TRD Supercharger install today!Is there a stock looking Pulley?
Discussion in 'Performance and Tuning' started by jarhead0313, Aug 13, 2012.
  1. Aug 13, 2012 at 8:18 AM
    jarhead0313
    jarhead0313 [OP] Well-Known Member
    Portland, OR
    2017 TRD ORDC LB 4X4
    So dropped my baby off to have the dealership install the supercharger. I purchased the URD pulley but it is red. 1. I was wondering if anyone knows of a 2.85 pulley that looks stock as not to raise question when I take my truck in for service. 2. This weekend I had planned on putting on my DTLT headers and was wondering if they could deny warranty claims on the supercharger cause of the cats delete?
    Input much appreciated!
  2. Aug 13, 2012 at 8:23 AM
    jarhead0313
    Portland, OR
    I looked on there site and have not seen them. Do I just call Gadget?
  3. Aug 13, 2012 at 8:29 AM
    jarhead0313
    Portland, OR
    What about headers and the supercharger warranty? Is there a break in period on the supercharger?
  4. Aug 13, 2012 at 8:31 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Congrats on the supercharger addition!!! I believe APR carries the 2.8 stock looking pulley. URD did but I know they were out of stock. You'll be losing your front cats when you install the headers and I don't think that will fly with your dealership with your truck under warranty. Do you have an O2 sim to keep the the CEL light off?
  5. Aug 13, 2012 at 8:35 AM
    jarhead0313
    Portland, OR
    Ya I got the sims when I ordered the headers. So are your saying they could void my warranty on the supercharger because of the cats delete.
  6. Aug 13, 2012 at 8:37 AM
    jarhead0313
    Portland, OR
    Is there a major difference from the URD version vs the APR version of the pulley?
  7. Aug 13, 2012 at 8:42 AM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    the urd one is red, the apr ones are the stock looking ones but they are hard to come by now.
  8. Aug 13, 2012 at 8:53 AM
    jarhead0313
    Portland, OR
    I guess i will call gadget and see what he says. Thanks for the input.
  9. Aug 13, 2012 at 8:57 AM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    sorry for the blank response, the urd one is 2.825" and can be installed by you with a pulley puller and a press tool which gadget sells. His pulley looks a little different and is red anodized. The apr one is 2.85" and looks identical to stock, same removal and install as urd. Apr also offered a 2.7 pulley and a small batch of 2.6 pulleys. Those both required machining of the snout to allow for the smaller size pulley for clearance. I have the urd 2.825 on mine, well worth the money.
  10. Aug 13, 2012 at 10:29 AM
    jarhead0313
    Portland, OR
    Just talked to Gadget at URD he said they are out of stock and will be a couple months before they have more stock looking pulleys made up. I guess red it is!
  11. Aug 14, 2012 at 9:40 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Not necessarily void, but removing cats on a brand new vehicle and then if you happen to throw a code related to emissions or o2 sensors etc.. the dealership most likely will give you a hard time - especially with the charger. Also, keep your cats and stock headers just in case.
    Are your headers the second Gen doug thorleys. If not get the collectors welded with bungs so you can move your WRAF sensors. Get the WRAF extensions from Gadget. Do it before you install, it's one of those "do it right the first time" things. I'm actually pulling my headers off today to get welded, (wish i didn't have to, driver side pain in the ass).
    Biscuits likes this.
  12. Aug 14, 2012 at 11:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you haven't installed the ARP header studs, then just remove the top and bottom studs closest to the firewall. Will make life so much easier.
  13. Aug 14, 2012 at 1:17 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Can you clarify? Is this before reinstalling headers?
  14. Aug 14, 2012 at 1:31 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There are 6 studs on the head, which hold the header to the head. When you unscrew the nuts, use I believe a 6mm socket, to rachet out the rear two studs. Top and bottom. The ones closes to the firewall. Doing so will give you more clearance.
  15. Oct 10, 2012 at 7:26 PM
    Budokai
    Budokai Active Member
    Winnipeg
    2013 dbl trd with leather
    At Tires/running boards/skid plate/tonneau/bon jovi and hood deflector.
    Outlaw made a comment about the pulley being well worth the money.. as i have just got the sc installed and am in process of getting doug thorley headers/y pipe and dual exhaust done..a few questions if i may.
    Is the pulley difference noticeable?( i havent run a dyno yet )
    and have you had any problems with over taxing the engine transmission ect.?//This is my daily driver and i cant afford for it to be in and out of the shop?.
    everything ive done is still covered by warrenty (went shorty headers to keep the cats) so dont want to lose the protective feeling i currently enjoy with the extended warrenty i bought for 2k .
  16. Oct 10, 2012 at 8:09 PM
    jarhead0313
    Portland, OR
    The pulley woke up the charger quite a bit. I have no dyno #'s yet, as far as the warranty it voids the SC. I am currently running all my mods on my trd reflash and have had no problems. My truck is my daily driver as well. I have the toyota tow package from factory so I havnet worried sice I have the transsmission cooler. I know that URD is making a stock looking pulley that wouldn't draw attention to its self, but last time I checked they were a couple months out and I didnt want to wait. Check out my other thread, lots of good info there and soon will have some dyno runs up.http://www.tacomaworld.com/forum/pe...ave-trd-supercharger-installed-mods-dyno.html
  17. Oct 11, 2012 at 4:30 AM
    Budokai
    Winnipeg
    Thank you for the reply I also have the trd tow package so.......where's my visa gone...will post dynos after final build.
    dbs1 likes this.
  18. Dec 4, 2012 at 11:40 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Wow, that looks like an unusual amount of low and simple parts in order to accomplish this swap!
