TRD Supercharger question
Discussion in 'Performance and Tuning' started by tyacrzy, May 26, 2016.
  1. May 26, 2016 at 2:49 PM
    tyacrzy
    tyacrzy [OP] Member
    I have a 96 Tacoma extra cab 5 spd . My question is about a Trd Supercharger with 4 port . Would that work for my vehicle
  2. May 28, 2016 at 4:21 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I don't think any pre 98 tacomas can be s/c'd easily because of ECU restrictions.
  3. Aug 2, 2016 at 5:39 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Check with urdusa.Gadget knows all!
  4. Aug 3, 2016 at 8:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Those would be easier that '09+. X_X
  5. Aug 4, 2016 at 9:10 AM
    micalbertl
    micalbertl Well-Known Member
    1996 Tacoma Sr5 Xtra Cab
    all you need ecu wise for low boost is the ecu out of a 97 Tacoma with same transmission configuration as you (and obviously the 3.4L)
    Fuel wise is a little trickier as the 7th injector kit won't work with these older models for a reason im not 100% on just know is wont work, but URD used to make an upgrade kit that had 6 new pnp injectors and a controller and fuel pump. too bad they have sinced stop selling it so you cant buy from them.
    However it is still possible to find one. granted it will be almost 1k if not more and you will have to do some digging, but it will be easy plug and play ready to go with your new ecu.
    congratulations you now have 300bhp and a very unique truck:thumbsup:.
    sorry if there is more information that I have not provided I have not experienced this I have only done my own very extensive research as I plan to do all the things I listed. How I gave you what you were looking for
    eon_blue likes this.
  6. Aug 6, 2016 at 12:41 PM
    01MUD.TACO.SC.V6
    01MUD.TACO.SC.V6 Well-Known Member
    Clive
    MAXWELL AFB
    01 Tacoma 4WD SR5 Supercharged
    TRD Supercharger, URD 7th Injector Kit, 2" Body Lift, Rear Manual Air Bag Suspension, Marlin Crawler Rear Bumper
    I have a 01, Has anyone had any auto transmission issues with the supercharger?
