TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Oct 13, 2015 at 10:34 AM
    #2181
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Orrrr, you can just play it safe and burn the tank down and refill it with premium as recommended by TRD. That's a warranty denied waiting to happen right there. You can say "the engine and ECU will do this and this and this, just run regular, you're fine" but when something goes wrong..."You should have waited for premium".
  2. Oct 13, 2015 at 10:46 AM
    #2182
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    never understood how all of you know when your super charger is going on yet u dont just put a tank of premium in a tank or two before.
    TRDMountaineer and Conumdrum like this.
  3. Oct 13, 2015 at 10:53 AM
    #2183
    VolcomTacoma
    Jeff
    NorCal
    I only use premium in mine...but waited to install my SC after buying the truck until I drove through the dealer tank of regular and half a tank of premium. I don't remember where, but someone actually posted dyno results on 87 vs 91 and there like 3-5 hp difference lol. Plus cleaner burning and less crap in it. You can say all you want about 87 being fine, but you've clearly never bought 87 from a Naval base before.
  4. Oct 13, 2015 at 10:56 AM
    #2184
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Your also in Cali. Piss water gas. last road trip I did down to san fran in my evo I had to retune the car when I filled up in just into cali. The car was knocking. I had to drop timming 2degs across the board and drop boost from 26psi to 23psi.
    Georgeth1022 and nfs257 like this.
  5. Oct 13, 2015 at 10:58 AM
    #2185
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I started to run premium about in mine 3 to 4 tanks before dropping it off at the dealer.
  6. Oct 13, 2015 at 11:02 AM
    #2186
    zeekevin
    zeekevin Well-Known Member
    San Diego
    California gas really causes a lot of issues
  7. Oct 13, 2015 at 11:27 AM
    #2187
    VolcomTacoma
    Jeff
    NorCal
    yea because the rest of the world's 87 is wonderful and never has any issues. All i'm saying is lets not encourage people to try to use 87 on their newly boosted Tacomas, that is a stupid, and you know it.
    JuanitoBonito likes this.
  8. Oct 13, 2015 at 11:29 AM
    #2188
    VolcomTacoma
    Jeff
    NorCal
    When i used to commute from San Diego to Orange County, I used to use 87 in another vehicle...I would fill up down at the base in San Diego and it would take over half a tank to get to Orange County, and then I'd drive around OC and empty the tank, then before I drove back down I'd fill back up at Chevron and it would take me maybe 1/4 of a tank to get back to SD.
  9. Oct 13, 2015 at 9:05 PM
    #2189
    ThomasMore66
    Dallas/Fort Worth & Durango
    That's what I did.
  10. Oct 13, 2015 at 9:27 PM
    #2190
    zeekevin
    San Diego
    i been running premium for the last 3 years. even before the sc lol california gas is very bad, causes a ton of spark knocking
  11. Oct 13, 2015 at 10:46 PM
    #2191
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    I've run premium in mine since I purchased the truck. It's the only way to go in Cali. It's only a few bucks more per tank.
  12. Oct 13, 2015 at 11:29 PM
    #2192
    Kodachrome
    Kodachrome Well-Known Member
    Western Colorado
    2005 Taco, 2024 Audi SQ8 ETron
    TRD S/C, URD...Stuff
    And if you are dealer ECU re-flashed you are also getting a 7th injector, upgraded fuel pump and UCON-EMS....right? Otherwise, pingitty-ding-ping!
    Unless one is 110% sure they are sticking with the stock TRD S/C setup, that damn re-flash hoses you for a lot of fun upgrades. The UCON is the only thing out there that will truly take over the re-flashed ECU in any meaningful way when it comes to getting enough fuel delivered to prevent detonation.
  13. Oct 14, 2015 at 6:37 AM
    #2193
    wedgemoose
    wedgemoose Well-Known Member
    Wedge
    Worcester,MA
    2014 TRD Sport
    Mine is in the shop right now being installed.
    Volcom, I wanted to do it myself, I really did. Especially when I put my stock Air cleaner set up back on this weekend and saw how open is was in there. But I found a dealer to do it for dirt cheap!! And he took it in right away. So I figured the warranty thing would make it worth it. Although I have never used warranty in my life.
    Can't wait though. Hopefully done today or tomorrow. I always use premium so no problem there. And I know it takes a little while for the ECU to learn. But can't wait for that initial pound.
    I just hope it's not some joker at the dealership doing it and snapping all my clips and stuff. It better be done right and perfect. Anything to look for when I get it back? Any tricky parts you guys remember so I can check on them to see if they did what they were supposed to? Or any clips or brackets they have the potential to screw up so I can replace if they did????
  14. Oct 14, 2015 at 7:44 AM
    #2194
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Yup me too. I started running 91 when I towed our camper and noticed it ran smoother all around so I haven't put 87 in in a couple of years. No SC here. I thought about it but am saving for a sports car instead.
  15. Oct 14, 2015 at 2:01 PM
    #2195
    wedgemoose
    Wedge
    Worcester,MA
    2014 TRD Sport
    officially in the club now. Done!!!! Shout out and special thanks to Crashnburn. Helped me on this one also. And Tacorican of course. Without him I wouldn't have it. Now time to play!! Dealer did awesome job. Engine compartment is as clean as when I dropped it off. Still want to know places I should check to see if done right.
  16. Oct 14, 2015 at 2:07 PM
    #2196
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Make sure ur not leaking from the resi mounted to ur fender..... The connections leak for some
  17. Oct 14, 2015 at 2:51 PM
    #2197
    VolcomTacoma
    Jeff
    NorCal
    Yea, take it for a spin, then check all your coolant connections on everything, like...everything that has a rubber hose pretty much got replaced or removed. I forgot the little 1/4" hose on top of the pump under the main unit and as soon as I started up I started leaking coolant everywhere...luckily I shut it off quick and found the hose lol. Other than that, i know a couple guys have had small drip leaks on some of the hoses that was fixed by adjusting clamps or using different clamps. I check mine over every couple of weeks and haven't found anything out of place yet!
    And hey! No worries man, I was so against installing myself, but after getting quotes around me from 1k-2500 for install I finally decided I'd give it a go. After spending a day reading through the instructions, It actually didn't seem that bad. After doing it now, I recommend it to anyone that can turn a wrench. I don't think there was anything super hard about it, just time consuming. As long as you follow the directions, as well as use the walk through someone did on here to supplement the instructions, its a good day! :D
  18. Oct 14, 2015 at 3:18 PM
    #2198
    zeekevin
    San Diego
    The hardest part would probably be the crank pulley after that it's straight forward
  19. Oct 14, 2015 at 9:01 PM
    #2199
    ThomasMore66
    Time for lights.
  20. Oct 14, 2015 at 9:32 PM
    #2200
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I wired my 2 car garage with 1800 watts equivalent of 100w CFLs. It is lit brighter than the brightest operating room. 500w halogen work lights make no difference. LEDs under the hood would probably only cast a shadow, unless of course I'm not at home.
