TRD Supercharge kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drek, Mar 1, 2014.
  1. Nov 9, 2014 at 5:31 PM
    #141
    ThomasMore66
    Dallas/Fort Worth & Durango
    I think I want to use the warrantee up before I go crazy. You adding gauges? I think I like the driver's post mount option better than the Craven Speed option, but it's a close difference.
  2. Nov 9, 2014 at 5:33 PM
    #142
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea we'll see how I like it from just the SC. Yea I'm looking at the steering wheel mounted gauge pods. I like that alot better than the A pillar. I've also heard alot of the aftermarket A pillar stuff just doesn't line up or fit well
  3. Nov 9, 2014 at 5:34 PM
    #143
    ThomasMore66
    Really? Well, maybe I just changed my mind. AFR and boost? Brand?
  4. Nov 9, 2014 at 5:38 PM
    #144
    VolcomTacoma
    Jeff
    NorCal
    I just found it all on URD's website. They seriously have like everything boost related you might need. I'm gonna call up Gadget one of these days with money in my hand and see what how much I have left :)
  5. Nov 9, 2014 at 6:04 PM
    #145
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the A pillar mounts are terrible. they dont fit properly, they dont match the grey color of the interior. I have the Flex pod mount on the steering wheel with AEM AFR and Boost gauges (highly recommend them if you're ok with the price) and love my setup.
  6. Nov 9, 2014 at 6:23 PM
    #146
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Looks great. Does it block some of the warning lights some people have said?
  7. Nov 9, 2014 at 6:25 PM
    #147
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    slightly.. plus i set the steering wheel all the way up, so even without the pods, i sometimes have trouble seeing the lights.
    you learn to just peak over or to the side quickly tho.
  8. Nov 9, 2014 at 6:32 PM
    #148
    VolcomTacoma
    Jeff
    NorCal
    Oooooooo I was hoping to get a good picture like that. I love it! Yea the price is a bit steep, but worth it IMO.
    I keep reading about the AEM digital stuff. Are all those gauges plug and play? Would I just need the two gauges and the flex pod and it all comes with the appropriate connections and tubing or do I need to get creative to hook everything up lol
  9. Nov 9, 2014 at 6:32 PM
    #149
    Lord Helmet
    Nick
    Oh ok. I'm the opposite I set my steering wheel almost all the way down so hopefully it won't be in the way.
  10. Nov 9, 2014 at 6:35 PM
    #150
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    everything you need is supplied. :thumbsup:
    ahh you'll be good then.
  11. Nov 9, 2014 at 6:39 PM
    #151
    VolcomTacoma
    Jeff
    NorCal
    Woohoo!
    OK so I built a shopping cart last night just to see,
    URD stealth 2.85 pulley with pulley tool
    URD 2005+ Tacoma fuel package...I think it was all new pump and filter and some other stuff, looked interesting
    I think I was also looking at the next step up injectors and/or the 7th injector as well.
    Planning on keeping my 1st generation TRD CAI (the afe looking one) and putting that on...but probably putting an AFE pro dry filter in there, I'm so tired of oiled filters...or getting the Airaid CAI.
    Also getting the TRD Cat back exhaust, it's what I have currently and i like the sound :)
  12. Nov 9, 2014 at 6:41 PM
    #152
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you cant run larger injectors/7th without an EMS fyi.
  13. Nov 9, 2014 at 6:49 PM
    #153
    VolcomTacoma
    Jeff
    NorCal
    Ah. Good call! Then I'll stick with the pulley intake and exhaust. Maybe some headers down the road. Oh and the new fuel pump
  14. Nov 9, 2014 at 6:53 PM
    #154
    Lord Helmet
    Nick
    Don't forget the Y-pipe either :p and meth injection :)
  15. Nov 9, 2014 at 6:58 PM
    #155
    The Stig
    The Stig Well-Known Member
    All that money for such little gain. The superchargers hardly seem worth it
  16. Nov 9, 2014 at 6:59 PM
    #156
    VolcomTacoma
    Jeff
    NorCal
    Hey, you can't take it with you might as spend it on something that's fun!
  17. Nov 9, 2014 at 7:02 PM
    #157
    Lord Helmet
    Nick
    Horsepower isn't cheap
  18. Nov 9, 2014 at 7:08 PM
    #158
    VolcomTacoma
    Jeff
    NorCal
    Yup. And let's be honest, If I wanted a race car, I wouldn't have a Tacoma. I want at tacoma, and I'd like it to be as fast as possible without puting a different engine in it. Bam.
  19. Nov 9, 2014 at 7:12 PM
    #159
    ThomasMore66
    I'm just having fun with this truck. It is expensive, but worth it to me. I don't plan on taking down anybody in my hot rod, but fast trucks are just cool.
  20. Nov 9, 2014 at 7:15 PM
    #160
    VolcomTacoma
    Jeff
    NorCal
    Yea, it'll just be fun to watch the full size trucks gun it and just race past them.
