TRD Sport vs TRD Offroad front springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nach73, Oct 29, 2015.
  1. Oct 30, 2015 at 11:35 PM
    nach73
    nach73 [OP] Well-Known Member
    Nacho
    Pueblo, CO
    06' Pre-Runner TRD- Off Road
    5100's set @0 with 887 springs and 1.5 AAL. Satoshi Raptor grill, Halo Projector led Spyder headlights and syder taillights, Projector led Halo fog lights by Zack/Taco Nation, LED's everywhere else, Raceline 16x8 Assualt wrapped with Goodyear DuraTracs 285/75/16. Wet Okole seat covers, Paracord headrest handles by Cole/Dessert Dunes, Weather tech floor mats, JVC Arsenal KW-V200BT, 2 10" Kicker shallow mount, Alpine components, Alpine 1000 watt amp, interior is completely Dyna matted
    Yeah my 06 has the 2+overload. Was looking for a used set of 3+ but the prices I was getting, I could hold out for a new set of Dakars
  2. Oct 31, 2015 at 1:32 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    My 14 off road double cab is 3+1 spring.
  3. Oct 31, 2015 at 4:44 AM
    mandavdle
    mandavdle Well-Known Member
    Dave
    PA and CT
    2016 TRD OFF ROAD V6 DCSB AT
  4. Oct 31, 2015 at 8:56 AM
    Pigpen
    Dan
    Northwest Montana
    I have 2+1 on my 2012 base. I like my linear coil springs preloaded with 5100s at 1.75 for most of my driving.
  5. Oct 31, 2015 at 2:55 PM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Can you go into more detail on this? I mean I know the difference between progressive and linear but it seems to me like the progressive OR springs would be gentler on the small bumps and imperfections of road conditions and stiffer in deep ruts and flexes of off road.
    nach73[OP] likes this.
  6. Oct 31, 2015 at 3:15 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI, if your truck was made after october 2014 all 6 lug trucks have the 3+1 leaf pack.
    before that its a mixed bag depending on TRD OR vs SPORT vs base with tow package.
    Mtniner likes this.
  7. Oct 31, 2015 at 6:18 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    It's hard to explain the dynamics in real world applications. The best way for me to describe it is through the spring rate. Whenever you lift a vehicle using preload for example, you're essentially compressing the spring rate to achieve lift. Progressive coils, as you know, have a varied spring rate as you travel the coil. If you preload that coil, you are increasing the spring rate dramtically which creates a stiffer ride. A linear coil is the same rate throughout, so you're applying preload that is "uniform". Now if the vehicle is riding stock on either coils, you probably couldn't tell the difference between the two. It's when you modify existing parts in which you'll be able to tell the difference most likely.
  8. Oct 31, 2015 at 6:20 PM
    Mtniner
    Mtniner Well-Known Member
    NW Montana
    I bought mine in Oct 2013, so I guess that explains it. I found some free oem 3+1 springs (very nice tacoma owner who upgraded with same year/model as mine), is it worth it to switch mine out for them?
    Sorry if I'm hijacking the thread
  9. Oct 31, 2015 at 6:24 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    If you got them for free, you might as well. You will get a bit of lift out of it and some more cargo handling capacity as well. There's no real downside honestly.
    My 2013 purchased in Nov of 2012 TRD OR w/tow was configured with the 2+1. When I added my AAL, I had a set of 3+1s waiting for it. I have 3 + AAL as I pulled the overload when I did the AAL.
    Mtniner[QUOTED] likes this.
  10. Oct 31, 2015 at 10:58 PM
    nach73
    Nacho
    Pueblo, CO
    How lucky you are. I have yet to find any out there that aren't thought of as gold. Lol
  11. Sep 5, 2018 at 6:44 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Can someone help me with how to identify them from each other? I am looking for OR front coils and being able to tell the difference would come in handy.
    TIA,
    GB
