TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Aug 28, 2015 at 4:58 PM
    #1281
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    It seems like the smart thing for both parties is for Toyota to sell the rights to magnuson. Toyota gets money, magnuson can still make money selling and producing the part and Toyota could offset the cost of being federally required to support the part for 10 years.
  2. Aug 28, 2015 at 5:00 PM
    #1282
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Yep copyright etc. Meaning legalese. Lawyers. Takes time. No worries for you and me. I'm thinking of not watching this thread anymore. I can't help, I just see folks thrash. No fun.
  3. Aug 28, 2015 at 5:00 PM
    #1283
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I'd rock it scratched so people could see my mall is more extreme than theirs.
    Torspd likes this.
  4. Aug 28, 2015 at 5:04 PM
    #1284
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    True, though that FJ kit should be able to be made to work if you do the install (assuming it is still available).
    Worst case senario is you sell them both together for much more than you paid for each individually.
  5. Aug 28, 2015 at 5:17 PM
    #1285
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am waiting on a response from a source of mine, to see if he is willing to make the two most necessary parts of the fit kit. The thermostat spacer and the belt bracket/tensioner assembly.
  6. Aug 28, 2015 at 5:20 PM
    #1286
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I already mentioned this, as well. Haven't heard if anyone has looked into the availability of the 4Runner or FJ fit kits though?
    That is just a simple question to ask. Everyone has been asking about Tacoma fit kits. Someone should ask about those.....
  7. Aug 28, 2015 at 5:34 PM
    #1287
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    SC + Tacoma fit kit available for $6900:
    http://www.egmcartech.com/store/Bra...Kit-Ptr29-35090-Ptr29-35120_121733342162.html
    The FJ kits are scarce too, haven't heard anything on the 4Runner that would be good to checkout. I posted where some FJ kits were still listed as 'in stock' earlier. Not sure if anyone tried ordering.
  8. Aug 28, 2015 at 8:56 PM
    #1288
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My source said that he will look into the viability of making the parts I mentioned, and get back with me.
    What all comes in the fit kit besides those parts? Main things. Not nuts and bolts.
  9. Aug 28, 2015 at 9:12 PM
    #1289
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Im sure Toyota owns all of the tooling to make those superchargers so they won't be able to use it without their permission. However they could get around it if they slightly altered the supercharger to use different tooling to make essentially the same product to accomplish the same task, but it probably would not be worth it from their prospective to do that. But one can always hope :pray:
  10. Aug 28, 2015 at 9:50 PM
    #1290
    ThomasMore66
    Dallas/Fort Worth & Durango
    This is why people go US manf.
  11. Aug 28, 2015 at 10:43 PM
    #1291
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Why would your friend need to make those parts? They are not in the fit kit. Both those parts are in the main kit. I posted a pic of what's in the fit kits.
  12. Aug 28, 2015 at 11:00 PM
    #1292
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I don't think there was a fan boy stampede.
    I believe a lot of people had planned on getting them. I picked my truck up in November and planned on buying at tax return time this coming year. But TRD discontinuing it, pushed people to buy now. I had other stuff I wanted to do first but had to buy now.
    1truckdriver likes this.
  13. Aug 28, 2015 at 11:22 PM
    #1293
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Stampede yes. Fan boy no. I would say fan boy if we were talking Subaru/ken block and monster. :D;)
  14. Aug 29, 2015 at 11:26 AM
    #1294
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I had just skimmes over that picture.
    Apparently those parts aren't needed. Lol.
    So what the heck is in the fit kit that makes it so important?
  15. Aug 29, 2015 at 11:32 AM
    #1295
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    "The fit kit is basicaly the heat exchanger and brackets. The items on this list of the fit kit that may cause you issues are:
    The replacment bracket that holds up the radiator support.
    bracket for the intercooler surge bottle.
    wiring harness for the intercooler pump."
    That is what is stopping people from installing this kit? :facepalm: This is Tacoma World. With all of the innovators on this website, there isn't a single person that can just do a simple DIY for those part? Seriously.......?
  16. Aug 29, 2015 at 11:35 AM
    #1296
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well, he's looking into the brackets now. As those are much easier.
    There are some that don't have the time or skill to make the brackets. I understand that. For those that can, there are enough people on this forum that can pull together, take pictures, and make things happen.
    Or we wait for my source, to hopefully make a bolt-on product. Of which are always high quality.
  17. Aug 29, 2015 at 12:21 PM
    #1297
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    The heat exchanger is the main of the fit kit. Then you have the hood support backet/ coolent res bracket (if your truck has atrac that bracket is in the main kit)wiring. All this stuff can be picked up else were and made to work.
    Wiring
    http://www.superchargersonline.com/index.php?main_page=index&cPath=510_1689_1777
    Heat exchanger
    http://www.frozenboost.com/water-to-air-heat-exchanger/
    I'm not even going to be using the factory coolent Rez. I'm having a friend make me one that is bigger and made out of aluminum. Then in a few months I'm going to replace the heat exchanger with a bigger core and a better pump.
  18. Aug 29, 2015 at 12:34 PM
    #1298
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Now that is what I'm talking about. Not sitting idly by and letting things pass you up because you couldn't/wouldn't do it yourself. Bravo sir.
  19. Aug 30, 2015 at 5:14 AM
    #1299
    redsoxcole
    redsoxcole Well-Known Member
    Cary, NC
    2011 TRD Off-Road 4X4 DCSB TRD Supercharged
    TRD Supercharger, 3" lift, 33" AT BFG's, V1 Radar Detector, Python 5906P Remote Start.
    Well I got my S/C installed. Only big problem I had was getting the crank pulley bolt off! I had to use a 1,100ft lbs impact wrench to break it lose. Thank god for friends. Waiting to reflash Monday now.
    Torspd likes this.
  20. Aug 30, 2015 at 6:07 AM
    #1300
    Tacotalker12
    Tacotalker12 Member
    shawn
    2012 taco trd sport
    Bone stock
    We can get Chuck Norris to start kicking heads up in corporate office
