TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Oct 20, 2015 at 9:18 AM
    #2221
    Canks
    Canks Well-Known Member
    San Diego
    08 DCSB in pieces; 04 Tundra Access cab also in pieces
    At this time I have no plans to get the flash, I will be searching out some sort of data logger to monitor to monitor the knock sensor and verify that I'm not pulling timing etc. etc. 11.1 is a hair rich but very safe, outside of boost its dead nuts on to factory tune, so I'd say its good as is.
    I will eventually get a smaller pulley, headers, y-pipe etc. and will upgrade as it goes. Might mess with the next step up in pulley's just to see how the computer reacts. Waiting for the UCONN before I go to the smallest pulley.
    Lord Helmet likes this.
  2. Oct 20, 2015 at 5:56 PM
    #2222
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I like people who throw caution out the window :thumbsup: I have been waiting for the UCONN since 2012 so I'm quite sure you'll be waiting longer or you can run the Superchip, I heard it's a plug and play setup. Only down side I heard about the Superchip is finding a Superchip tuner unless your brother can figure out the Superchip fuel mappings :thumbsup:
    Canks[QUOTED] likes this.
  3. Oct 20, 2015 at 6:32 PM
    #2223
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    I'd be curious to see the fuel trim values without the flash also.
  4. Oct 20, 2015 at 6:47 PM
    #2224
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    The TRD engineers did not come up with a new map because the stock one was acceptable. And there is more to a map than A/F ratio, such as ignition timing. Just because you didn't experience knock at 65 degrees doesn't mean you won't at 30 degrees or 100 degrees. Your knock sensors are a reactive system that only work after potentially damaging detonation has already occurred. It is all fun and games till someone cracks a piston. I would not recommend anyone try this.
    vlodpg and stempsons like this.
  5. Oct 20, 2015 at 7:04 PM
    #2225
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    My knock sensors just throw me a code, saying to replace them. I still need to get my ECU and wiring checked out soon.
  6. Oct 20, 2015 at 7:27 PM
    #2226
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you do the flash and are running premium?
  7. Oct 20, 2015 at 7:32 PM
    #2227
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    I'm running premium but the truck was factory installed. Up to this date idk if Toyota or TRD did a flash on my truck.
  8. Oct 20, 2015 at 7:59 PM
    #2228
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea I'm gonna go ahead and stay on the reflash. As said above, Toyota reflashes for more than just A/F ratio...if it were that simple, alot more people wouldn't reflash and would just self tune
  9. Oct 20, 2015 at 8:19 PM
    #2229
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It also compensates for larger injectors which come with the TRD s/c.
    To prevent the OEM injectors from being maxed out. Especially once additional mods are added.
  10. Oct 20, 2015 at 8:34 PM
    #2230
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    The 1st gen or 2nd gen?
  11. Oct 20, 2015 at 8:45 PM
    #2231
    Dr. Cornwallis
    Dr. Cornwallis Well-Known Member
    Flarrrrrrrida
    2016 Super White TRD Offroad 4x4 AC
    I thought it was a "must do" sort of thing to have the ECU flashed but I guess not? This is the first I've heard of this.
  12. Oct 20, 2015 at 8:49 PM
    #2232
    ThomasMore66
    Dallas/Fort Worth & Durango
    No flash sounds like a really bad idea.
  13. Oct 20, 2015 at 10:24 PM
    #2233
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    A dealer should easily be able to tell if it was done or not. I'd double check.
    Just like putting premium in is a "must do".
    Do not confuse bad advice with correct engineering practice. I'm pretty sure the TRD engineers are far more qualified in determining the fuel map requirements than guess and check.
  14. Oct 20, 2015 at 10:51 PM
    #2234
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Hoping the check up bill won't cost too much. Stealerships like taking money.
  15. Oct 20, 2015 at 11:32 PM
    #2235
    VolcomTacoma
    Jeff
    NorCal
    The only time you can get away with no Toyota Reflash, as far as I know, is if you have UCON or a similar tuning device that can adjust all your major engine settings and ECU stuff.
    :popcorn: For the "I blew my engine up and I'm trying to put a warranty claim in" thread
    vlodpg likes this.
  16. Oct 21, 2015 at 5:40 AM
    #2236
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    2nd gen.
    First didn't originally come with injectors, flash, or intercooler.
  17. Oct 21, 2015 at 7:28 AM
    #2237
    wedgemoose
    wedgemoose Well-Known Member
    Wedge
    Worcester,MA
    2014 TRD Sport
    This guy now has me nervous though. My dealer didn't write ECU reflash on my invoice. And I just figured if they forgot to reflash it that a code would show up. But now with him saying all this I'm not sure.
    Anyone know another way I can tell if it was flashed? Besides asking the dealer(which I just did). Who knows, they might say they did it just to save face. Or the mechanic might tell them he did it to not get in trouble or something.
    Edit: Just heard back from Dealer and he assured me they flashed it. Feel better now. But still wish there was a way to tell
  18. Oct 21, 2015 at 9:03 AM
    #2238
    Canks
    San Diego
    Easy there fat Jesus, lets slide the rhetoric back there. This "bad advice" was not once meant to instruct people to run around with out proper tuning (whether that be the TRD flash or UCONN or otherwise). As stated in my first post on the subject it was intended solely for people driving to the dealer after they performed the install themselves. Everyone seems to freak out about driving from the location of install to the dealer for the flash stating that you need to be super careful. My point was, drive to the dealer like a normal sane person and don't sweat it. If you drive around without proper tuning or a way to monitor it you aren't very bright :D....
    Now I'll admit the conversation did then turn to what I am personally doing. I can't advise anyone to follow those footsteps because it is all so fresh. ... along those lines my brother and I had already scheduled more testing to make sure all is well. If anything changes I'll be sure and update, good or bad.
  19. Oct 21, 2015 at 9:09 AM
    #2239
    Canks
    San Diego
    Not sure how I feel about this, the first gen's got a supercharger and zero support until people started having real problems. Personally this leads me to believe that they are just covering their ass and did a basic tune that creates a blanket safety net across the board (mostly because of assholes like all of us whom modify our vehicles well past where the intended use). Personal opinion here.
    I agree with this whole heartedly.
  20. Oct 21, 2015 at 11:20 AM
    #2240
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Quote from Gadget:
    "There is a good reason why TRD does not include fuel and ignition upgrades with their [Gen1] supercharger kit. I was told by the folks at TRD the reason they do not do so is that they are being restricted by Toyota. TRD is part of Toyota in North America and because they are an arm of the manufacturer they would have to submit the entire kit with upgrades for EPA approval just like it was a new complete car. There simply is not enough profit in the supercharger kits to cover the cost of getting something like this through the EPA approval process, so can not include ignition and fuel system upgrades and the engine will run without them, but I can tell you for certain, it will run so much better with some additional tweaking in the fuel and ignition system. That is my understanding of what I was told by the folks at TRD."
    http://www.gadgetonline.com/Super.htm
    Even good engineers can be blocked by corporate bean counters.
    Toyota did it right in the 2nd gen SC, and provided a much more complete package with the upgrades and the tune to prevent 'real problems' and have a superior running kit.
