TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Sep 23, 2015 at 9:30 PM
    #1861
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pff. I'm turbo. :p
  2. Sep 23, 2015 at 9:33 PM
    #1862
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
  3. Sep 23, 2015 at 9:34 PM
    #1863
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Our trucks whine...... Tors queefs
    Biscuits and 12TRDTacoma like this.
  4. Sep 23, 2015 at 10:19 PM
    #1864
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    Is this the beginning of the death of this thread??
  5. Sep 23, 2015 at 10:20 PM
    #1865
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Goonies never say it
    Torspd likes this.
  6. Sep 23, 2015 at 11:35 PM
    #1866
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Shit no.
  7. Sep 24, 2015 at 6:08 AM
    #1867
    redsoxcole
    redsoxcole Well-Known Member
    Cary, NC
    2011 TRD Off-Road 4X4 DCSB TRD Supercharged
    TRD Supercharger, 3" lift, 33" AT BFG's, V1 Radar Detector, Python 5906P Remote Start.
    The AT transmission is more then capable of handling the extra HP. With that said most transmission will lag in the low gears when your on the gas. That's not a problem unless you take off aggressive most every time. The reason the transmission is like this is because it is built for smooth shifting. The clutch pack takes its time to engage which creates more heat. So by getting into the gas more often leads to more heat on the clutch pack which will burn up. Unless you are drag racing most days you will not have a problem.
    Konvict KROG likes this.
  8. Sep 24, 2015 at 6:34 AM
    #1868
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    What fun is having a SC & not driving it like you stole it?
    Ninj and Konvict KROG like this.
  9. Sep 24, 2015 at 6:57 AM
    #1869
    redsoxcole
    Cary, NC
    If that's how you like to drive 95% of the time get the valve body upgrade kit. At that point you will have close to a Tundra transmission in a Tacoma.
  10. Sep 24, 2015 at 7:04 AM
    #1870
    vlodpg
    Connecticut
    I run a 6 speed
  11. Sep 24, 2015 at 7:36 AM
    #1871
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    Stock clutch blows!
    Or I have a faulty one. It started slipping at about 8k miles. Hasn't been smoked a single time. But it is intermittent. I believe it has a weak pressure plate. Some days it doesn't do it others it does it all the time.
    My 2013 had 25k on it with no issues.
    At the point the clutch in my 81, that was extremely abused outlasted it. It is still good, has 10-15k or so since I installed it in 2010. I never expected it to last more than a season as a play truck and it kept going.
    I took it to Toyota, where they said they could not repeat the issue. Those 2 days were a waste of time. My wife says drive it till it quits and call toyota stranded.
  12. Sep 24, 2015 at 8:01 AM
    #1872
    redsoxcole
    Cary, NC
    As far as reliability the auto and manual are almost the exact same. 10-15 years ago yes there was a difference. Not with these Transmissions.
  13. Sep 24, 2015 at 8:08 AM
    #1873
    Konvict KROG
    Louisiana
    I would have to see real numbers. My gut tells me that these days the auto is a good bit more reliable.
    I 100 percent am biased for the manual and have all manuals myself. The modern toyota automatic may have less gears than a GM but damn they seem to be very reliable. And they get better MPG to boot.
    At the end of the day, I prefer the manual. So even if that ends up costing more.. which is the opposite of years ago. . I will have one!
  14. Sep 24, 2015 at 8:20 AM
    #1874
    redsoxcole
    Cary, NC
    The last two quarters the auto has been slightly better then the manual. For its 10 year cycle they have been about the exact same. Some quarters the manual has a few less customer issues. I work at AW and see this reports from time to time.
    Konvict KROG[QUOTED] likes this.
  15. Sep 24, 2015 at 8:38 AM
    #1875
    redsoxcole
    Cary, NC
    You must be talking about the foreign matter in the clutch disk during manufacturing for the manual. The automatic prone issue is valve body solenoid sticking caused by small cutting chips blocking and jamming the solenoids. Both have about the same occurrence.
  16. Sep 24, 2015 at 9:04 AM
    #1876
    redsoxcole
    Cary, NC
    All are issues for the manual. The Auto has a lot more then you might think. Machining the case, oil pump, and valve body is not easy at all for the auto. Tolerances get as tight as 50 microns on positions. All the 4x4 Tundra's and Tacoma's auto transmissions are machined and assembled here in Durham, NC in case anybody would like to know.
  17. Sep 24, 2015 at 9:08 AM
    #1877
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    This. I do not know a manual owner with a Tacoma over 3 years old that has not replaced the throw out bearing. I think there is some confusion here between people saying the manual is weak and the manual is weaker than the auto on the second gens. Honestly, the manual is definitely strong enough to take the SC and mods because people have taken it there and not had issues. However, the automatic transmission was designed for a higher working load off the bat, and I'm sure the long term failure point for the manual will be higher than the automatic in high output applications simply as a result of design loading.
    In the end I find people here just defend their positions with the same old tired arguments between manual and auto. Good luck convincing someone they picked the weaker transmission on any level. IMHO pick your poison.
    JuanitoBonito likes this.
  18. Sep 24, 2015 at 9:09 AM
    #1878
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    Nope u don't have a faulty one.
    Mine started slipping in 6th right before 6k miles, about 3k miles after having the SC installed and about 1k miles after the 2.85 pulley installed. I have a feeling they're right on the limit with only the SC installed.
    I didn't even bother getting a new factory clutch, I've had a URD Stage 2 clutch in mine since 6k miles and have never looked back. Engagement is even better... bite point is much earlier in the clutch pedal stroke.
  19. Sep 24, 2015 at 9:18 AM
    #1879
    redsoxcole
    Cary, NC
    Important point to keep in mind is most people do not drive and manual the right way. I lot o thosef issues come from people not knowing how to shift in a manual. I am basing my info on the quality reports we get in.
  20. Sep 24, 2015 at 9:23 AM
    #1880
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    "The manual didn't break itself, you need to learn how to shift."
    That is definitely a very dealership friendly response, no offense. Please explain to me why I know of people with high end sports coupes, old Dodge diesels, and heavy trucks that shift those just fine and yet have throw out bearing failures fairly early in the Tacoma trucks life. I'd love to hear Toyota's official opinion is that they are too rough on the Tacoma transmission with their shift pattern :D.
    This is almost like Toyota's explanation of why WS fluid is better than anything else in the auto, even though it's be proven to basically be a cheap fine dodging fluid.
    Konvict KROG and stempsons like this.
