TRD Sport Skid Plate: Does this look normal to you?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GregLee98, Mar 7, 2012.
  1. Mar 7, 2012 at 4:43 PM
    GregLee98
    GregLee98 [OP] Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    I've had some rubbing with my new tires, but only at full lock.
    3 inch lift running Goodyear Wrangler MT/R with Kevlar 275/75/R17s.
    Had minimal rubbing on the UCAs only. AHd them on since NOV11.
    Now I see more rubbing...:mad:
    Anyway, today I get this horrible jerking clunking noise.:eek: Its my tires rubbing on the passenger side part of the TRD Sport skid plate. Looks bent down to me. I pushed it up a bit.
    Pics show Passenger side, then Driver's side for comparison. Hopefully, my deal for the Spidertrax goes through soon. Otherwise, I may take it off until then. Its just the 4 bolts right?
    Any recommendations on a nice aftermarket skid plate? Especially one that doesn't cost and arm and a leg?
  2. Mar 7, 2012 at 5:10 PM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    In the second picture, you can see the dark area on the skid. I rubbed it with my fingers, it looks like a seam from a bend, although not rippled or flaking off.
  3. Mar 7, 2012 at 5:17 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    Can you bend it up?
  4. Mar 7, 2012 at 5:26 PM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    yeah it looks like that part got bent down. Do you get your oil changed someplace? Those corners arent very strong and if someone takes plate off and sets it down wrong it'll bend out. You should be able to bend it back pretty easy with just your hand.
    I cant remember if there are 5 or 6 12mm bolts holding skid plate on. I believe there is one in the middle towards back of truck, 2 on each side just a little more towards front than the middle one, and 2 or 3 in the front of it.
  5. Mar 7, 2012 at 5:42 PM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    Actually, my tires did that. May have gotten bent a little earlier some other way, but not sure. My Wranglers have kevlar in them and the side nubs were grabbing it hard.
  6. Mar 7, 2012 at 5:50 PM
    tbturner47
    Honestly, I'd sell it and pick up a real one. ATO has a group buy going on now.
  7. Mar 7, 2012 at 5:52 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Why would someone take off the skid to change the oil? Theres an access cut out for the drain plug. Unless its a four banger and the filter is on the bottom. I'm not sure on the four bangers or if the op has one. I'm on my phone so I can't see that info
  8. Mar 7, 2012 at 7:29 PM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    I'm a V6, so no. Its weird because on the driver's side, the skid is about 2 inches from the tires at full lock, but on the passenger's side, it was close enough to grab it. May have been from some flex when off road, bent it, and I've made it worse.
  9. Mar 7, 2012 at 7:35 PM
    tuckdaddy
    tuckdaddy Well-Known Member
    Tucker
    Lake McQueeney, Texas
    the same thing happened to me and i just took it off, beat it back with a sledge hammer and bolted it back on. I haven't had a problem since i bought my spidertrax spacers (1.25 inch) im running a 3 inch lift and 285/75/r16 km2's
  10. Mar 7, 2012 at 7:36 PM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    Taking off, just the 5 bolts on the front?
  11. Mar 7, 2012 at 7:37 PM
    IndianTaco
    IndianTaco Well-Known Member
    what he said^^
  12. Mar 7, 2012 at 7:38 PM
    tuckdaddy
    Tucker
    i believe i only had four bolts but i also have the toyota add on aluminum skid
  13. Mar 7, 2012 at 7:38 PM
    jandrews
    '09 FourDubDee TRD OR
    This. It's not like that skid "plate" is doing anything under there. You can fold it in half by hand.
    Getcha some beef!
  14. Mar 7, 2012 at 7:40 PM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Then there is no reason for the skid to have been removed for routine work. But its just a metal plate... Take it off and persuade it to match the drivers side with a BFH.
  15. Mar 7, 2012 at 7:53 PM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    Anyone got an impact wrench? Its not playing nice.
    I'll beat on it tomorrow. I'll look into a new tougher skid.
  16. Mar 7, 2012 at 7:59 PM
    tuckdaddy
    Tucker
    a ratchet did good for me good luck with getting it off and beating it back into place!
  17. Mar 7, 2012 at 8:01 PM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    There is a Relentless Fab group buy coming up for skids soon. On top of the ATO one that was already mentioned.
  18. Mar 8, 2012 at 5:20 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    Couldn't get it off, so I bent it up as far as I could. Well, after 1 mile into work, its bent down again. Can't turn left. I've got to get this thing off.
  19. Mar 8, 2012 at 5:51 AM
    TRDyota09
    TRDyota09 Well-Known Member
    Jabin
    Reedsville,WV
    09 Super White TRD DCSB
    K&N cold air intake, magnaflow dual exhaust, extang trifold, grillcraft black mesh grill, spyder black projector headlights w/LED's and halo's, trd 6 speed shift knob, aftermarket TRD badges, interior piped out in red,265/75-16 Goodyear Duratrac tires,painted wheels w/red pin stripe
    Grinder and a a cutting wheel..... That'll bring that bitch off!
  20. Mar 8, 2012 at 7:03 AM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Maybe try PB Blaster... Sounds like the bolts are rusted in. Then hit it with an impact wrench. That or use a breaker bar and a cheater bar. Problem with the grinder option is that you need to get the bolts out somehow or you wont be able to mount any skid that uses factory holes. Same goes for what I suggested, if the bolt heads shear off all you can do is drill out whats left. But at least the skid would be off.
