TRD Supercharger Technical Data?? Snout Oil Change?
Discussion in 'Performance and Tuning' started by 2wheelnut, Mar 17, 2014.
  1. Mar 17, 2014 at 12:10 AM
    2wheelnut
    2wheelnut [OP] Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Does anyone know where to get the actual technical data for the '05 and up S/C? i.e. Rotor RPM @ full boost, pulley ratio. Air displacement HP to run etc?
    Also when are you folks changing the oil in the snout?
  2. Mar 17, 2014 at 10:39 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Mar 17, 2014 at 10:56 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    cant recall what generation MP90 we have, but some generic info is over at magnuson
  4. Mar 17, 2014 at 10:18 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    It is a mp90 with internal bypass and built in liquid/air intercooler. Unknown how efficient intercooler is. Link posted is good info of sc rpm, delta discharge temp (non-ic), psi, inlet cfm, power consumption, ect. Rotor rpm at full boost is hard to determine as full boost will be had at any rpm however that number will change slightly due increasing sc ve and motor ve throughout rpms. Pulley ratio is crank pulley I think 6.5" or 165mm and sc pulley 3" or 76mm. This would make stock configuration 6.5/3 or 2.167. So 2.167 x rpm = sc rpm. At 5700rpm oem rpm limiter and 12, 350rpm sc it takes a little over 30hp to spin. They rate them per link to 14k rpm however they can be ran at higher rpm safely for short periods if case temps are in check. For example I ran the trd sc for the 5vz which is a mp62 rated for 16k rpm to over 19k rpm. A company made/makes 175mm crank pulley for the 1gr, and others make sc pulleys in 2.55", 2.6", 2.7", 2.825", and 2.85". Also there are blower upgrades from steigemier to increase sc output. Plenty of options out there.....
  5. Mar 18, 2014 at 4:39 AM
    2wheelnut
    Angelo
    Vallejo, CA
    Thanks for the info!
  6. Mar 18, 2014 at 4:40 AM
    2wheelnut
    Angelo
    Vallejo, CA
    So do you guys do a post break in snout oil change? Or leave what's in there til 100k miles?
  7. Mar 18, 2014 at 8:00 PM
    trdtoy
    North Carolina
    Whatever makes you feel comfortable..... you can put some mileage on them before needing changed though...
  8. Mar 22, 2014 at 8:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
