TRD Sport Wheels on SR5
Discussion in '4th Gen. Tacomas (2024+)' started by JoeVB, Jul 14, 2024.
  1. Jul 14, 2024 at 7:37 AM
    JoeVB
    JoeVB [OP] Member
    Joe
    2024 SR5
    No e
    I have a 24 SR5.
    mpg lists as 21/26
    It has 245/70 17 tires on it.
    I am about to put wheels and tires from a TRD Sport on it (265/65 18)
    I’m wondering if I should expect TRD Sport type MPG (20/24)
    Or are there other differences between the Sport and SR 5 that account for the MPG difference. Thanks for any help.
    j-
  2. Jul 14, 2024 at 8:52 PM
    jimmydean
    jimmydean Well-Known Member
    Camarillo, CA
    16' DCSB TRD SPORT 6M
    Limited Grill/Wheels, 265/65/18 Nitto RG
    The loss of MPG is due to the larger wheel and Tire. You're adding an inch to your diameter but I doubt your MPG loss will be noticeable.
  3. Jul 15, 2024 at 8:07 AM
    mmessier2
    mmessier2 Well-Known Member
    17 Sport DCMTSB
    Don't forget that putting bigger tires on will make your speedo inaccurate. Make sure you account for this when calculating your new MPG.
  4. Jul 15, 2024 at 8:34 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Those size wheels and tires are tuned to the sport suspension too. The sr5 has different shocks. Just a thought it could change the ride quality as well
  5. Jul 15, 2024 at 2:14 PM
    JoeVB
    JoeVB [OP] Member
    Joe
    2024 SR5
    No e
    It’s interesting, as it is now with the stock wheels and tires, the actual speed is 2 mph slower than indicated on the speedometer. So my thought is that a slightly larger wheel could actually make the speedometer more accurate.
  6. Jul 15, 2024 at 3:04 PM
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    Putting 33's on my 2nd gen made the speedo accurate...
    I think they put Mickey Mouse tires on all trims to improve MPG ratings but they know you're going to change them so they at least put the speedo where it will be right when you get the right tires for the truck.
    JoeVB[OP] likes this.
