TRD SUPERCHARGER PROBLEMS.
Discussion in '1st Gen. Tacomas (1995-2004)' started by neegdogdig, Apr 26, 2013.
  1. Apr 26, 2013 at 2:41 AM
    neegdogdig
    neegdogdig [OP] Untrained with bad experiences go go go!
    Central CA
    1st Gen DC V6 5Spd
    HELLLLLLLLLLLLLLLLLP PLEASE!
    MY TRD SUPERCHARGER IS HAVING SOME LEAK AT THE NOSE DRIVE AND
    I DON'T KNOW WHAT IS WRONG WITH IT:confused:.
    IS ANY OF YOU GUYS HAVE THIS ISSUES ON YOURS? AND WHAT YOU DO TO
    CORRECT THE ISSUES I WOULD LIKE TO KNOW. YOUR INPUTS ARE APPRECIATED, THANKS.
  2. Apr 26, 2013 at 3:08 AM
    2011supercoma
    2011supercoma Well-Known Member
    capt. schyler
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts woth rigid industry D2 spot lights,
    first or second gen? how many miles on the trd sc?
  3. Apr 26, 2013 at 6:56 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    If I recall correctly the first gen blowers(grey) had a problem with the nose cone cracking and leaking. If that's not the issue or you have the second gen(black) then the gasket that seals the nose cone to the blower is leaking. Either way, I think you might have to pull it off.
  4. Apr 26, 2013 at 12:05 PM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
  5. Apr 26, 2013 at 11:14 PM
    neegdogdig
    Central CA
    1st Gen DC V6 5Spd
    i was thinking the nose seal might turn old and cracked may be its time to replace with new seal.
    but anyone know what kind of tools to use to remove the bolt from the nose? or to take it apart?
  6. Apr 27, 2013 at 12:30 AM
    neegdogdig
    Central CA
    1st Gen DC V6 5Spd
    not too sure but look like second gen. color is black and it's 81k on the sc.
  7. Oct 24, 2014 at 11:36 AM
    Pachacuti
    Pachacuti New Member
    Tucson
    03 Tacoma 4x4 TRD SuperCharger
    MT wheels Running Boards Lifts
    I have 80,000 miles on it and am wondering what maintenance I need to do on the Grey colored SuperCharger . Oil change ? How? Can I do it without removing it? I have no problems yet but I see some evidence of oil on the hood above the SuperChanger. :(
