TRD sport wheels on TRD off road
Discussion in 'Wheels & Tires' started by Voodoo176, Jan 4, 2024.
  1. Jan 4, 2024 at 8:47 PM
    Voodoo176
    Voodoo176 [OP] Member
    Joe
    2020 Toyota Tacoma TRD Off Road access cab
    None yet
    I’m going to be doing some longer road trips this summer with my truck and I have my stock TRD off road wheels on my truck with some Falken Wildpeak tires that I like for my day to day short commute, dirt roads, and snow. however I’m thinking some TRD sport wheels may save some mileage for some longer road trips. Anybody do anything like that at all and how did it go for you?
  2. Jan 4, 2024 at 9:52 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    The 17 inch rims will require tires (duh) so you could choose a 245/75 in a highway-type tire and get a bit of extra diameter with no rubbing. The taller narrow tires will have less rolling resistance as a bonus.
  3. Jan 5, 2024 at 9:24 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Like BC hunter said, you’ll need to buy wheels and tires so it will take around 3 or 4 years to pay off approx with your fuel savings. I’d save the money for road trips. What mpg you getting now?
    hooliganrick likes this.
  4. Jan 5, 2024 at 9:31 AM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Interesting BC. Wouldn't the taller tire cause issues with MPG though?
  5. Jan 6, 2024 at 10:07 AM
    BC Hunter
    All the taller tire does is decrease your final gear ratio by around 3%. So for every engine revolution you travel a bit further than you would have on the OEM size.
    Or, at a certain true speed, your engine would be going 3% slower. Say, 1940 rpm instead of 2000.
    There are a ton of variables at play…for example you are riding ~1/2” higher, so there is a bit more air resistance, but the narrower tires (which will be at a higher pressure to maintain load-carrying capacity) will have less rolling resistance.
    Our experience with our manual transmission Tacomas is that the larger tires make the final drive ratio in 6th closer to the final ratio that the automatics get, and we get the (slightly) improved fuel economy on long drives that they enjoy.
    As they say:YMMV.
  6. Jan 6, 2024 at 10:14 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    I would just pump up the air pressure to 45 for hwy driving better gas mileage ..for sure ..down side is more likely to have a blow out ....
  7. Jan 6, 2024 at 10:16 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    This could make sense as long as you choose a tire that makes sense. Personally I would go smaller, 245/70R17. Since it’s clearly about performance and not looks, a skinny 30.5” ought to net the best performance and mpg. I have never ever experienced better mpg from a larger tire, though I suppose experiences can vary.
    If I were doing what you were doing, I’d pick Michelin Defenders in 245/70R17.
    BC Hunter likes this.
