TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Oct 9, 2015 at 2:04 AM
    #2141
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Really??!! sc is coming back to production? Where did you hear that from? How much from your friend Zeekevin? Might be interested if it's resonable
  2. Oct 9, 2015 at 2:37 AM
    #2142
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Sigh. Magnuson has the rights to make the TRD Superchargers now, just minus the TRD mark, since they were the original Manufacturers.
  3. Oct 9, 2015 at 5:05 PM
    #2143
    kingk0ng
    11 TRD OR AC
    just a few things.
    will it be smog legal like the trd?
  4. Oct 9, 2015 at 5:06 PM
    #2144
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    eventually
  5. Oct 9, 2015 at 6:46 PM
    #2145
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    LC Engineering who posted the return said they were working on the smog certification. It is the same SC minus the logo so I'd imagine no problem in getting it certified other than time, money and bureaucracy.
  6. Oct 9, 2015 at 6:57 PM
    #2146
    zeekevin
    zeekevin Well-Known Member
    San Diego
    i wonder how they are going to handle the ecu flashing
  7. Oct 9, 2015 at 8:00 PM
    #2147
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  8. Oct 10, 2015 at 8:27 AM
    #2148
    Dr. Cornwallis
    Dr. Cornwallis Well-Known Member
    Flarrrrrrrida
    2016 Super White TRD Offroad 4x4 AC
  9. Oct 10, 2015 at 9:24 AM
    #2149
    Renegade MkIV
    Renegade MkIV Member
    Atlanta, GA
    2015 Tacoma TRD Sport 4x4 1994 Toyota Supra Turbo
    Tacoma: Bone stock down to the air filter....for now..... Supra: Too much to list....
    Turbos win every time. Vastly more power potential and less heat issues HP for HP, not to mention better mileage if you back off. Turbos are back and bigger than ever at the moment, so now would be a brilliant time for Toyota to add twin turbos to the 2016 Tacoma for an extra 100 HP and TQ. Plus, they even sound cooler. Once you've experienced a turbo with open wastegate, everything else seems tame. :D
    Lord Helmet[QUOTED] and Torspd like this.
  10. Oct 10, 2015 at 9:31 AM
    #2150
    Dr. Cornwallis
    Flarrrrrrrida
    It's the perfect time yes, but Toyota has proven us time and time again they aren't that bright. Why do something that makes complete sense and give people exactly what they want, which also happens to be the best, most logical option when you can give them some bs engine from a rav 4 and they'll buy it anyways. Because toyota bro!
  11. Oct 10, 2015 at 11:13 AM
    #2151
    Renegade MkIV
    Atlanta, GA
    Not with a high end car. Sounds like sex.
  12. Oct 10, 2015 at 12:20 PM
    #2152
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Open wastegate sounds like ass. I ran one for years when I was younger. It makes it a pain in the ass to even play with the car. People can hear you coming form a mile away.
    Lord Helmet likes this.
  13. Oct 10, 2015 at 6:22 PM
    #2153
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Possibly referring to "Open" as in a turbo engine at full boost open?
  14. Oct 11, 2015 at 3:48 PM
    #2154
    bsaunder
    bsaunder Well-Known Member
    Colorado
    2015 DCSB TRD 6spd
    I'll look forward to the supercharger. I like turbos for street driving, but not off-road. Turbo diesels are great, but they already have the torque.
    At 5000ft+ altitude, even the best twin/quad turbo setup still has lag followed by punch - SC has the boost right off idle and can have much smoother torque curves (ie more driveable, vs binary street fun)
  15. Oct 11, 2015 at 7:19 PM
    #2155
    huj2000
    huj2000 Well-Known Member
    dan
    Burbank, il
    2010 Tacoma Offroad 4.0 V6
    Supercharger
    alright i successfully installed the sc i got the check engine light one and what ithink is the traction control light is this normal
  16. Oct 11, 2015 at 7:25 PM
    #2156
    matt2491
    matt2491 Well-Known Member
    Massachusetts
    2015 TRD Off-Road Supercharged
    Did you have the ECU re-flashed to the supercharger calibration?
  17. Oct 11, 2015 at 7:26 PM
    #2157
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Have you had the ECU flash at Toyota yet?
  18. Oct 11, 2015 at 7:42 PM
    #2158
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Quoted for truth :thumbsup:
  19. Oct 11, 2015 at 7:44 PM
    #2159
    Lord Helmet
    Nick
    LOL.... guilty of this in my younger days :anonymous: :D
  20. Oct 11, 2015 at 8:02 PM
    #2160
    Lord Helmet
    Nick
    I did the same on my DA9 :D I ran a external wastegate and instead of rerouting it back into the exhaust piping I just dumped it to the atmosphere :D
    Nothing like stomping on the throttle in front a Prius and seeing that black cloud in the review mirror :laugh: A ricer rolling coal :D
