TRD Supercharger increase MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner32, May 31, 2012.
  1. May 31, 2012 at 11:56 AM
    prerunner32
    prerunner32 [OP] TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    Does a TRD supercharger increase MPG? Ive heard yes and no. I am in the condition to posibly aquire one. Just a little worried what the MPG's will be. I know a few of you guys have them so what are you getting??? Im getting about 17-18 city and 22 highway right now but I am stock. I will be getting Camburg Coilovers and leveling my truck with 285's soon. I know that will kill my MPG just thinking maybe a TRD Supercharger would bring it up a little.
    THANKS!!!
  2. May 31, 2012 at 12:05 PM
    Brandon9402
    Brandon9402 uncoordinated dirtbox
    Brandon
    Mississippi
    02 prerunner sr5
    Kenwood headunit, 4 kicker 5x7 coaxials,2 memphis 1.5" tweeters, 2 12" memphis subwoofers, memphis 500w amp, chrome grille guard, kc fog lamps, chrome side steps, chrome tool box, and window visors
    i seriously doubt any kind of forced induction would raise mpg. my taco is n/a and never had anything else, so im no expert, but im like 99% sure its going to drop. and probably a good bit. From my past research iirc supercharger spins off of engine power and pulls more air in through the intake. this requires some tuning to get the air/fuel ratio fixed so then your forcing in more air which requires more fuel per cylinder. but like i said im no expert i could be dead wrong lol
  3. May 31, 2012 at 12:06 PM
    Aw9d
    Aw9d That one guy
    You will loose MPG's with an SC.
  4. May 31, 2012 at 12:07 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    It might but even if it does you will never see it. You'll be too busy enjoying the BRAAAAAAAAAAAAAAP! Whats the point of having one if you aren't going to floor it everywhere you go :)
  5. May 31, 2012 at 12:07 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    7/10 times you'll get a drop. But if you're good with the skinny pedal you can use the extra power to your advantage and see a bit of an improvement. That being said $2500-$5000 buys quite a lot of gas.
  6. May 31, 2012 at 1:49 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    with that setup no, and not even with the supercharger. you'll be getting about 17mpg as what i've been reading.
  7. May 31, 2012 at 2:01 PM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    IMO, if you want boost, MPG is not a concern. A SC uses your engine to turn the screw, so there's parasitic loss. Think of that kinda like an additional AC compressor. It's going to drag on your engine. That said, there's probably some efficiency of getting the increased compression. But let's just throw all that out, because if you want more power, your foot will want to play. No one buys boost to granny it around all day. You will want to hear it. And the gas will burn!
  8. May 31, 2012 at 3:16 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    Other than the SC, my truck is stock, I drive the speed limit and I still average 20-21.2 mpg per tank, same as before the SC. Passing and accelerating onto the freeway doesn't last more than 5 seconds or so, so I'm not sucking down any serious fuel.
    OldManTacoFeels likes this.
  9. May 31, 2012 at 3:44 PM
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    Ive got a supercharger on my 1st gen. I only paid 600 bones for it. But anyways my gas mileage is a tad better but only if I keep out of WOT. I avg about 22 mpg on 32's I got a litle less then that without the SC. But I also drive my truck easily as well.
  10. May 31, 2012 at 3:48 PM
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    HAAHHAHAHAHAHAHAHAHAHAHAHAHA
  11. May 31, 2012 at 4:20 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    I have increased my mileage on the freeway it makes the engine more efficient and doesnt downshift going up inclines...people who says it drops considerably dont have one to tell you....in the city if i stay out of boost its the same but if im in boost it drops so its all in all how you drive it....
  12. May 31, 2012 at 4:22 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    My S/c increased my fuel economy by about 1-2 mpg's, when I'm driving economically. It decreased them radically when I hit pedal to floor
  13. May 31, 2012 at 6:42 PM
    Uplander
    Uplander Active Member
    Idaho
    2012 Barcelona Red DCLB Sport
    TRD Supercharger, URD 2.825" Pulley, TRD Exhaust, Moroso Catch Can, MB Chaos Wheels, 265/65/17 Hankook Dynapro's, 5100's @ .85", ARE MX Topper W/BedRug
    20 mpgs on my last fill up. Mostly freeway driving. The tank before that was 19 and that was doing some test runs in the hills after adding the URD pulley. The truck never downshifts on the freeway, even on some steep grades which I like. I've been boosted since leaving the dealer, so I cant say what the mpgs would be without the s/c, but I'm extremely pleased so far.
  14. May 31, 2012 at 7:28 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Yes it will give you twice the horsepower and half the miles per gallon.
    Ak-47 likes this.
  15. May 31, 2012 at 7:56 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Most people I have talked to (including myself) loose about 1 MPG.
  16. May 31, 2012 at 9:53 PM
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    thats a big fat NO.
    my 2001 had a SC and it lowered my MPGs considerably. With all things realistic....The thing is that you inevitably gas it harder and more often with the SC, you won't be be able to help it as much as you think you will, so there alone your suffer. Then when you do take it super easy, the best i saw was 19mpgs when i used to get 21, so loose even when you focus on getting the best.
  17. May 31, 2012 at 11:18 PM
    prerunner32
    Alan
    Foothill Ranch
    See this is what I am talking about. I understand why it would decrease MPG but then there are some people who have it that says they now get better. That is what baffles me! Maybe the efficiency at 2k-3k rpm is better but anywhere else its worse.
  18. Jun 1, 2012 at 2:05 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Honestly, its going to vary from everybody you will ask. My MPG varies from 16.5-18.5. That's the same mpg's I was getting before I put the s/c on, so for me it didn't change. It basically comes down to how you drive end of story.
  19. Jun 1, 2012 at 3:17 AM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    I had a slight decrease around town and my highway stayed the same.
  20. Jun 1, 2012 at 5:07 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Keep in mind that if you just ask people what their MPG is bone stock (non-supercharged), you'll get a range of about 10 MPG. Put a supercharger on the same field of people, the ones getting great MPG because they're driving responsibly will do even better, the more aggressive drivers will lose even more MPG.
    Krazie did say it best though, if you're buying a $3,500 supercharger for better fuel economy, you're wasting your money.
