TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Feb 14, 2016 at 3:12 PM
    #2361
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea, it happens. Its just liquid being pumped, it makes that noise.
  2. Feb 14, 2016 at 7:16 PM
    #2362
    Erkon
    Erkon Well-Known Member
    Wisconsin
    2012 Pyrite Mica Tacoma TRD Supercharged
    Glad I'm not the only one
  3. Feb 15, 2016 at 5:55 AM
    #2363
    Erkon
    Wisconsin
  4. Feb 15, 2016 at 5:58 AM
    #2364
    Erkon
    Wisconsin
    That was when I got to work this morning. I have a 12 min drive to work. Every trip to and from work I can hear that.
    Let me know if you cannot hear it and I can pop the hood and try to capture the sound from under there. I haven't listened to it with the hood up yet but I'm 95% sure its coming from the small reservoir on the drivers side of the engine bay.
  5. Feb 15, 2016 at 9:37 AM
    #2365
    Erkon
    Wisconsin
    Bump for any answers
  6. Feb 15, 2016 at 9:49 AM
    #2366
    Erkon
    Wisconsin
    How full should the reservoir be? I dont recall seeing a full line or anything.
  7. Feb 15, 2016 at 9:55 AM
    #2367
    Erkon
    Wisconsin
    I think mine is about half full is all. I will add some more and get it to at least 3/4 full and see what happens.
  8. Feb 15, 2016 at 9:56 AM
    #2368
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know. I have seen this before an I am not necessarily supporting it, because I know the damage it does and can do over time namely to the catalytic converters, but on GM models (specifically LSx and LQ equipped vehicles, so performance and trucks/SUV's) they have an integrated feature that handles the AFR called "Lean Cruise." It essentially enables all their huge V8's to obtain the 23-30MPG you see them regularly achieving easily. I am wondering if there is a way to make that a possibility on our Tacoma's. The fuel savings on the highway would be pretty nice, because as of right now, I notice that on all highway unless you are on accel. or decel. the target AFR is always 14.7 no matter what.
  9. Feb 15, 2016 at 10:03 AM
    #2369
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Maybe tunning on the urd ecu can do that
  10. Feb 15, 2016 at 10:04 AM
    #2370
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's quite a bit to spend on the Ucon just to get a different cruise AFR, unless there is another way to get the tuning done without getting a new ECU?
  11. Feb 15, 2016 at 10:49 AM
    #2371
    Erkon
    Wisconsin
    Dealer installed at 1 mile. I just got the truck in November and have noticed the sound since I bought it. I have put about 2,000 miles on it since then. I am around 18,500 miles on the truck. I did have a clamp leaking slightly that came off that reservoir. I installed a new clamp. It wasn't dripping leaking so I don't think I lost that much coolant but probably just enough to make it low.
    I will top off the coolant and see if the "problem" persists. I will update this thread when I do. I dont have any coolant at home, only dex-cool so it may be a few days.
  12. Feb 15, 2016 at 10:51 AM
    #2372
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    I'm sure there are several ways you could go about it. I'm thinking maybe a switchable maf calibrator or something. I think you'd want more than an AFR to monitor it though. Cylinder head temp? Maybe EGT? Don't know.
    I'm not a tuning guru though, just spit balling.
  13. Feb 15, 2016 at 10:57 AM
    #2373
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Sub'd. Gimme my damn S/C!
  14. Feb 15, 2016 at 11:11 AM
    #2374
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    This is the entire reason why I want one too... "Midsize" is no excuse for inadequate power. These engines don't cut it when it comes time to tow 5,000 lbs (well within specs) at highway speeds.
    Biscuits likes this.
  15. Feb 15, 2016 at 1:10 PM
    #2375
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yes, you'd at least want to monitor EGT at a minimum.
  16. Feb 26, 2016 at 6:39 PM
    #2376
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
  17. Feb 27, 2016 at 9:26 AM
    #2377
    sester
    sester New Member
  18. Feb 27, 2016 at 10:38 AM
    #2378
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is the target stoichiometric air fuel ratio for gasoline's best efficiency, while in Closed loop. That is what you want the AFR to be.
    Keep the cruising AFR the same. Adjust the Open Loop AFR's and timing.
  19. Feb 27, 2016 at 10:46 AM
    #2379
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I thought they were doing some "improvements" to the blower but I see its advertising the same HP and TQ that the TRD kit originally did. Just cant justify that price tag for the gains. If it was WHP then I would be all over this new kit, but from what I've read it would take a lot more to reach 300whp with the TRD kit.
    Lord Helmet likes this.
  20. Feb 27, 2016 at 10:53 AM
    #2380
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Well, not a whole lot IIRC. @Torspd has dynographs of TRD-supercharged Tacomas with some fairly simple bolt-ons that reach 300rwhp.
    I know it's not a one-stop drop in 300rwhp mod though.
