TRD Supercharge kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drek, Mar 1, 2014.
  1. Nov 9, 2014 at 7:37 PM
    #161
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Exactly, as long as you're having fun and not killing anyone, that's all that matter. I bought my Tacoma for fun, work, and haul stuff. Along the way I heard about the TRD SC and how it's smog legal I got hooked. No more worries about showing up for smog and failing on the spot. Not looking for a 500 whp beast like Torspd, Super Werthy, or Jutus ;)
  2. Nov 9, 2014 at 7:42 PM
    #162
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :pout:
  3. Nov 10, 2014 at 12:35 AM
    #163
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Orly?? Man I just can't bring myself to ebay much these days. Just to scared of getting swindled with some shit lol.
  4. Nov 10, 2014 at 7:40 AM
    #164
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I love how some people aren't happy with nearly a 30% increase in horsepower from a supercharger that maintains the factory warranty...
    The Tacoma as a V6 putting out under 250 HP stock. You just aren't going to see the massive gains you can get with forced induction on V8 muscle cars because 30% on a base 400 HP engine is a lot more than 30% on our V6's. BTW I'm just using 30% as a base number, a lot of aftermarket kits do a lot more than just add boost.
    If you have the money and want the Tacoma to feel like it, in my humble opinion, it should of felt like off the lot then supercharge it!
  5. Nov 10, 2014 at 7:41 AM
    #165
    ThomasMore66
    Dallas/Fort Worth & Durango
    Dropped it off this morning for the install!
  6. Nov 10, 2014 at 8:48 AM
    #166
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this last weekend out at Glamis made me REALLY happy with all my stuff..
    granted i have a bit more than others.. but damn.. those sand drags were mine :cool:
    ill link some videos once i edit them all together.
  7. Nov 10, 2014 at 9:03 AM
    #167
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    interesting..
  8. Nov 10, 2014 at 9:09 AM
    #168
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Which bolt on's give you 60HP? I'm not asking sarcastically, I think you may of had expectations that were unrealistic of what the TRD S/C can deliver without the same supporting mods. I mean there's guys who have got close to 60 HP with long tube headers, True CAI, full CAT-less exhaust (technically illegal), a throttle body upgrade, and a custom tune using a plug in EMU but then you're talking about nearly the same sort of money as a S/C, albeit spent over a period of time.
    If you're talking about some of the guys who have rebuilt 1GF-RE engines to have more than 300 HP, that's not really a bolt on to me. Anything that requires the engine out of the truck isn't "bolt on", though I'm sure some look at it that way.
    I think it depends on what you expected from the S/C. The S/C basically gives the Tacoma the same RWHP as a full sized truck with 1000 lbs less weight. It's not going to turn it into a rocket. It does give it a far more useful torque curve IMHO.
    Now put your S/C (or any F/I you fancy) together with the same bolt on mods, then you're getting into race truck territory. Just don't expect the engine to hold up very long stock.
  9. Nov 10, 2014 at 9:12 AM
    #169
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Are you automatic? Maybe do some research into the transmission valve body upgrade. There's a lot of talk that under high stress loads the transmission in our trucks slips way to much with the stock valve body. Just an idea, I haven't had it done but that might be worth looking into to get the results you're looking for.
  10. Nov 10, 2014 at 9:25 AM
    #170
    Lord Helmet
    Nick
    This is the place I was recommended: http://www.importperformancetrans.c...-converters-and-transmission-parts.-63-1.html
  11. Nov 10, 2014 at 9:34 AM
    #171
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :spy: :D
  12. Nov 10, 2014 at 4:25 PM
    #172
    SabMotocross
    SabMotocross Well-Known Member
    Bobby
    Santa Fe, Texas
    2014 Tacoma PreRunner SR5 DCSB V6 TRD S/C
    TRD BAJA Suspension...Rims and tires, blackout badging, TRD oil filler cap, front skid plate, N-Fab step bars, GrillCraft custom upper and lower grills. K&N air filter, TRD Supercharger.
    Larger tires is probably the one item that makes such a difference on your vehicle...ya know...torque multiplication comes into play with your revised gear ratio. Going from the stock 30-inch tires to 33's or larger can make a significant impact on any engine performance modification.
    Just my opinion, but it does make a huge difference.
  13. Nov 10, 2014 at 6:26 PM
    #173
    VolcomTacoma
    Jeff
    NorCal
    My god, your transmission must be soup by now. That is just way to big of a tire with a regear.
  14. Nov 10, 2014 at 6:29 PM
    #174
    VolcomTacoma
    Jeff
    NorCal
    You're the reason Toyota never warranties any thing.
  15. Nov 10, 2014 at 6:51 PM
    #175
    Lord Helmet
    Nick
    :laugh:
  16. Nov 11, 2014 at 5:43 PM
    #176
    ThomasMore66
    Just got it home! More tomorrow. ImageUploadedByTapatalk1415756589.674217.jpg
  17. Nov 11, 2014 at 5:44 PM
    #177
    VolcomTacoma
    Jeff
    NorCal
    Two tanks of gas? Three? Just to get home :D.
    Wife- where have you been
    You- melting tires
  18. Nov 11, 2014 at 6:04 PM
    #178
    ThomasMore66
    It does put a smile on your face.
  19. Nov 11, 2014 at 6:05 PM
    #179
    VolcomTacoma
    Jeff
    NorCal
    Just got my FedEx tracking from Toyota of Dallas :)
  20. Nov 11, 2014 at 7:01 PM
    #180
    VolcomTacoma
    Jeff
    NorCal
    Well, I might just pay to have it installed when I pick up the 4x4. if I buy anything that's got more than a 2 year warranty on it, I'll probably just shop around for the cheapest dealer install. If I don't get a good warranty because of an older truck, then yea, self install all day long.
