TRD Supercharger/CAI for 2015 Tacos??
Discussion in 'Performance and Tuning' started by Adrian's Taco, Feb 17, 2016.
  1. Feb 17, 2016 at 1:02 AM
    Adrian's Taco
    Adrian's Taco [OP] New Member
    Adrian
    2015 6 Spd TRD Off-Road
    Is there a TRD supercharger and cold air intake available for 2015 tacomas?? Ive been doing some research and only find them up to 2011... Ive found more recent ones for Tundras, FJs, and 4Rs but don't know if any one of these are compatible w/Tacos. Any info would be greatly appreciated. Thanks!
  2. Feb 17, 2016 at 9:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Pavlik1988 and Adrian's Taco[OP] like this.
  3. Feb 17, 2016 at 10:30 PM
    Adrian's Taco
    Adrian
    Thanks for the info/welcome crashnburn. Any input on the TRD cold air intake?
  4. Feb 18, 2016 at 8:33 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Admittedly I do not pay much attention to CAIs, as I don't see much value. I believe there were 2 TRD CAIs for the 4.0 Tacoma, and older design and newer one. I recall the older one being better than the newer model, but do not recall the specifics. Without the supercharger, you are just going to get noise and a couple hp near redline that will be unnoticeable in daily driving. Not worth the money.
    Adrian's Taco[OP] likes this.
  5. Feb 18, 2016 at 8:55 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
  6. Feb 18, 2016 at 12:24 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You'll have to track down a supercharger, and the current TRD CAI is worthless. The AFE CAI's are pretty good. Without an SC, youll get some extra noise and maybe a hair of HP. With forced induction you get alot more gains.
  7. Feb 18, 2016 at 8:32 PM
    Hunter223
    Hunter223 Member
    Hunter
    2015 Toyota Tacoma
    K&N CAI and Flowmaster Dual Exhaust
    Some dealerships still have the TRD supercharger. They are trying to sell the rest of them off. As for a cold air intake i highly recommend the K&N aluminized steel cold air intake. Sounds amazing and you can feel a difference. Definitely worth the money and they come with a million mile warranty. Couldn't be happier with the system. I installed it in 2 hours with basic tools. They are on Amazon for around $300 or a cheaper plastic model for $250. But once again a lot of dealerships still have the superchargers for sale. Im about to install one in mine before they all go.
  8. Feb 18, 2016 at 9:00 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW.
    Your info regarding the superchargers is way off. People have hunted for them for a very long time and been unsuccessful. Dealers will say they have them in stock to take your order when in fact they do not and cannot get them. Even if you do find a supercharger, you still need the fit kit. Which is like trying to find a unicorn on the dark side of a moon, off of pluto while wearing a blindfold. Your best bet now is to order one of the Magnuson units.
    Here is the thread to track down and locate all known superchargers and fit kits:
    https://www.tacomaworld.com/threads/trd-supercharger-availability-update.377700/
  9. Feb 18, 2016 at 9:10 PM
    Hunter223
    Hunter223 Member
    Hunter
    2015 Toyota Tacoma
    Thank you, they said they had superchargers but i never asked about the fit kit. I'll look into the Magnuson units!
  10. Feb 18, 2016 at 9:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Funny. That link is dead. Are they pulling the plug on the Magnuson 4.0 blowers now? I would like to see whst kind of tuner they are going to be utilizing. I'd like to pick one up for my truck instead of using this filthy rich stock tune.
  11. Feb 19, 2016 at 8:38 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    First hit on google is dead too. But this one works:
    http://www.lceperformance.com/PRE-ORDER-Supercharger-Assembly-4-0L-1GR-FE-p/7015240.htm
    Nah, just do ALLTHEMODS to lean out the tune.
  12. Feb 19, 2016 at 10:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  13. Feb 19, 2016 at 10:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Don't have gauges yet, but was thinking 2.85 pulley, plus CAI (both known to lean) plus maybe URD crossover plus catback to see what the numbers would come out to be. Will take me a while to get there though as sliders need to come first.
  14. Feb 21, 2016 at 7:21 AM
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    I was thinking the exact same thing about the tune
    12TRDTacoma[QUOTED] likes this.
  15. Feb 29, 2016 at 6:14 PM
    Pavlik1988
    Pavlik1988 Well-Known Member
    Pavel
    Chicago
    2015 Toyota Tacoma TRD Sport 4X4 V6 SC
    modified
    probably magnuson blovwer will break the factory worranty
  16. Mar 3, 2016 at 6:20 PM
    Pavlik1988
    Pavel
    Chicago
    modified
    how many HP on the wheel had TRD supercharger? i didn't find where is 304hp came from, engine or wheel
    Because Magnuson shows around 290hp on the wheel (with 5.3 boost)
  17. Mar 3, 2016 at 6:29 PM
    Pavlik1988
    Pavel
    Chicago
    modified
    looks like same sh..t, just from other side! 305 on the crank, transmission waste 15hp, ad we have 290 at the wheel
    it is gonna be the same blower, just 2k more ($5,995) and no worranty . it is sad(
  18. Mar 4, 2016 at 5:39 AM
    Vassily28
    Losses are closer to something between 15 and 20 %. On a 4WD i think the OEM 236 hp has been dynoed at 191 WHP. So on a 4WD parasistic losses trough AT, TC and differential is close to 20%.
    Pavlik1988 likes this.
