TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Sep 9, 2015 at 4:52 PM
    #1521
    ThomasMore66
    Dallas/Fort Worth & Durango
    The Sentinels will be coming. They smell the fear.
    Canadians can't be trusted to leave things alone.
  2. Sep 9, 2015 at 5:54 PM
    #1522
    jsriolo
    jsriolo Well-Known Member
    Susquehanna, PA
    2015 TRD Off-Road V6 6-Speed 4x4 Access Cab
    Huh did not see anything in the "Buy / Sell / Trade" section. I will take a look.
  3. Sep 9, 2015 at 6:10 PM
    #1523
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Page 87
  4. Sep 9, 2015 at 9:12 PM
    #1524
    ThomasMore66
    Nobody has come for us yet.
  5. Sep 9, 2015 at 9:48 PM
    #1525
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Your religion is worse than my religion! I hate your political views! You love spiders! Uh...what else...hmmm...RACIST COMMENT!!
  6. Sep 9, 2015 at 11:18 PM
    #1526
    huj2000
    huj2000 Well-Known Member
    dan
    Burbank, il
    2010 Tacoma Offroad 4.0 V6
    Supercharger
    Just put in mynorder for trd auperchargwr kit for fjcruiser im gonna do the same way brianawd did gonna post results when i gt it and put it in
  7. Sep 9, 2015 at 11:20 PM
    #1527
    huj2000
    dan
    Burbank, il
    Supercharger
    Found it on ebay and its actually been there for a while so surprised noone took it sooner the main kit is exact same part number as for tacoma kux its same engine i got it for 4700 with fj fit kit and shipping
  8. Sep 9, 2015 at 11:51 PM
    #1528
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lol dude the TRD supercharger stock tune is so pig rich it's disgusting. Though I'm pretty sure you know that. I go as low at 9.5 AFR on WOT runs. This supercharger NEEDS more air to help clean up all that fuel it's dumping out.
  9. Sep 10, 2015 at 1:07 AM
    #1529
    VolcomTacoma
    Jeff
    NorCal
    We both know that Rob, what I'm pointing out is that Toyota put a blanket warranty void on aftermarket CAI's. Just don't want someone to walk in for a reflash with an AFE and get turned away becausd of stupid dealers
    12TRDTacoma likes this.
  10. Sep 10, 2015 at 1:09 AM
    #1530
    VolcomTacoma
    Jeff
    NorCal
  11. Sep 10, 2015 at 6:03 AM
    #1531
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I still need to install my E85 Walbro 400LPH pump.
    Lord Helmet likes this.
  12. Sep 10, 2015 at 6:45 AM
    #1532
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Needs moar foampile
  13. Sep 10, 2015 at 8:55 AM
    #1533
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Did you ever post the stock LPH numbers you were working on? If not can you PM me, I'm curious.
  14. Sep 10, 2015 at 9:16 AM
    #1534
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Score. I think I saw that a while ago and was also surprised no one jumped on it.
  15. Sep 10, 2015 at 10:19 AM
    #1535
    huj2000
    dan
    Burbank, il
    Supercharger
    should be gettin it the 15th
  16. Sep 10, 2015 at 10:30 AM
    #1536
    VolcomTacoma
    Jeff
    NorCal
    Im hoping for Sundayish install, gotta drive around some more and get rid of gas :D
  17. Sep 10, 2015 at 10:37 AM
    #1537
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Apparently I lost the disk with the data. Big debate between us about that. Thanks for reminding me. I'll ask for a new copy again.
    All I can say is that they weren't promising.
  18. Sep 10, 2015 at 10:44 AM
    #1538
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I dropped out of the debate, but I'd appreciate the data before I install my URD pump kit. Thanks!
  19. Sep 10, 2015 at 10:53 AM
    #1539
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I just meant a debate about who actually lost the disk. I'm rooting for myself that I didn't. :anonymous:
  20. Sep 10, 2015 at 11:08 AM
    #1540
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Was it on Hillary's server?
