TRD Supercharger Questions
Discussion in 'Performance and Tuning' started by Large, Feb 21, 2012.
  1. Feb 21, 2012 at 5:22 PM
    Large
    Large [OP] Red
    If I find one on CL or a used one on eBay, what am I looking for? Kind of a stupid question yes, but what comes in the box so to speak? Thanks for your patience and my ignorance.;)
  2. Feb 21, 2012 at 5:24 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    P/N: PTR29-35070 - MAIN SUPERCHARGER KIT
    P/N: PTR29-35072 - TACOMA FIT KIT
    Item Qty Req’d Description
    1 1 Main Supercharger Assembly with Hardware Bag “B” attached to the coolant nipples at the rear of the intercooler lid.
    2 1 TRD Air Filter (not illustrated)
    3 1 Hardware Bag “C”
    4 1 Hardware Bag “D”
    5 1 Hardware Bag “E”
    6 1 Hardware Bag “F”
    7 1 Hardware Bag “G”
    8 1 Hardware Bag “H”
    9 1 Hardware Bag “I”
    10 1 Hardware Bag “J”
    11 1 Hardware Bag “K”
    12 1 Hardware Bag “L” (White Envelope)
    1 1 Heat Exchanger - Low Temperature Radiator (LTR)
    2 1 Hood Support Bracket
    3 1 Hardware Bag “A”
    Hardware Bag “A” Contents
    1 1 Installation Instruction Manual
    2 1 Reservoir Bracket
    3 2 Rubber Grommet
    4 2 M8X20mm Hex Flange Head Bolt
    5 1 Spacer, .50” Dia X .75” Long
    6 1 M6X50mm Hex Flange Head Bolt
    7 1 M6X20mm Dia Washer
    8 2 Spacer, .75” Dia X .75” Long
    9 2 M8X30mm Hex Flange Head Bolt
    10 1 10 Amp Mini Fuse
    11 1 Ring Terminal, 12-10 GA
    12 12” 5/16” EVAP Hose
    Hardware Bag “B” Contents
    Item # Qty Req’d Description
    1 6 M8 X 35 mm Reduced Shank Hex Head Bolts
    Hardware Bag “C” Contents
    1 1 Tensioner Bracket Assembly
    2 1 5 Rib Belt
    3 1 Smooth Idler Pulley
    4 1 5 Rib Idler Pulley
    5 1 Tensioner Strut Bracket
    6 2 M10 Double Ended Stud
    7 2 M10 Hex Flange Nut
    8 1 M8X16mm Hex Flange Head Bolt
    9 2 Short Spacers
    10 1 Idler Spacer with Groove
    11 1 Idler Spacer without Groove
    Hardware Bag “D” Contents
    1 1 Upper Idler Bracket Assembly
    2 3 M8X20mm Hex Flange Head Bolt
    Hardware Bag “E” Contents
    1 1 Crank Pulley
    2 1 M16X70mm Hex Head bolt
    3 1 M16X48mm Dia Washer
    Hardware Bag “F” Contents
    1 1 Supercharger Support Bracket
    2 1 Air Box Bracket
    3 1 VSV Bracket
    4 2 M6 Hex Flange Nut
    5 1 M6 Washer
    6 1 M6X16mm Hex Flange Head Bolt
    Hardware Bag “G” Contents
    1 1 Thermostat Spacer
    2 1 Water Pipe Spacer
    3 1 O-ring – Large
    4 1 O-Ring Small
    5 2 Spacer
    6 5 M6X55mm Hex Flange Head Bolt
    Hardware Bag “H” Contents
    1 1 Wire/Conn Assembly
    2 2 Adel Clamp, #36
    3 8 Wide Band Spring Clamp
    4 10 Tie Wrap, 7.5”
    5 1 Hose Mender Fitting, ¾”
    6 2 Hose Clamp, #10
    7 1 Adel Clamp, #16-2
    8 1 M6X20mm Hex Flange Head Bolt
    9 1 M6 Hex Flange Nut
    10 2 M6X16mm Hex Flange Head Bolt
    11 1 15 Amp Fuse
    12 1 Fuse Tap-In
    13 1 Female Terminal, 16-14 Ga
    14 4 M6X12 Hex Flange Head Bolt
    Hardware Bag “I” Contents
    1 1 Intercooler Pump
    2 1 Coolant Reservoir with Cap
    Hardware Bag “J” Contents
    1 96” 1” Wire Loom
    2 1 ¾” x 4” x 36” Coolant Hose
    3 1 ¾” x 4” x 60” Coolant Hose
    4 96” ¾” Coolant Hose
    5 1 ¾” Formed Coolant Hose, LTR to Pump Outlet
    Hardware Bag “K” Contents
    1 1 Lower Radiator Coolant Hose (loose in main box)
    2 6 Spark Plugs
    3 6 Fuel Injectors
    Hardware Bag “L” Contents
    1 2 Sticker, TRD Supercharged
    2 2 Sticker, TRD Development
    3 2 Sticker, Premium Fuel Warning
    4 2 Sticker, TRD Red TRD Logo
    5 1 Warranty certificate, TRD
    6 1 Warranty Registration Card
    7 1 Mirror Hanger, S/C Noise
    8 1 Label, Vacuum and Belt Routing
    9 1 Label, CARB D-425-20
  3. Feb 21, 2012 at 5:26 PM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    If you are getting a used one I would suggest changing out the snout oil.
  4. Feb 21, 2012 at 5:30 PM
    Large
    Large [OP] Red
    Good responses so far, one more question for blasphemous, is does that include the fit kit or just the main assembly or both?
  5. Feb 21, 2012 at 5:48 PM
    Blasphemous
    I believe that is both fit and main.
  6. Feb 21, 2012 at 5:49 PM
    Blasphemous
    x2.
  7. Feb 21, 2012 at 6:15 PM
    Large
    Large [OP] Red
    Damn y'all are good.
  8. Feb 22, 2012 at 12:11 PM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    3700 for supercharger and fit kit shipped on usatoyotaparts.com
    Currently the best price new I can find these days. Used will still cost
    you to buy injectors etc
