TRD supercharger pulleys
Discussion in 'Performance and Tuning' started by US Marine, Apr 7, 2016.
  1. Apr 7, 2016 at 3:43 PM
    US Marine
    US Marine [OP] Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Who has the better pulleys for a 2.7 3RZ motor looking to step up from 4.5psi to 8psi
    The only companies I see are URD or LCE , I'm looking at a 2.4" pulley
  2. Apr 13, 2016 at 9:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Got a link for LCE? I suspect they just resell the URD gear. I'm running the URD 2.85 on the 4.0.
  3. Apr 16, 2016 at 9:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There are reports that the tensioner allows a lot of belt slip. That reconfiguring it for better tension reduces slip and increases psi. As they are also directly related.
