TRD supercharger availability update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 12, 2015.
  1. Sep 24, 2015 at 2:04 PM
    #1941
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Ah, so I was right, it's a measurement that compensates for the extra mass of air by referring to the compression level as if that air was all at 1 atm. So basically saying that at 6 PSI our engines are getting close to a flat line number that may or may not apply. Like I said, the Ford Ecoboost 2.7 L is damn near pushing 30 PSI which would be an insane effective compression number. Then again, that engine was designed from scratch for those pressures and combustion volumes.
  2. Sep 24, 2015 at 2:13 PM
    #1942
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I'm sure a little TLC will fix that
  3. Sep 24, 2015 at 3:01 PM
    #1943
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    That'll buff out, I fail to see the issue. Its a toyota, you'd still win the race and drive it home.
    Biscuits likes this.
  4. Sep 24, 2015 at 3:53 PM
    #1944
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
  5. Sep 24, 2015 at 3:57 PM
    #1945
    Konvict KROG
    Louisiana
    BlueT in his weekend warrior says 30 psi is for girls
    WICKED 150 PSI BOOST CUMMINS DIESEL PRO MOD PULLE…: http://youtu.be/XAIHPzuqSc4
  6. Sep 24, 2015 at 4:20 PM
    #1946
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    His weekend warrior is a LC. I think that is actually what people call his "phantom penis" :D.
    Konvict KROG[QUOTED] likes this.
  7. Sep 24, 2015 at 4:29 PM
    #1947
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Did Foampile ever get his engine back together and running?
  8. Sep 24, 2015 at 6:38 PM
    #1948
    ThomasMore66
    Dallas/Fort Worth & Durango
    And this is why I hang out here b
  9. Sep 24, 2015 at 8:25 PM
    #1949
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    That's not surprising. His first thread basically middle fingered several mods and praised BlueT. You know when that happens there is a ban in your future.
    Konvict KROG likes this.
  10. Sep 24, 2015 at 8:48 PM
    #1950
    ThomasMore66
    image.jpg They're about to hate me over on Post Your MPG... Thanks V.
    Maybe I'll repost the racing vid that Lobster posted over on the MPG thread.
    Rock Lobster likes this.
  11. Sep 25, 2015 at 5:46 AM
    #1951
    redsoxcole
    redsoxcole Well-Known Member
    Cary, NC
    2011 TRD Off-Road 4X4 DCSB TRD Supercharged
    TRD Supercharger, 3" lift, 33" AT BFG's, V1 Radar Detector, Python 5906P Remote Start.
    Effective Compression Ratio (ECR). It basically accounts for boost
    (sqrt((boost+14.7)/14.7)) * CR = ECR
    sqrt = square root
    boost = psi of boost
    CR = static compression ratio of the motor
    ECR = effective compression ratio
    Torspd[QUOTED] likes this.
  12. Sep 25, 2015 at 6:47 AM
    #1952
    Konvict KROG
    Louisiana
    So I had an ECR of 14.28 in my supercharged corolla, it ran like a beast tuned on 93.
    Problem came when I moved to a new state, and only had 91 with octane booster. Then I shit out the bottom end.
    That car was a 1zzfe, 10.5 compression with 12.5 boost. 5 large injectors etc.
  13. Sep 25, 2015 at 7:01 AM
    #1953
    Konvict KROG
    Louisiana
    Also with the TRD supercharger stock I get ECR of 11.86
    TRD supercharger plus 2.85 pulley I get ECR of 12.56
    Personally, and I am by no means an expert. Considering 93 octane fuel and a pig rich factory tune. 12.56 doesn't sound bad to me. I think its close to the limit, but not drastic.
    Of course there are many people running that pulley and I have not seen any issues because of it, so its just a confidence boost :)
    also, I can't speak knowledgeable on it but I know there are differences in the way static compression ratio and effective compression ratio applies.
    I know 12.7 worked in a sohc honda motor on pump gas, but 12.7 is super high in the 22r.
    And I know that mazda cars with skyactive can have up into the 14s for effective compression ratios while their static ratio is not nearly that high.
  14. Sep 25, 2015 at 7:38 AM
    #1954
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    It's all in the intake, cylinder and fuel injection design. Not to mention the shape of the cams, the timing, the injection timing, yadda yadda yadda. That's why we see new engines every few years. The improvements in efficiency and pushing the knock resistance continues on. That 2.7 L Ford engine makes it's power with regular gas even though it's effective compression is insane at WOT.
  15. Sep 25, 2015 at 7:47 AM
    #1955
    Konvict KROG
    Louisiana
    Definitely. I am smart enough to know I am not educated enough, but I have a rough idea haha.
    The 22r is just old basically, the honda has a smaller bore, more efficient everything and plays better. The skyactive is modern.
    The 1gr, is probably very close in tech to the 1zz.
  16. Sep 25, 2015 at 7:55 AM
    #1956
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yeah, it's funny how quickly technology becomes old. Just yesterday I found my old 2004 Alero still driving around town. I found that car plenty powerful with the LA1, for what it was, and yet it only made 180 HP and 200 ft lbs of torque. Now I could go buy a Ford Fusion and the sub 2.5 L I4 engines in that car make the same amount of power and the V6 of similar displacement to the Alero makes 240 HP and 270 ft lbs of torque....
  17. Sep 25, 2015 at 8:52 AM
    #1957
    redsoxcole
    Cary, NC
    I am just the type of guy that likes the details of things before I take peoples word that you can add 30psi with no problems. Looking into the eco boost the truck runs stock at 12.5 psi. ECR of (13.6:1). They can bump it up to 29psi and get a ECR of (17.24:1). That's around top fuel dragsters! No idea how they pull that off.
  18. Sep 25, 2015 at 9:02 AM
    #1958
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Ford has put something like 5 million man hours of research into the Ecoboost engines. I'm guessing that's how. They know more about turbo's now than most companies know about their naturally aspirated engines.
  19. Sep 25, 2015 at 9:08 AM
    #1959
    Konvict KROG
    Louisiana
    Now all we need is a global market ranger with 5.0 ecoturd in the us. I would buy it.
  20. Sep 25, 2015 at 9:13 AM
    #1960
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    ^600 HP Ranger... that thing would literally fly apart I'm sure.
