TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Aug 14, 2015 at 4:41 PM
    #1041
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Makes sure to get metal core OBDII compliant high flow cats. High flow ceramic core cats will cause a CEL and even though they are working, you'll still need an O2 sim.
    Biscuits, STiLL WILL and Konvict KROG like this.
  2. Aug 14, 2015 at 5:13 PM
    #1042
    ThomasMore66
    Dallas/Fort Worth & Durango
    Good grief.
    Now you sir have created a problem. I'm hard after a shop to v-band the cats to the headers. Haven't found them yet. Seems like a little braided stainless flex pipe would make fit up even better on the downstream side.
  3. Aug 14, 2015 at 5:19 PM
    #1043
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Jotech is one of the many performance shops in your area. Turbo lined stainless steel flex couplings FTW!
  4. Aug 14, 2015 at 6:01 PM
    #1044
    ThomasMore66
    GTR's on the website. Already a plus. My favorite car.
  5. Aug 14, 2015 at 7:42 PM
    #1045
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    After looking at what's in the fit kit. It's not even worth the 500-580 most places are asking for it. You could make your own fit kit easy and cheaper
    Konvict KROG likes this.
  6. Aug 14, 2015 at 7:51 PM
    #1046
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
  7. Aug 14, 2015 at 7:53 PM
    #1047
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Maybe. From some pics there is more than you can tell from the parts list. Like a belt tensioner bracket. How are your mechanical drawing and welding skills?
  8. Aug 14, 2015 at 7:54 PM
    #1048
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    Is that the normal replacement part price? Or is that inflated due to the current situation?
    For 400 you could have a custom one to yoyr specs made.
    Torspd and Conumdrum like this.
  9. Aug 14, 2015 at 7:54 PM
    #1049
    Conumdrum
    Las Vegas
    2014 Tacoma
    Torspd likes this.
  10. Aug 14, 2015 at 7:57 PM
    #1050
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Nope. All that stuff comes in the main kit
    I have 2 friends that are engineers and both just finished making there own CNC machines. I can also weld if I needed to makes something my self or I have a few friends that work at extreme turbo systems that could help me out
  11. Aug 14, 2015 at 8:00 PM
    #1051
    Conumdrum
    Las Vegas
    2014 Tacoma
    This is the PDF install. Shows the parts kit. You figgure it out.......... And look at recent pics and see if the poster shows only the fit kit parts.
    SOMEONE post a pic of ONLY the fit kits parts please. SOMEONE. And verify the PDF I just posted PLEASE!
  12. Aug 14, 2015 at 8:01 PM
    #1052
    Konvict KROG
    Louisiana
    I installed mine myself.
    I can say there is barely 500 bucks worth of stuff in that kit.. After buying a LTR everything else could be made pretty easy.
    the kit is not a bad value at 500 bucks. But much more its excessive.
  13. Aug 14, 2015 at 8:03 PM
    #1053
    Conumdrum
    Las Vegas
    2014 Tacoma
    Your fit kit pic is WAYYYY diff than mine. See previous post. Mine is 10/20/07 in the PDF, what date does your's show? My install was on a 2014. No idea what the real paper showed, it's buried in a box in my garage.
  14. Aug 14, 2015 at 8:06 PM
    #1054
    Konvict KROG
    Louisiana
    The fit kits for tacoma are all the same. I believe there was a period where there was a difference between 2005-2011 and 2012-2015 but if not identical they are stupid close
  15. Aug 14, 2015 at 8:10 PM
    #1055
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    If you look date of this list is 10/22/2014
    On the left is the fit kit parts. On the right is the start of the supercharger package parts list. The supercharger package list goes on for 3 pages.
  16. Aug 14, 2015 at 8:10 PM
    #1056
    Conumdrum
    Las Vegas
    2014 Tacoma
    Well someone post the diff please, lots more in that other pic than the one I have.
  17. Aug 14, 2015 at 8:12 PM
    #1057
    Conumdrum
    Las Vegas
    2014 Tacoma
    Thanks, looks like my PDF is an old one without the big loom of wires etc. Appreciate it. My PDF is obsolete now. Poof, deleted.........
  18. Aug 14, 2015 at 8:12 PM
    #1058
    Konvict KROG
    Louisiana
    2015-08-14-23-10-49.jpgThe shit in red is the fit kit
  19. Aug 14, 2015 at 8:14 PM
    #1059
    Konvict KROG
    Louisiana
    I got mine from trd sparks. Didn't use it.
    I printed a manual for a 2012 I had before that (my kit was for a 2012) my truck is 2015.. no issues at all.
  20. Aug 14, 2015 at 8:21 PM
    #1060
    Konvict KROG
    Louisiana
