trd supercharger question?
Discussion in '4 Cylinder' started by SargeSlapnuts, Jul 12, 2011.
  1. Jul 12, 2011 at 5:08 AM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    well ling story short i came across a good deal on a supercharger for my 2.7 prerunner. i was curious if installing this kit would compromise the reliability of the truck. also what kind of hit should i expect to take gas mileage wise. i get 18 around town now and 23 on the highway.
  2. Jul 12, 2011 at 5:41 AM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    Forced induction is always harder on an engine, particularly on one not originally designed for it. Many people can go for years without an issue on an aftermarket low-pressure turbo/SC setup but I would recommend planning for the unexpected.
  3. Jul 12, 2011 at 6:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I ran the Alpine unit on my 2000 2.7 for a long time all the while beatigng the poop out of it. I never had an issue and at 110,000 miles, the top end was still within new engine specs. I got about 20.5 mpg all the time.
  4. Jul 12, 2011 at 12:22 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    wait did your gas milage go up because of the s/c kit? or is that just the milage you got?
  5. Jul 12, 2011 at 12:24 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
  6. Jul 12, 2011 at 12:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was getting about 20 to 22 without the SC.
  7. Jul 12, 2011 at 12:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add, I was running over 6 psi, with no mods, or 5th injector. You can modify the FMU to increase fuel delivery as boost comes on with a simple "T" fitting, and running the vacuum lines accordingly.
  8. Jul 12, 2011 at 12:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, Alpine made them, but Toyota put "TRD" on certain units, along with a smaller pully for less boost.
  9. Jul 12, 2011 at 12:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alpine made 3 types for testing. One used a 65" blower unit, and ran 8 psi boost, but required the use of a head spacer (included), another ran a 45" blower unit, and the last one was a 65" blower running 6 + psi (the one I ran). NUKE (from TTORA) ran the 65" with the decompressed head, and I ran the non decompressed head, and someone else got the "TRD" unit....
  10. Jul 12, 2011 at 12:38 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    huh thats cool. so if im getting 18mpgs i should expect to get prolly only 16-17 on low boost. im gonna have to keep in touch with you about this setup cause im still considering installing it. did your kit come with any ecu chips or anything or can the ecu adjust enough to accomodate the s/c and fuel flow?
  11. Jul 12, 2011 at 12:40 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    what is the difference between the unit length in unit and how do i tell cause im going to look at it today and the guy has no idea what it is so im assuming its either a alpine or lce. anyh ways to tell?
  12. Jul 12, 2011 at 12:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You might get better mpg. 16 would be pretty low, and the only time I ever got that was when off roading.
    I cant remember the size, and I never compared it to other units, as it was new at the time, and no one had it.
  13. Jul 12, 2011 at 1:58 PM
    ssmskot
    ssmskot Well-Known Member
    Maine
    '07 Base 4x4
    Soft Tonneau. Tint. Toyota bed mat. K&N Air Intake. 265/75/16 BFG AT's. Sport grille. Weathertechs.
    I think he meant when you referred to it as a 65" blower unit and 45" unit? I'm curious as well actually. Don't know much about them.
  14. Jul 12, 2011 at 2:02 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Your MPG shouldn't change much if your driving habits stay the same.
    The loss will come because it's fun to step on the pedal more.
  15. Jul 12, 2011 at 2:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The type of blower used is called a "posative displacement", or "root" type blower. They are sized in Cubic Inches of impeller displacement.
  16. Jul 12, 2011 at 3:02 PM
    ssmskot
    Maine
    '07 Base 4x4
    Ah ok gotcha. Thanks, that clears it up.
