trd sticker
Discussion in 'Technical Chat' started by 2003greenbean, Feb 2, 2007.
  1. Feb 2, 2007 at 5:26 AM
    2003greenbean
    2003greenbean [OP] Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    what is the best way to remove my trd sticker on the side of the bed i have found one i like better and want to buy
  2. Feb 2, 2007 at 6:14 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    The best way I have done it is by using a razor blade at a close angle to the sticker to get the bulk of it off. Then I used some of my wife's nail polish remover to get the excess gunk off. It worked well, and did not destroy the paint. That was on a 1982 VW Caddy (Rabbit Pickup). The paint on your tacoma is much stronger than that... :)
  3. Feb 2, 2007 at 7:38 AM
    spp
    spp OC, Kalifornia
    OC California
    I would avoid taking a blade anywhere near paint! Leave truck out in sun on a warm day or gently and carefully use a hair dryer to warm up sticker. Use FINGERNAILS to lift edges and just slowly peal it off. May be a little stickum residue which WD-40 or goof-off will remove. Clean and wax area afterwards.:)
  4. Feb 2, 2007 at 8:24 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Great advise. BTW, steam should help peel it off too.
  5. Feb 2, 2007 at 8:47 AM
    2003greenbean
    socaste,sc
    03 trd
    thanks for the help i might try it this weekend if i am brave enough
  6. Feb 3, 2007 at 3:17 AM
    jfb504
    jfb504 New Member
    3M makes an adhesive remover that works well. It's sold at stores that sell supplies to body shops and detailers.
  7. Feb 8, 2007 at 10:25 AM
    TRDeity
    TRDeity Well-Known Member
    ATX
    2017 TRDpro
    Just curious about what sticker you found? Did you get it off yet? Any pics of the new sticker?:confused:
  8. Feb 9, 2007 at 4:24 AM
    2003greenbean
    socaste,sc
    03 trd
    i havemt got brave enough to try to get it off yet
  9. Feb 9, 2007 at 6:50 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Yea I used that 3, adhesive remover to take the toyota stickers off the tailgate of my 95 taco when I had it it just eats it away I did however use a scraper like one used to spread bondo to get under it it works great good luck what other kind of trd stickers did you find
  10. Feb 10, 2007 at 8:09 AM
    2003greenbean
    socaste,sc
    03 trd
    i found a trd stcker that was camo
  11. Feb 10, 2007 at 8:18 AM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    thats cool take a pic when you are done
  12. Feb 10, 2007 at 9:07 AM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    so any update on your trd sticker were you brave enough to replace it?
  13. Jul 28, 2007 at 12:26 PM
    sunruner19
    sunruner19 Senior Senile Member
    Bill
    Great Sacandaga Lake region Northville NY, South Y
    09 Tacoma 4WD
    supercharger, ARE series 2 lid.
    best way to remove and also the safest is either your hair dryer or a heat gun. wd-40 will remove the sticky residue without scratching the paint. Take this advice from a detailer who does this often.
  14. Jul 28, 2007 at 12:56 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    agreed..heat gun and fingernails to pull it off. then i used some of the pink lysol or windex multisurface cleaner and a paper towel. the adhesive came right off.
