmet like this.
  5. Jul 25, 2015 at 7:13 PM
    Someone
    2015 TRD Sport DCLB
    Is there a kit for it?
  6. Jul 25, 2015 at 10:56 PM
    Iasco
    Iasco Well-Known Member
    3 People literally just told you what to do..
    ADD A REAR LOCKER, That is "The Kit."
  7. Jul 26, 2015 at 4:00 PM
    Someone
    2015 TRD Sport DCLB
    Sorry, thanks for clarifying. How do you activate it? Or is it anyways active once installed?
  8. Jul 26, 2015 at 4:04 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Usually with air. You'd have an onboard compressor that you would turn on then activate the diff lock when you need it.
    You could also swap in a TRD OR rear axle, switch, and associated wiring but I'm not sure if this has been done. It would probably be more complicated and cost more than just adding a tougher ARB locker to your axle.
  9. Jul 26, 2015 at 4:09 PM
    js312
    Joe
    New England
    You could also do something like an Eaton TruTrac. It would be cheaper, requires no driver input, and though not quite as good as a selectable locker, it will still be better than what you have (brake simulated LSD) or the typical mechanical LSD.
  10. Jul 26, 2015 at 4:13 PM
    js312
    Joe
    New England
    True. Most probably aren't getting a DCLB into situations where the locker is a necessity. I know I'm not. Enabling Auto LSD works well enough for me.
    But then, I have a 4x4 so I have that option available to me as well. Not sure if the OP's is or not.
  11. Jul 26, 2015 at 4:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i could twist up a DCLB real easy where even in 4x4 it wouldnt look pretty getting through...... 2wd and a locker would walk right through it.
    That stated.... OP do you feel as though you need a locker. Outside of the rear locker, like stated you get ATRAC on the 09+ TRD OR's which when used right is damn impressive.
  12. Feb 3, 2016 at 8:12 PM
    heymanniceshot
    heymanniceshot Well-Known Member
    San Diego, CA
    '14 DCLB Pyrite TRD Sport 4x4
    Fox 2.5 coilovers with adjustable remote resi., Fox 2.0 rear shocks with adjustable remote resi. Total Chaos UCAs, FN Five Star wheels 17x8.5 with -6 offset, BFG AT KO2 LT275/70R17, Icon 1.5-2 inch AAL, diff drop kit by Toytec, Columbia Overland dual battery setup, IBS battery regulating system with Blue Sea systems fuse block, Weathertech Mats, Skanda seat covers, SnugTop Rebel truck cap w/ Yakima gear racks
    What does that even mean?
  13. Feb 4, 2016 at 7:13 AM
    nd4spdbh
    SoCal
    nice thread dig.
    What i mean there was you could get a 4x4 truck with open diffs like all the stock DCLB's have "twisted up" or flexed out to where you had a tire in the air and another one very lightly on the ground and it wouldnt want to go forward.
    Same truck with just a rear locker and in 2wd could get through the same obstacle without much issue.
