TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Jul 2, 2015 at 1:22 PM
    #141
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The higher the octane rating the more stable the fuel is to burning. It also means it typically burns slower. I had to up my octane from 87 to 91, and any and all pinging went away IMMEDIATELY.
    JuanitoBonito[QUOTED] likes this.
  2. Jul 2, 2015 at 1:23 PM
    #142
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    The problem with e85 is not the octane rating. The stochiometric spelled wrong is different and the flow rate is different between it and standard gasoline. . Unless your computer knows how to adjust you may do damage. Some non flex fuel vehicles will run ok and adjust just enough but its not preferred.
    Our manual says 91 or better octane no more than 10 percent alcohol.
    12TRDTacoma likes this.
  3. Jul 2, 2015 at 1:24 PM
    #143
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea I'm just gonna go ahead and stick with 91 and maybe some octane booster when I'm feeling frisky.
  4. Jul 2, 2015 at 1:28 PM
    #144
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Fuck it, just throw some AVGAS in there. 130 Octane bitches!
    And zero performance gain, since the S/C is tuned to 91.
  5. Jul 2, 2015 at 1:31 PM
    #145
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I am aware of the fact that the adjustment may not be enough which is why I'm a bit leery of tryjng that out. Especially since boost can make or break your engine if its not running correctly.
  6. Jul 2, 2015 at 1:32 PM
    #146
    Konvict KROG
    Louisiana
    Hahaha thats great.
    Leaded too
  7. Jul 2, 2015 at 1:33 PM
    #147
    littleblue81
    littleblue81 Well-Known Member
    Hmmm. I suppose it would be a good idea to carry some octane booster in the car then...?
  8. Jul 2, 2015 at 1:33 PM
    #148
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yup. Good bye catalytic converters. If your stupid enough to try AVGAS you shouldn't have a S/C.
  9. Jul 2, 2015 at 1:35 PM
    #149
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Depends. What are the odds you'll find a service station that doesn't sell premium? On the trail you should always carry your own fuel anyways.
  10. Jul 2, 2015 at 1:44 PM
    #150
    Konvict KROG
    Louisiana
    I wouldn't bother. it doesn't work very well..
    It can help a little in an emergency.
    But we are tuned for 91 on the trd shit that is available prettty much anywhere
    The problem I had on the other car was it was tuned on 93 pure gas. And I tried the octane booster to run 91..
    The tune on that was not THE trd tune.
  11. Jul 2, 2015 at 8:42 PM
    #151
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Has anyone measured the lost stock 'lift' after SC install? Just curious with an additional 70lbs added over the front axle.
    Planning a multi-day off road trip next month and bumping up the tire size to 265/70R17, I'm concerned about clearance.
  12. Jul 2, 2015 at 8:46 PM
    #152
    VolcomTacoma
    Jeff
    NorCal
    Should be fine if you stay in boost all the time..all that HP should keep the front end up :rofl:
  13. Jul 2, 2015 at 8:56 PM
    #153
    Konvict KROG
    Louisiana
    Haha well you take some stuff off that doesn't go back on. I bet its 30-40 pounds at most additional weight. Shouldn't really affect you in any noticeable fashion.
  14. Jul 2, 2015 at 9:02 PM
    #154
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    Your better off carrying a jug of 100 octane race fuel than octane booster. Octane boosters will leave sediments and deposits on spark plugs and O2 wide bands. You'll foul plugs unless you want to change them all the time?
  15. Jul 2, 2015 at 9:06 PM
    #155
    Dubie220
    Dubie220 Active Member
    NorCal
    14 DCLB 4X4 Sport
    I'm thinking about having the dealer do the flywheel pulley and ecu flash, then doing the rest myself. For you guys that are installing it yourself, how long is it taking you to do it?
  16. Jul 2, 2015 at 9:07 PM
    #156
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I read somewhere yesterday that the TRD blower tune is actually capable of compensating enough for up to 94 octane. I believe it too. The ECM is capable of making some pretty good compensations for changes in the volatility/ stability of fuel.
  17. Jul 2, 2015 at 9:11 PM
    #157
    Konvict KROG
    Louisiana
    I would say plan on 6 hours a day for 2 days. That is a very relaxed and taking it easy following the instructions to the Tee pace.
    I wouldn't recommend octane booster anyway. Its not a very consistent result. And 100 octane race fuel is hard to get in some places. Really just put the right fuel in and don't worry about it. If your potentially somewhere you may run out I would carry a can of fuel just in case. Most people carry regular if they have any.
  18. Jul 2, 2015 at 9:13 PM
    #158
    Konvict KROG
    Louisiana
    Too high of an octane is just going to waste money. You could run 105 sunoco lead free if you wanted. You just wouldn't get anything more than 93 or 94 octane for the money.
    12TRDTacoma[QUOTED] likes this.
  19. Jul 2, 2015 at 9:15 PM
    #159
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Why don't you guys run meth injection?
  20. Jul 2, 2015 at 9:16 PM
    #160
    Dubie220
    NorCal
    14 DCLB 4X4 Sport
    For those looking. I located mine by going to www.partsvoice.com and putting in part number for fit kit. PTR29-35120
