TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Aug 30, 2015 at 6:17 AM
    #1301
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    Ingersoll Rand 1/2 Titanium max series is what I used.
  2. Aug 30, 2015 at 6:17 AM
    #1302
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    I already called to cancel & refund my extended warrenty due to the TRD SC discontinuation.
    I'm so pissed that I almost want to trade my Toyota for a 15 Nissan Xterra 6sp.
    Haven't decieded to cancel yet.
  3. Aug 30, 2015 at 10:36 AM
    #1303
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    My electric impact couldnt do it...ended up just doing the sketch way some have done it and just putting a breaker bar on the bolt head and then laying the bar on the frame and just trying to start it for a second to get it try to crank. Took about 5 tries of cranking and the bolt loosened. I must say, having two people for your install makes it waaayy easier. If my neighbor hadnt come over to help, it would have taken me a good solid 2 days to do it instead of a solid 16 hour day
  4. Aug 30, 2015 at 10:40 AM
    #1304
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    That is what I've ended up doing every time. Always works. I throw an old towel around the end of the breaker bar to not mar the finish off the frame.
  5. Aug 30, 2015 at 11:05 AM
    #1305
    VolcomTacoma
    Jeff
    NorCal
    Yup! Works like a charm!
  6. Aug 30, 2015 at 11:29 AM
    #1306
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    if you dont have an impact with enough ass, a big chain wrench with a piece of old scrap serp belt works too. havent looked under my taco, but was a lexus tech for years, the other trick is to use a line punch or similar to wedge in the flex plate. the starter trick works, but once in a while bad things happen.
  7. Aug 30, 2015 at 11:37 AM
    #1307
    VolcomTacoma
    Jeff
    NorCal
    I had a giant breaker on there to try to break it off and it was just spinning the engine lol. The only option would have been a super high pressure impact or the starter trick. Leverage was just making it spin, even in 4th gear
  8. Aug 30, 2015 at 12:10 PM
    #1308
    DEMikey
    mikey
    delaware
    2013 red taco
    oh i know, and being a manual makes it worse. im trying to remember what engine (vq or rb 2jz or something. i cant remember) the ARP crank bolt is silly like 180 ft/LB PLUS 180° .a chain wrench is the only way.
  9. Aug 30, 2015 at 12:23 PM
    #1309
    VolcomTacoma
    Jeff
    NorCal
    The crank bolt on ours is 204 lbs torqued lol.
    At least thats what the new one was instructed to be torqued at
  10. Aug 30, 2015 at 1:28 PM
    #1310
    DEMikey
    mikey
    delaware
    2013 red taco
    well there ya go. its always harder to get it moving than it is to keep it moving.
  11. Aug 30, 2015 at 1:53 PM
    #1311
    VolcomTacoma
    Jeff
    NorCal
    I just put the long torque wrench on it and had it in 4th gear, it took a couple tries to slowly pull until i got it to click around 205 ft/lbs without the crank rolling on me, but i got it.
  12. Aug 30, 2015 at 2:21 PM
    #1312
    VolcomTacoma
    Jeff
    NorCal
    Wut? Oh...yours just rolls around all day long lol?
    I wouldn't know :rofl: :rofl: :rofl: :rofl: :rofl:
  13. Aug 30, 2015 at 5:16 PM
    #1313
    Konvict KROG
    Louisiana
    I thought it was 277
    I have used the starter trick in the past many times. Before I had an impact with some serious ass!
    Last year I broke a crank bolt off in a 22r/20r hybrid that locked up.
  14. Aug 30, 2015 at 5:19 PM
    #1314
    Konvict KROG
    Louisiana
    My torque wrench only went to 175 lbs so I used the impact to put it on.
    Normally all I torque is the head bolts and flywheel bolts. But for this truck I torqued everything to spec except the crank bolt.
  15. Aug 30, 2015 at 5:19 PM
    #1315
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
    Ugh... that sucks. What you do to remove it? Bolt extractor Or did you have to drop the bottom end and remove the crank out?
  16. Aug 30, 2015 at 5:23 PM
    #1316
    Konvict KROG
    Louisiana
    Luckily it broke at the bolts head vs deeper inside. And I had the engine on a stand. I ended up drilling, freezing it and using a bolt extractor. It came out way easier than I expected.
  17. Aug 30, 2015 at 5:26 PM
    #1317
    Lord Helmet
    Nick
    Nice, that's the only reason I don't like the using the starter trick is because of a possibility of the the crank bolt getting sheared off. Then it's a PITA.
  18. Aug 30, 2015 at 5:29 PM
    #1318
    Konvict KROG
    Louisiana
    I love these suckers. I use the 3/8 for everything. Only break out the 1/2 for a few jobs like rusted U bolts, and crank bolts1440980797904.jpg etc.
    Biscuits and Lord Helmet like this.
  19. Aug 30, 2015 at 5:43 PM
    #1319
    Lord Helmet
    Nick
    My favorite brand when it comes to air tools :thumbsup:
    Konvict KROG[QUOTED] likes this.
  20. Aug 30, 2015 at 5:44 PM
    #1320
    Konvict KROG
    Louisiana
    Also for a budget impact. The 1/2 Pittsburgh earthquake is a pretty damn respectable impact. Its heavy as hell but it beat the shit out of the other 1/2 impacts I have minus the IR Titanium. It is a copy of the Ingersoll rand tgunder guns.
    I have a
    Blue Point 1/2, blue point 3/8
    MAC 1/2
    Cornwell 1/2
    Pittsburgh earthquake 1/2
    IR titanium 1/2, IR Titanium 3/8
    Craftsman c3 1/2
    Milwaukee 1/2
    Rigid 1/4 (hex)
    Campbell house? 1/2(walmart junker)
    And an older craftsman IR rebrand 1/2
    Lord Helmet likes this.
