TRD SUPERCHARGER 4.0L
Discussion in 'Performance and Tuning' started by socalgasking, Dec 14, 2011.
  1. Dec 14, 2011 at 6:20 AM
    socalgasking
    socalgasking [OP] Well-Known Member
    Ash
    San Diego
    Lifted Supercharged Tacoma 4x4 Crew Winch
    Road Armor bumpers, warn winch, toy tech 3" lift, XD rockstar wheels, all terrain tires. SUPERCHARGED, Exhaust intake
    Just bought a tacoma with a factory TRD supercharger, TRD intake, and TRD exhaust.
    Still doesn't have as much power as i would like!! Any suggestions for additional performance mods?
    Also the truck came lifted with larger tires and Road Armor front and rear bumpers. I think the additional weight is making the brakes really suck balls.
    Any suggestions for improving brake capacity?
    I found a Rotora big brake kit on HPF.com but i dont want to pay an extra 3k after dropping 40k+ on the truck.
    Any suggestions? Thanks!!
  2. Dec 14, 2011 at 6:33 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    How big of a lift and tires? May be time to regear.
  3. Dec 14, 2011 at 6:34 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you should regear! you will get tons of power back, the bigger tires kills your power.
    theres a group buy going on for them right now. its well worth it
  4. Dec 14, 2011 at 6:34 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Got any pictures....? :popcorn:
    I don't know about adding any more power...how big are your tires?
    Edit: regear like they said ^
  5. Dec 14, 2011 at 6:36 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Go to www.URD.com and check out some of the nifty things Gadget has to offer.
    I'd bet a MAF unit would help you out a bit.
    You've got to understand though that your not going to get a whole lot more out of the setup. The heavy bumpers, lift, and larger tires are going to have an adverse effect on performance.
    Happy shopping!;)
    edit - forgot re-gear :rolleyes:
  6. Dec 14, 2011 at 6:49 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    This may or may not matter to you but changing anything with the TRD SC set-up will void any warranty on the SC and engine.
    I was working with a local dealership and TRD SC and exhaust was about it for TRD approved and warrantied modifications. That being said....
    You can go to a smaller pulley on the SC, that spins the SC faster and increases the boost, however you need to know at what point the ECU can not compensate for the increases in air flow. I don't know how much 'margin' there is in the TRD reflash for the ECU, it could be at the limit now or not.
    If you are at the limit you do not want to let your engine go into a lean condition (too much air per part of fuel), this will destroy a boosted (turbo or supercharged) engine in seconds.
    Like these guys said though you are pushing a lot of extra weight both sprung (bumpers, body parts) and unsprung (wheels/tires). IIRC the effect on power of unsprung weight is 10x more than the same weight on the body (sprung weight). In other words wheels that are 20 pounds total heavier all around is the same as having 200 pounds in the truck. IIRC, it's been a while.
  7. Dec 14, 2011 at 6:50 AM
    socalgasking
    Ash
    San Diego
    Thanks guys, i will look into re-gearing!! I freakin love this forum!!!
    the truck
    Whats up Craig!! Cant wait to get that grille!! Once i get my grill and black badges i will post some pics of the truck!! It will look like a Tacoma version of the Knight Rider!!!
  8. Dec 14, 2011 at 6:51 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :cool:
  9. Dec 14, 2011 at 8:37 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    the 2.8" pully from urd is great too it is a noticeable difference and looks just like the factory part it even has the factory part number stamped in it.
  10. Dec 14, 2011 at 9:44 AM
    socalgasking
    Ash
    San Diego
    This pulley looks like exactly what i need.
    My supercharger is warrantied till 100k miles from toyota, does anyone know if this pulley will void that warranty?
    Thanks for the info, much appreciated!!!
  11. Dec 14, 2011 at 10:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I assume that you have 35" tires. Those un-mounted alone will weigh almost 70 lbs each. Then heavier than stock wheels. Then heavier components for the lift. Then the heavier bumpers. I imagine that you are about 4600 pounds. So especially still with maybe 300 whp now, it is still going to be hard to get that heavy mass moving. That being with a stock 3.73:1. Thus why everyone else has said to regear.
    Next is improve the efficiency of the exhaust. Breathe in breathe out. :)
  12. Dec 14, 2011 at 10:19 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    regear and some headers!
  13. Dec 14, 2011 at 10:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Dec 14, 2011 at 9:32 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    ^ I like the rear disc conversion kit. That will improve braking alot!
  15. Dec 14, 2011 at 9:39 PM
    tacocolin
    tacocolin Well-Known Member
    Colin
    Cloudcroft New Mexico.
    Kevin's (ATO) bad ass rig he built
    Everything Kevin from ATO did on his... and then some. LOL
  16. Dec 15, 2011 at 7:07 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You can do a rear disk conversion. It is just pretty intensive, if you want to keep the front to rear biasing equal. You will have to add in a different proportioning valve, and possibly a different master cylinder. Otherwise, with the Rotora rear disk conversion the rear will lock up before the front.
    The first rear disk conversions were not that good. As the quote above tells. The newer ones as well as the Rotora ones are much better. However, I don't believe that Rotora has yet come out with a conversion for the 6 lug.
    A friend of mine has both front and rear, and is working on the proportion issue as we speak. Although his XR is high modified for drifting, thus he doesn't mind the skeletal function look, other might.
  17. Dec 15, 2011 at 7:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    To the OP, what are you using for tuning? The Toyota reflash?
  18. Dec 15, 2011 at 7:12 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    "BINGO"
  19. Dec 15, 2011 at 7:38 AM
    ETaco23
    Evan
    PNW
    wow! really? never heard that before.. I just know my boss's silverado with 4 wheeldisc brakes stops amazingly..
  20. Dec 15, 2011 at 9:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those have been properly balanced/biased.
    The engineers know what they are doing. The money holders prevent them from going all out. :rolleyes:
