TRD Supercharger program discontinued
Discussion in 'Toyota Trucks & SUVs' started by Spvrtan, Jun 1, 2015.
  1. Jun 1, 2015 at 11:29 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    This makes me sad. I've been been dreaming of blowing 4+ grand on this someday.
  2. Jun 1, 2015 at 11:29 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    It's about what I expected from 300 HP in a Tacoma. I think some people expect the truck to fly or something. I just wanted the grunt I was missing from my past V8 trucks. The S/C gave me that back and a little more.
  3. Jun 1, 2015 at 11:30 AM
    Yota64
    Yota64 Professional Threadjacker
    Where do you use yours? Did you buy it for daily driving/adventures or for going to the track?
    I've always assumed that's what was wrong. Lol
  4. Jun 1, 2015 at 11:31 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Devin just buy one..
  5. Jun 1, 2015 at 11:33 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Mine stayed in boost during towing. At cruise the bypass is supposed to open and does for me when I'm not loaded. Load the engine enough though and the flap closes a bit, leading to boost. The main thing that helps when towing with the S/C is off the line performance. I can actually accelerate reasonably with a 5000lbs load on my truck. Stock I couldn't do that.
    I get about the same mileage I did before I got the S/C. Then again I do about equal parts city and highway. If someone did all city or stop and go alot I could see mileage dropping off a ton.
    URD is better if you want to go fast or make maximum HP. If you are looking for Offroad or off the line performance go with the TRD.
    Yota64[QUOTED] likes this.
  6. Jun 1, 2015 at 11:43 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Daily driving. Why the hell people would take a 4x4 to a track is beyond me. Racetruck lowered to the ground, sure. Truck with tires, tool box, larger tires, etc... just doesn't make sense to me to get a time with that.
    Offroad the TRD S/C does give awesome hill ascent power.
    smaldo76 likes this.
  7. Jun 1, 2015 at 11:46 AM
    Yota64
    I'll send you my routing info K?
    Not to mention they're only going up now... Great
    Okay, I understand now. Sounds like the TRD one is for me though, it would be fun to use offroad and would compensate for any added weight/bigger tires I put on.
    Thanks for the answers guys.
    So are the URD packages linear improvements or specializations? I.e. are you adjusting where the power is or just going up in power each time?
    Also, how do boost and the different URD packages affect the engine life? Christian I think I've heard you say it shouldn't affect it. I'm already at 115,000 miles but this engine is pretty healthy to my knowledge without doing a compression check. God knows what the mileage will be when I have 5-6K to blow. Maybe I can get into a gently used '15 by then.
  8. Jun 1, 2015 at 11:47 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    This is your problem and we all know it...
  9. Jun 1, 2015 at 11:47 AM
    Yota64
    Just trying to justify buying one since I just commute and lightly offroad. Lol
    I knew Christian took his to the track. Torspd's build is also a prime example, although I think if you're going that far you'll want more than the TRD S/C.
  10. Jun 1, 2015 at 11:49 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Potatoes going to potate
  11. Jun 1, 2015 at 11:51 AM
    VolcomTacoma
    Jeff
    NorCal
  12. Jun 1, 2015 at 11:51 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    To be fair Torspd's truck isn't really a 1GR anymore in anything but name! His truck is amazing, but he's done everything to get that truck faster. I can understand the guys that want to do that.
  13. Jun 1, 2015 at 11:51 AM
    T4RFTMFW
    4.0 problems.. :brianr:
    :pout:
    Rock Lobster likes this.
  14. Jun 1, 2015 at 11:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Here's my money.
  15. Jun 1, 2015 at 12:04 PM
    #35
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Well *insert swear word* 3.4 S/C for my 1st gen won't happen. Least a TRD one, but still can get a URD S/C so guess I'm OK with it. Still sucks though
  16. Jun 1, 2015 at 12:07 PM
    #36
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    There will still be Superchargers on the used market. The problem will be finding the odds and ends for them without going to the stealership.
  17. Jun 1, 2015 at 12:10 PM
    #37
    VolcomTacoma
    Jeff
    NorCal
    Which basically means paying the same or more that a dealer would have originally charged. Look at that TRD Supercharger main unit that's been floating around TW for like 4 years now, and yes, I actually almost bought it at one point before a friend told me its not worth it because of the hassle of tracking down all the one time use pieces and odds and ends that get lost on installation and take off. I think this is a kick ass deal that is just landing in URD's lap now lol, but the TRD super chargers will become alot more pricey on the private side I bet
  18. Jun 1, 2015 at 12:13 PM
    #38
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    URD will raise their price if the TRD superchargers go up. Business is business.
  19. Jun 1, 2015 at 12:15 PM
    #39
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Its OK I hear they are developing a TRD turbo setup for the 2016s.
  20. Jun 1, 2015 at 12:16 PM
    #40
    VolcomTacoma
    Jeff
    NorCal
    That's what I'm saying lol. If URD is the only SC on the market, then obviously they can raise prices and make a KILLING until a competitor shows up. Look at Rigid...they had the market cornered for a good year or so until all the cheap chinese bar vendors showed up and other actual competitors started making them on par quality wise.
