TRD sport or TRD or ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by short bus bully, Jul 1, 2010.
  1. Jul 1, 2010 at 12:10 PM
    short bus bully
    short bus bully [OP] Active Member
    matthew
    Clearlake TX
    about to build a 4x4 prerunner should i get a sport or a off road and what woild be the advantage of them thanks
    im going to get my 2010 in about 2 weeks
  2. Jul 1, 2010 at 12:12 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    4x4 prerunner is a contradiction. prerunner's are 2wd...
    if you offroad then obviously a OR model.
  3. Jul 1, 2010 at 12:18 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    the TRD Sport has a Supecharger and the TRD Off Road has a Rear diff E-Locker. those are the 2 main differences
  4. Jul 1, 2010 at 12:22 PM
    MarineTacoDriver
    MarineTacoDriver Well-Known Member
    Brian
    Cherry Point
    09 SR5 4x4
    ARB front bumper, Warn M8000, ATO front/transmission/transfer case skids, Icon ext travel coilovers, Total Chaos UCA's, OME Dakar leaf springs, Bilstein/RCD 5100 3-4" lift shock, extended stainless brake lines, DrewFab shackle flip, rear ARB Airlocker, ARB air compressor
    :confused: Not true on the supercharger
  5. Jul 1, 2010 at 12:27 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    no such thing as 4x4 prerunner
  6. Jul 1, 2010 at 12:28 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    trd sport does not have a supercharger.
  7. Jul 1, 2010 at 12:30 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    Go with the TRD off road package.
  8. Jul 1, 2010 at 12:30 PM
    JustTaco
    JustTaco i work for the Empire
    justin
    Rapid City South Dakota
    in work
    says who
  9. Jul 1, 2010 at 12:31 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Supercharger....really?? Hood scoop ≠ supercharger...unless of course dealer installed this and marked your truck up by another $6k. Best thing for you to do is go straight to the Toyota.com and compare the two packages line by line.
    Each of their advantages/disadvantage has a lot to do with how you'll be using it. If you do off road, certainly go with the OR because of the locker. If you're more concerned with aesthetics and will be mostly on the street, go with Sport. If you'll be hauling around a bunch of stuff you may also want the long bed...OR doesn't offer you a long bed, but Sport does.
  10. Jul 1, 2010 at 12:32 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    toyota:rolleyes:
  11. Jul 1, 2010 at 12:33 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    :laugh: I hope your kidding about the S/C
    I'd go with the TRD Off Road...the full locker is awesome!
  12. Jul 1, 2010 at 12:34 PM
    ColtsTRD
    Scott
    AZ
    oh and x2
  13. Jul 1, 2010 at 12:38 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    call me crazy but for some odd dumb reason ive been under the impression they did...probably read on here somewhere about a s/c on a sport and being retarded thought they all did...:crazy:
  14. Jul 1, 2010 at 12:39 PM
    JustTaco
    justin
    in work
    are yall talking about toyota prerunners or desert prerunners
  15. Jul 1, 2010 at 12:42 PM
    98tacoma27
    Ben
    Not Beech Creek
    Toyota pre-runners.
  16. Jul 1, 2010 at 12:43 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yota prerunners man...
    per toyota: Prerunner = 2wd 4x4=4x4
  17. Jul 1, 2010 at 12:47 PM
    short bus bully
    matthew
    Clearlake TX
  18. Jul 1, 2010 at 12:48 PM
    JustTaco
    justin
    in work
    my bad though yall meant desert prerunners carry on
  19. Jul 1, 2010 at 12:50 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    man, i know some folks that got screwed then, :D.
    I wish the sports did come with a factory S/C, I know I would have one of them instead of a Offroad!!!! Hey Toyota wake-up! Start offering it, but dont raise the price, these things are expensive enough.:D
  20. Jul 1, 2010 at 12:51 PM
    98tacoma27
    Ben
    Not Beech Creek
    I see you're fairly new here so just for future reference 99% of the time whenever "pre-runner" is mentioned on this board, it will be in reference to Toyota specifically.
    And thank you for your service
