TRD Supercharger....Any Thoughts
Discussion in 'Performance and Tuning' started by mountainprimat2, Jan 13, 2010.
  1. Jan 13, 2010 at 7:40 AM
    mountainprimat2
    mountainprimat2 [OP] Well-Known Member
    Stefan
    LI, New York
    09 DC TRD Off-Road 6spd man
    ICON Suspension 2.5 CoilOvers(Front), RXT 2.5 (Rears), 2.5 Hydraulic Bumps, ICON RXT Multi-Rate Leaf Spring, Total Chaos UCAs and LCAs, 33inch TOYO MTS on 17'' American Racing Teflon Coated Wheels, TRD Cat-Back Exhaust, TRD CAI, Grillcraft Grilles(U/L), MOT's Badge Grille Mod (Red), Black Lower Valence, Black Bed Lined Rear Bumper, Bushwacker Pocket Style Fender Flares, OEM Roof Rack, Wet Okole TRD Seat Covers, Husky Floor Liners,TRD 6spd Shifter Knob, Cobra CB w/ Firestick II, Interior LED Map(RED)/Dome(WHITE) Lights, LED Licence Plate Lights, Amber Fogs, Plasti Dip Badges, Trailer Harness Relocate, Thule Tail Gate Pad + Bed Rack
    I have 15,000 on my '09 TRD Off Road 4x4 double cab 6spd man which just wants to move as it is. The Black Cat exhaust is an added bonus but I want to do two things: Lift the rig a couple inches and add a TRD Supercharger. I usually get a ton of life out of my engines...250,000 on my '95 4runner without a rebuild. Some say that the supercharger will significantly decrease the engine life of the engine. Thoughts? Ideas?
  2. Jan 13, 2010 at 6:51 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    it will/can depending on your driving style with that supercharger
  3. Jan 13, 2010 at 6:53 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Well it probably doesn't help you engine
  4. Jan 13, 2010 at 7:09 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    it really depends on how much you beat on it.
    if you use the power for the occasional spirited run from a stoplight or passing people on the interstate, or the occasional towing. You really shouldnt have any ill effects.
    When cruising, the blower puts a negligible amount of additional stress and actually makes it run more efficient.
    If you are like some out there, and really could replace you throttle pedal with an on/off switch :). There would be extra wear and tear.
    List posted above, it really depends on your driving style
    Justin
  5. Jan 13, 2010 at 7:09 PM
    tacomamodboy
    tacomamodboy Member
    annapolis md
    09 trd off road
    Tube steps
    if you want more power go with the urd supercharger ive seen guys get 400 plus out of the xrunner with it anything that will cause more stress on your engine parts will probably put some wear and tear on engine parts you can always switch out engine parts with stronger ones that are designed for the stress if you get the trd supercharger installed by toyota ive heard theyll cover everything under warranty you should be good toyotas are built to last
  6. Jan 13, 2010 at 7:20 PM
    DarkShadows54
    DarkShadows54 Stop your whining
    Central Fl
    04 Lightning...bone stock...;)
    I dont think this is exactly right, many Lightning guys have shown even highway cruising the Eaton hurts your MPG. Case in point a guy drove to his tuner with his ported eaton and used 3/4 of a tank, no horsing around. They swapped on a whipple and he drove the same route home and used just over a half tank.
    I dont think there are any long term negative effects from the parasitic loss of spinning the blower at cruise however.
    that said so long as you dont beat the living hell out of it and run crappy gas it should still live a pretty long, healthy life so long as you keep a good tune and good plugs in it
  7. Jan 13, 2010 at 7:22 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    black cat exhaust?
  8. Jan 14, 2010 at 3:25 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    There may have been a problem with his bypass actuator then. The blower is belt driven, so its always spinning, the bypass actuator will be open to allow the excess air to be recycled back into the intake tract under normal vacuum.
  9. Jan 14, 2010 at 4:44 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    For this particular setup, most see a slight increase in MPG during cruising.
    When I installed the TRD on my old 3.4, the MPG increased slightly
    The same thing happened when I installed the URD MKI and MKII on my X-runner.
    Once I find the Dcab, I have a TRD blower for it, so I will see how that goes and if the trend continues :).
    They should be more efficient during cruising.
    but it really does depend on your driving habits
    Justin
  10. Jan 14, 2010 at 5:32 AM
    TBAGRR
    TBAGRR Well-Known Member
    Md
    07 4x4 sport
    Trd intake Doug Thorley long tubes URD short shifter Eibach front springs Tsb rear leafs
    the superchargers swirls the air into the combustion chamber, the effect of swirling air usually increases the efficiency of a internal combustion engine. Swirling air burns better in the combustion chamber so usually u will get some added mpg's. Now when people put s/c's on there ride they usually drive it harder thats why u dont hear many people getting better mpg's!!
  11. Jan 14, 2010 at 5:37 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    Exactly :)
    Justin
  12. Jan 17, 2010 at 10:56 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Installing a supercharger does not significantly decrease the engine life. If it is properly fueled and tuned the engine will last a very long time.
    I have a TRD Supercharger on my 96 4Runner, Serial number 299, and it has 190,000 miles on the truck with a URD 7th injector system. The engine is in perfect shape and I drive it all over the country to off road events. I use boost constantly!!!
    My 2005 XRunner has been boosted with a URD system for the last 70,000 miles and makes some serious power. The engine is in great shape. No oil consumption and the compression is right where it should be.
    Gadget
