TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Aug 17, 2015 at 3:15 PM
    #1121
    robotninjasrule
    robotninjasrule Well-Known Member
    peter
    edmonton alberta
    2013 trd sport
    It was a toss up between AEM and snow. I honestly prefer the AEM brain, looks only. I went with snow because of the nozzles they claim to be the best.
  2. Aug 17, 2015 at 3:20 PM
    #1122
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    With the UCON, MAP-ECU3, or others, they can control it as well.
    I'll have to look on the Facebook lage for his XR. He's out of Florida.
  3. Aug 17, 2015 at 3:23 PM
    #1123
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    If only I could plug and play the UCON. I am seriously thinking of making the harness required , I already have the ECU (don't ask junk yard score) just need a second one to harvest the receptacle lol
  4. Aug 17, 2015 at 3:35 PM
    #1124
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Here he is - If someone wants to import the pictures, be my guest.
    STiLL WILL likes this.
  5. Aug 17, 2015 at 4:44 PM
    #1125
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I know of a member with a '12(?) that is running the 2.55" and an NST lower. Using the UniChip for tuning (plug n play). Cannot remember if he is using meth or a 7th injector. Small lift, larger than stock tires. Lots of added weight. Makes a pretty damn quick time down the 1/8th considering.
    I know of another using the 2.55 with a built engine. Getting a stroker kit installed. Should be easy mid 400's whp. Possibly closer to 500 when all sais and done. He definitely uses meth.
  6. Aug 17, 2015 at 4:47 PM
    #1126
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    :eek:
    :rofl:
    Torspd[QUOTED] likes this.
  7. Aug 17, 2015 at 4:50 PM
    #1127
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    I thought of unichip but local dyno/tuner does not have the provisions nor the knowledge to tune with it. I am hoping to get the 2.7 at least w/o tune. Then maybe this winter I'll work on the ECU. I highly doubt I will safely be able to do anything past he 2.7 w/o some kind of tuning. I have been thinking of getting a bigger Low temp radiator made as well.
  8. Aug 17, 2015 at 5:03 PM
    #1128
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Radiator? Heat exhanger? Or both?
    That guy has been tuning his own, but is now thinking of switching to the MAP-ECU3. Since it has more features of control. He is a go getter though, and isn't satisfied with waiting for plug.
  9. Aug 17, 2015 at 5:07 PM
    #1129
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    Heat exhanger mounted in front the rad. I briefly looked into getting a thicker radiator made. Oodles of room after getting rid of the clutch type fan. Cost vs benefit is quite low though.
  10. Aug 17, 2015 at 5:12 PM
    #1130
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You can pretty easily piece together a larger heat exchanger, from Jegs or Summit Racing. Or find one from a larger engine vehicle. Say the Tundra or Ford Lightning.
    I don't know if it has changed in recent years, but the pump itself had a Ford stamp on it. The upgrade when it failed, which has happened a lot in my history of these forums, has been to get the pump from the Lightning's kit.
    robotninjasrule likes this.
  11. Aug 17, 2015 at 5:47 PM
    #1131
    ninjaexplosion
    ninjaexplosion Well-Known Member
    steven
    AZ, CA, CO
    2004 Tacoma Double cab
    stock height on 35s, 488s
    Friday cant come soon enough
    robotninjasrule and Torspd like this.
  12. Aug 17, 2015 at 5:50 PM
    #1132
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which version blower is that?
  13. Aug 17, 2015 at 5:51 PM
    #1133
    ninjaexplosion
    steven
    AZ, CA, CO
  14. Aug 17, 2015 at 5:52 PM
    #1134
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I got that. Which version/size blower is that?
  15. Aug 17, 2015 at 5:55 PM
    #1135
    ninjaexplosion
    steven
    AZ, CA, CO
    hahaha sorry bud, i was wondering why you were asking, figured you knew lol
    C38-81 Supercharger
    Torspd likes this.
  16. Aug 17, 2015 at 6:20 PM
    #1136
    ThomasMore66
    Dallas/Fort Worth & Durango
    Did you replace your fuel pump? I'd like to have some data on why change other than opinion.
  17. Aug 17, 2015 at 6:23 PM
    #1137
    ThomasMore66
    Sigh... No Facebook. Sometimes you can see people's stuff without an account.
    Are you running water/meth injection?
  18. Aug 17, 2015 at 6:23 PM
    #1138
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    Yes I did change my fuel pump. I did it along with the 2.8 pully. I have 0 data with out it. I figured that it's a safe bet and pretty simple to do.
    Torspd likes this.
  19. Aug 17, 2015 at 6:47 PM
    #1139
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    We did testing. Independent of URD's. Compliments of @Moose1988 . Burnt the pump up at a fairly low HP equivalent flow rate. With the oem filter it came with. Testing was done in a lab. Not my garage. Apparently I lost the CD of the flow data.
    If you only ever plan on the s/c and its stock pulley, on a TACOMA, leave it alone. If you ever plan on adding more boost and more mods, on the TACOMA, upgrade the pump!
    @Lucario Runner
  20. Aug 17, 2015 at 7:48 PM
    #1140
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yup, thinking on tackling my pump replacement next week...maybe this week, we'll see how much free time I can get. Need to throw on the 2.85 pulley and then watch my AFR...now I just need to track down a good welder for my headers...
    On another note, picked up some 265/70/17 MT's today, can DEFINITELY feel the difference in power. Really glad I've got the boost and performance mods...my god, what ever was I thinking before lol
