TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Sep 14, 2015 at 8:44 PM
    #1661
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Make sure the headers have the air injection stuff for 2012+
  2. Sep 14, 2015 at 8:53 PM
    #1662
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    As far as I know, they do. I'm just paranoid about the emission stuff....as far as being able to pass and not have problems come time. Just to double check with you guys though...he told me removing the rear cats(which the y-pipe will do) will not hamper the emissions. There are the 4 O2 sensors, 2 before the front cats and 2 after so I shouldn't have a problem.....this sound right to you guys? As far as removing the rear cats and not having emission problems??
  3. Sep 14, 2015 at 9:22 PM
    #1663
    VolcomTacoma
    Jeff
    NorCal
    I have no codes thrown if that's what you're asking.
  4. Sep 14, 2015 at 9:24 PM
    #1664
    ThomasMore66
    Dallas/Fort Worth & Durango
    Dude, that's why I haven't altered the manifolds, but when I do, they will be the shorties. It's my DD, and I don't have time for issues.
    12TRDTacoma likes this.
  5. Sep 14, 2015 at 9:36 PM
    #1665
    VolcomTacoma
    Jeff
    NorCal
    I would, but A) California and B) Total Chaos Coil Bucket Gussets
  6. Sep 14, 2015 at 9:40 PM
    #1666
    ThomasMore66
    I agree. Meh!
  7. Sep 14, 2015 at 9:43 PM
    #1667
    VolcomTacoma
    Jeff
    NorCal
    C) Doug Thorley Shorties are already sitting in the garage
  8. Sep 14, 2015 at 9:50 PM
    #1668
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I had to change mine out. I was basically forced to or else my truck wouldn't run. The supercharger was an afterthought because I had the funds available for it at the time is all. As far as the fuel pump upgrade for the 2.85 is concerned I would do it. You don't want fuel starvation at the top end! Even if the AFR reads correct you don't know if the fuel pump is having issues keeping up with volume demand.
    STiLL WILL likes this.
  9. Sep 14, 2015 at 9:53 PM
    #1669
    zeekevin
    zeekevin Well-Known Member
    San Diego
    i been eye balling the urd spec u header for the 2012+ and the spec u full exhaust system. it looks like the perfect combination. add in the urd o2 simulator = no check engine lights
    smog wise, in california now anything 2000 and above does not have to do a sniffer test. they do a obd2 scan for any check engine lights and the emissions monitors. they still have to do a visual but a truck with full skids and lots of dirt and mud, the tech may overlook that issue.
  10. Sep 14, 2015 at 10:38 PM
    #1670
    VolcomTacoma
    Jeff
    NorCal
    I didn't like the way the Spec U Exhaust system sounded. The extra resonator they added gave it to much of a euro ricer sound to me. The Mark III 3" exhaust sounds alot beefier to me.
  11. Sep 14, 2015 at 10:54 PM
    #1671
    zeekevin
    San Diego
    true the mark III sounds better on the 6sp vs the autos. i just wish i can hear the full spec u exhaust system in person.
  12. Sep 15, 2015 at 5:55 AM
    #1672
    VolcomTacoma
    Jeff
    NorCal
    The Mark 3 sounds better than the Spec U full system, but the Mark 3 does have a bit of a rasp at higher rpms. Thats just from 2 less cats....the Spec U needs two mufflers because of no cats with the headers as well, but to me ends up sounding like some european sports car. The Mark 3 to me puts out a pretty aggressive rumble, and you can get it and the y pipe for a good $500 less than a spec U.
  13. Sep 15, 2015 at 8:07 AM
    #1673
    zeekevin
    San Diego
    Any exhaust drone while cruising?
  14. Sep 15, 2015 at 9:33 AM
    #1674
    VolcomTacoma
    Jeff
    NorCal
  15. Sep 15, 2015 at 9:34 AM
    #1675
    VolcomTacoma
    Jeff
    NorCal
    I just turn the music up
  16. Sep 16, 2015 at 10:50 AM
    #1676
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
  17. Sep 16, 2015 at 1:28 PM
    #1677
    GWinstead
    GWinstead Well-Known Member
    Haven't checked in here a while, didn't know there was a shortage. Or, rather, none available. Mine was installed in early may. Took it to a dealer out of town, that had experience installing these things. $5700 and change. There really is a substitute for cubic inches.
  18. Sep 16, 2015 at 1:35 PM
    #1678
    littleblue81
    littleblue81 Well-Known Member
    Don't be like that Debbie.
    vlodpg likes this.
  19. Sep 16, 2015 at 2:01 PM
    #1679
    littleblue81
    Clearly.
  20. Sep 16, 2015 at 2:14 PM
    #1680
    FtApache
    FtApache Well-Known Member
    2019 Raptor
    Every since I joined, TW has been encouraging me to drain my wallet. Wrong thread to ask this ?, but here goes
    A) Front and rear ADS MT setup w/ leaf and uca
    B) Supercharger w/ aFe CAI + 2.85 pulley + upgraded fuel pump
