TRD Supercharger increase MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner32, May 31, 2012.
  1. Jun 1, 2012 at 5:11 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I have seen an increase in my milage SOMETIMES. It all depends on how I drive. Generally the milage has stayed about the same though.
  2. Jun 1, 2012 at 5:50 AM
    triumphx
    triumphx Well-Known Member
    Austin, TX
    X-runner/cummins
    Go with a turbo and you will see better mpg as long as you stay outta boost as much as possible. The more boost=worst mpg
  3. Jun 1, 2012 at 6:28 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    If I had to make an educated guess I'd say my increase in MPG's has a lot to do with my elevation also, I live at 1100 feet.
  4. Jun 1, 2012 at 6:33 AM
    triumphx
    Austin, TX
    X-runner/cummins
    Not quite as the blower will build boost at pretty low rpms and throttle, with turbo you can shift in lag before boost even thinks about building
  5. Jun 1, 2012 at 6:35 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    A proper bypass valve prevents any and all unwanted boost from building pressure
  6. Jun 1, 2012 at 6:40 AM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    No, you would have to be really into it to build boost in low RPM's.
    I monitor my vacuum/boost and the only time I switch over to boost is if I am really getting into it. But if you floor if from every light, you would be correct.
  7. Jun 1, 2012 at 6:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    A local member was running a supercharger (I think the TRD) and was pulling 22 - 23 MPG on the highway. His truck had a 3" lift and 33's, stock gears. He did say he had to be careful with the skinny pedel though because 22 could turn into 12 very quickly. We're at a fairly low elevation.
  8. Jun 1, 2012 at 7:08 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  9. Jun 1, 2012 at 4:23 PM
    prerunner32
    prerunner32 [OP] TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    Yea I agree. I also agree with the elevation part too. I myself am at sea level. And I would be getting it for WAY less than $3500 :) I wouldnt be getting it for MPG I am just trying to factor in everything before I make a decision. I would be getting it for more the increase in hp and tq. I do tow hear and there and also its just nice to have something that can haul the mail! I was just looking at all pros/cons.
    It seems like in the overall, you get about the same. But some people loose more cause its just to much fun to play around with. And some people gain more cause they drive like grandmas ;)
  10. Jun 1, 2012 at 9:49 PM
    Thundjet
    Thundjet Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    Think about it for a minute. A SC forces more air in your engine which requires more fuel. Do you really think for a minute you can keep your foot out of it and have better fuel economy than stock? Ain't gonna happen. If anyone says it does they are lieing.
  11. Jun 2, 2012 at 7:39 AM
    Pugga
    Massachusetts
    It's no where near that simple and yes, you can get better MPG than stock with a supercharger. That kind of over simplistic logic doesn't apply and is not accurate.
  12. Jun 2, 2012 at 7:56 AM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    Overall my mileage hasn't changed.
    I am doing lower RPMs on hills, and it rarely shifts
    down to 4th.
    At the most I am in boost conditions for a couple seconds
    during a drive. When pulling the boat trailer that is a different
    story. Drinks the gas but good power.
    As everyone else has mentioned, totally depends how you
    drive. It is very easy to get horrible mileage if you like speed.
  13. Jun 3, 2012 at 1:02 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    You don't have one so you wouldn't know....like I said it makes the engine more efficient if you stay out of boost...nuff said or you can go out and buy one and see for yourself :)
  14. Jun 3, 2012 at 4:45 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If you putted around like a Grandpa you probably would see a slight increase in MPG- But who buys a SC to drive like a Grandpa and putt around? :cool:
    ricantaco likes this.
  15. Jun 3, 2012 at 11:08 AM
    #35
    DevL
    DevL Well-Known Member
    On the highway...
  16. Jun 3, 2012 at 11:14 AM
    #36
    DevL
    Also consider this... stock engine tuned for regular. S/C tuned for and requires premium. So yes it will not only get better gas milage under 2000 rpm, but enough to counter parasitic drag and gain 1 mpg. However more power = more fuel and ecomony drops. The extra cost of premium eats up the 1 mpg gain. Inevitably you end up losing about 1 mpg and having to use premium fuel.
  17. Jun 4, 2012 at 4:50 AM
    #37
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    I've never seen anywhere near 20 mpg even stock. Best I got stock was 16-17,now with the SC (which is awesome by the way) if I drive like grandpa I get like 15 with mixed driving which is incredibly boring...If I drive how I want to I get 12-13; I never bought the SC expecting to gain mpg, I bought it expecting to have fun :) FWIW, I have 275/70/17 BFG TA KO's and a 3" lift.
    Expect to lose mpg for sure
  18. Jun 4, 2012 at 6:12 AM
    #38
    D4D Hilux Dude
    D4D Hilux Dude Well-Known Member
    Darren
    Arvada, CO
    2011 4x4 Double Cab TRD Offroad
    TRD Supercharger TRD Catback Exhaust Ziebart Rust Proofing Additional Bed Ties 2012 Indicator side mirrors
    My MPGs did not change after the SC was installed.
    MPGs are affected by how heavy your right foot is. I experimented a bit and got higher MPG if i did not cross 2500 RPM. I don't have the exact figures on me right now, but It was a lot more the typical everyday use of the heavy foot.
    Although.... the S\C is fun to use :D
  19. Jun 14, 2012 at 3:01 PM
    #39
    michaelg589
    michaelg589 Well-Known Member
    Obviously when you think about air/fuel ratios, one might think the result of adding more air to the combustion chamber means adding more fuel, and thus, worse MPGs. Yes more air means more fuel. That's why cold weather MPGs suck. The air is more dense and your engine is using more fuel to keep the ratio even.
    But boost can absolutely increase MPGs. Especially a turbo. A supercharger has the draw back of adding more work to the engine before it gives it more power. But for some comparison, a 2002 Pontiac Grand Prix GTP (supercharged 3.8 liter V6) can AVERAGE 30 mpg and have as much as 260hp and 260lb./ft. when WOT. A 2008 Saturn Sky redline (turbocharged 2.0 liter 4 cyl.) Can Average 32 mpg and have as much as 290hp and 340 lb./ft..
    Its all about how one drives. Adding boost will make MPG exponentially worse when you put your foot down hard. But under normal, casual drivng, MPGs can increase because the engine isn't having to work so hard. Hell the 2013 Mustang GT500 gets mid 20s on the highway WITH 662 HP!
  20. Nov 28, 2012 at 2:40 AM
    #40
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    no there is a fuel air ratio that your truck allways tries to keep the same for proper combustion I cant remember the exact ratio right now but with a supercharger you are increasing the air ratio so in order to keep the ratio correct it has to feed more fuel, it is basic gas or diesel engine dynamics for proper combustion. but it is not a whole lot, you may suffer more from having to use high octane fuel to prevent engine knock or ping. so in stupid terms more air means more fuel. but if your a lover of horses I think its good .
