TRD Sport rear shocks .
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mamaluke, Aug 4, 2022.
  1. Aug 4, 2022 at 3:28 AM
    Mamaluke
    Mamaluke [OP] Member
    Dino
    Anyone change just the rear shocks for a softer ride ?
  2. Aug 4, 2022 at 3:52 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Probably not the shocks unless they are blown. Is the truck stock? Running a spacer lift? Blocks in the rear? How much load are you carrying? What tire pressure are you running? What tires are you running?
    Chew likes this.
  3. Aug 4, 2022 at 4:14 AM
    Mamaluke
    Dino
    2022 stock truck . I know I should have got the Off Road for a better ride but I like the painted trim and the hood and I don't go off road much if any .
  4. Aug 4, 2022 at 4:22 AM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    I have heard of this. Give it a try. You can find cheap new takeoffs from an OR and see if you like it.
    MannyS likes this.
  5. Aug 4, 2022 at 5:15 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Like he said, TRD OR OEM shocks ride softer.
  6. Aug 4, 2022 at 5:40 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I would not recommend it, unless you plan on never towing or putting anything heavy in the bed.
    Softening just the rears is going to make the truck feel unbalanced. I would also worry about slamming the bump stops (to be fair, it didnt take much for the stock sports to land on the bumpstops either).
    It's a truck, no suspension will be perfect. Your best options are:
    • buy a set of off-road takeoffs for dirt cheap (people on TW sell them all the time, and its easy to find a set with less than 5000 miles on them) and do all four corners - Truck rides much softer, but its not going to have the best cornering maneuverability. That isn't a major issue however, several people on here really enjoy the OR suspension.
    • Pony up a little more and buy a budget aftermarket like Eibach, Bilstein, or Icon - Truck still rides and corners a little on the firm-ish side (depending on brand), but is much smoother overall.
    • Pay big bucks for a high end aftermarket suspension - Truck can take anything and feels great, too bad your bank account is now too empty to go enjoy it. :cookiemonster:
    If you really hate the harshness, I'd recommend trying out a set of lightly used OR shocks. A few people on here have swapped all four corners while keeping the front swaybar in, and wound up loving the ride.
    Mamaluke[OP], Vmax540 and cammerv8 like this.
  7. Aug 4, 2022 at 5:51 AM
    moon_taco_420
    moon_taco_420 Well-Known Member
    Josh
    2022 TRD Sport Access Cab, 6SPD MT, Lunar Rock
    Might be just me but I’m loving how the Sport suspension feels compared to my 2003 with BILSTEINs all around.
    cammerv8 likes this.
  8. Aug 4, 2022 at 7:03 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I have to agree, I really don't think the ride is bad at all. It is after all a truck and I'm not expecting to ride like a big ole Detroit road sofa. Given that one of the main reasons I bought a truck was to have the option of towing my Honda Goldwing to places in a UHaul trailer, the last thing I want to do is soften up the suspension, especially the rear.
    I think the suggestion that others have offered the OP makes the most sense. Look for someone with some low mileage OR takeoffs, switch all 4 out, and give it a shot. Hold on to your Sport components. If you don't like the ride you can always change back and you haven't dropped a ton of cash.
  9. Aug 4, 2022 at 7:58 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    defiantly start with tire pressures,,, most any dealer or shop will simply just ,,,,,,fill em up!
    Rock Lobster and TRD_Seeds like this.
  10. Aug 4, 2022 at 8:13 AM
    TRD_Seeds
    TRD_Seeds Well-Known Member
    York, PA
    2019 Cement Tacoma TRD OR
    This. Double check you aren't running super high.
    Chew[QUOTED] likes this.
  11. Aug 4, 2022 at 8:19 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    add to that: even a few psi makes a huge difference, especially over empty truck beds.
    shakerhood likes this.
  12. Aug 4, 2022 at 8:27 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    The sport's ride stiff. Personally I'd swap out both front and rear with some OR take-off's instead of just the rear. Keep everything balanced that way. They can be found with low miles super cheap and are pnp.
  13. Aug 4, 2022 at 8:51 AM
    Mamaluke
    Dino
    Thanks for the help guys . I'll probably go all 4
  14. Aug 4, 2022 at 10:18 AM
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    There was a post on TW some years back where a Sport owner replaced his rear shocks with Bilstein 4162s (if I'm not mistaken). He claimed it did away with the pronounced rear hop you get with the Sport on uneven road surfaces. I live in rural Maine, the land of few truly smooth roads :D, and the hop is my only complaint with the Sport, but not enough to compel me to do anything about it. Yet.
    Mamaluke[OP] likes this.
  15. Aug 4, 2022 at 10:53 AM
    Dean62
    Dean62 Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    i did this on my sport access cab i put on fox 2.0 resi with adjustors so i could dial them up and down stiffness wise for driving on and off road
    i did it before i lifted it knowing that soon i would be lifted tho
