trd sticker removal
Discussion in 'Detailing' started by commtrd, May 11, 2009.
  1. May 11, 2009 at 8:18 PM
    commtrd
    commtrd [OP] commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    How can I remove the trd sport stickers on the sides of the truck at the stern? Without harming the paint?
  2. May 11, 2009 at 8:19 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  3. May 11, 2009 at 8:23 PM
    Y0TA
    Y0TA Well-Known Member
    Zac
    Central MT
    05 BLK TRD Sport 4X4
    i just did mine thi weekend. use a hairdryer to heat it up and just pull it off. i used goo gone to get the gunk off there. then washed and waxed and buffed out with windex. hope this helps
  4. May 11, 2009 at 9:01 PM
    commtrd
    Corpus Christi TX
    '09 trd sport. I will try the hair dryer trick. Thanks.
  5. May 12, 2009 at 2:49 PM
    hawkman
    hawkman Well-Known Member
    Prairieville La
    tinted windows,fog light mod,sock monkey decals
    dont get frustrated. the glue left behind sometimes takes a while to come out. i found patting it with the same spot on a rag with goo gone on it works too ,kinda like gettin gum off of somethin.
  6. May 12, 2009 at 8:23 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    On a warm to hot day, face the panel you want to work on to the sun for an hour or two and then peel (of course the hair dryer trick works too). Don't use ANYTHING sharp to help you peel the sticker or you might trash the paint.
    D-Solve it works pretty good too at removing adhesive. Here's mine after removing TRD stickers and all emblems:
