TRD Sport- vs- OffRoad packages
Discussion in 'Technical Chat' started by wardbr549, Nov 9, 2014.
  1. Nov 9, 2014 at 4:03 PM
    wardbr549
    wardbr549 [OP] New Member
    David
    05 trd sport
    I have a TRD Sport. was wondering about limited slip and lockers. I was in 4 wheel drive in some mud spinning and there was no mud in the pasanger wheel well? I had not noticed before but did not know if i got a problem with the lockers or if it will only pull with 1 wheel. I don't go off road alot.
    Thanks David
  2. Nov 26, 2014 at 3:15 PM
    nathan0214
    nathan0214 New Member
    Nathan
    Moline,Illinois
    2017 TRD Off-road Silver Sky
    Stock
    Trd sports do not come with the e-locker. Only trd off roads come with the locker. You have a trd sport so no diff lock only mechanical lsd
  3. Nov 26, 2014 at 3:24 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Yep. The front wheel on your truck without traction will spin and the rear wheel without traction will spin. Sometimes that leaves you stuck. If that happens to me I just have to turn on atrac or my locker( on trd offroad). If that doesnt work I can let more air out of my tires or use my maxtrax or winch. May want to get yourself some maxtrax if your going to start offroading.
  4. Nov 26, 2014 at 3:48 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Hi David,
    The 2005-2008 Sport TRD has a mechanical limited slip rear differential and an open front differential. 2009+ Sports have returned to open rear differential but with traction control using the ABS brakes (it also works the front tires in H4).
    In slippery conditions one front tire and one rear tire gets the bulk of the power and you usually see just two spinning tires. The limited slip means that at a point, clutches inside the rear differential apply break force to the one spinning side to transfer power to the other tire. Having two back tires working together gives you better chance at getting out.
    Better is a locking rear differential... which gear matches both sides of the back end diff guaranteeing you equal power to both tires.
    4WD LOW RANGE is likely the best choice for mudding, as it is for climbing. Until you add a locker to the rear... ARB lockers are very popular after-market add ons. Serious off roaders put a front locker on as well. The rear alone will get you pretty much everywhere in 4WD!
