TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Aug 18, 2015 at 10:51 PM
    #1161
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    yeah, like which ratchet doesnt make my butt look big?
  2. Aug 18, 2015 at 10:51 PM
    #1162
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    or, boost gauge = rice?
  3. Aug 18, 2015 at 11:03 PM
    #1163
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Patty farmers just jealous and ignorant on the facts. ;)
    We shall call them Peasants.
  4. Aug 18, 2015 at 11:04 PM
    #1164
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    fuel pumps are overrated too............someone should run one and see how long till they burst into.......................oh yeah, thats right
    Torspd[QUOTED] likes this.
  5. Aug 18, 2015 at 11:05 PM
    #1165
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Or Kardashians.
  6. Aug 18, 2015 at 11:07 PM
    #1166
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only if they can properly boost a bottle of champagne onto their arses.
  7. Aug 18, 2015 at 11:07 PM
    #1167
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Kimmy's meat curtains could hide a magnum of drank in there
    Biscuits likes this.
  8. Aug 18, 2015 at 11:18 PM
    #1168
    littleblue81
    littleblue81 Well-Known Member
    At what temperature will the truck overheat? This past weekend my ultragauge was reading 210+ degrees slow crawling up hill in 1st gear in 4L. It was maybe 90 degrees outside.
    The truck hit similar temperatures last year doing the same thing without the blower.
  9. Aug 18, 2015 at 11:41 PM
    #1169
    123erinnc
    123erinnc Well-Known Member
    Erinn
    Lake Arrowhead, CA
    2014 Double Cab Long Bed 4x4 TRD
    Weathertech, Wet Okoles, OME 887, Nitrochargers, LR UCA...
    So now that the TRD supercharger is being discontinued, is there any other supercharger options out there for the Tacoma?
  10. Aug 18, 2015 at 11:42 PM
    #1170
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Plead with Eaton and magnusson
    Unless u want a belt driven turbo, then u could ask them to come on board I guess. I just like tq on demand
  11. Aug 18, 2015 at 11:47 PM
    #1171
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    true dat..... Hack wires, use spotty uconn, don't bother checking oil, have crotchety tech support, and u too can have a supercharger
  12. Aug 18, 2015 at 11:55 PM
    #1172
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Think I'd join the L S X wagon too.......maybe internship at Nelson racing engines first.
  13. Aug 19, 2015 at 3:25 AM
    #1173
    ThomasMore66
    Dallas/Fort Worth & Durango
    An internship at Nelson would be cool. Hell, I'd just like to just watch those guys work and ask questions.
    Justus[QUOTED] likes this.
  14. Aug 19, 2015 at 3:27 AM
    #1174
    ThomasMore66
    I've seen some numbers close to that sitting in 100+ at a standstill in traffic. I haven't had any issues so far.
  15. Aug 19, 2015 at 11:33 AM
    #1175
    JDELA
    JDELA Active Member
    I work at a Toyota dealer and had my parts guy search up inventory/prices on the blower and fit kit. Looks like the fit kit is on massive back order as you all already know. The blower I can get by the next day. Has anyone pieced together their own fit kit?
    Here's my 'employee pricing' if I were to order. I could probably even get a better deal if I talk directly to the parts manager too.
    redsoxcole likes this.
  16. Aug 19, 2015 at 11:38 AM
    #1176
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You should do that immediately
  17. Aug 19, 2015 at 12:04 PM
    #1177
    JDELA
    JDELA Active Member
    Details about current inventory on the fit kit... looks like it will be a long wait (possibly a few months) until the backorders will be fulfilled.
    *Edit: Talked more into detail with my parts guy and he said that as long as they get a 'reference number' the kit is guaranteed to ship and arrive even if you are on the waitlist.
  18. Aug 19, 2015 at 12:10 PM
    #1178
    VolcomTacoma
    Jeff
    NorCal
    Or refunds are issued...
  19. Aug 19, 2015 at 12:17 PM
    #1179
    JDELA
    JDELA Active Member
    And there is my dilemma. Buy the blower and get on the waitlist for the fit kit or just put together my own. Labor and reflash would be free :D
  20. Aug 19, 2015 at 12:24 PM
    #1180
    VolcomTacoma
    Jeff
    NorCal
    If you have the cash, I'd get the blower now...worst case you can always fab up the fit kit easily enough
    JDELA likes this.
