TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. May 24, 2016 at 7:08 PM
    #2081
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I have the URD Y-pipe and URD Mark lll exhaust. I believe the spec u is just everything I have in one package.
  2. May 24, 2016 at 7:09 PM
    #2082
    ThomasMore66
    Dallas/Fort Worth & Durango
    No. You can't evaluate it that way. Noise. Seat of the pants. Annoying people. I can't talk on the phone in my truck now. All better.
    GT7[QUOTED] likes this.
  3. May 24, 2016 at 7:11 PM
    #2083
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I think the y pipes are different but the rest is the same
  4. May 24, 2016 at 7:13 PM
    #2084
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yes you correct....the y-pipes are a little different.
  5. May 24, 2016 at 7:13 PM
    #2085
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... My thoughts exactly ... in a single cab, short bed ...:burnrubber:
  6. May 24, 2016 at 7:24 PM
    #2086
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Toyota proved that you can fit the 5.7 V8 in the Tacoma. F the 4.7 you can't even supercharge. I'd either go LS or 5.7 Toyota and supercharge either for 500 hp
    JuanitoBonito and Blacktaco2042 like this.
  7. May 24, 2016 at 8:04 PM
    #2087
    ThomasMore66
    LS FTW. Toyota doesn't understand aftermarket engines.
  8. May 25, 2016 at 1:25 PM
    #2088
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spec-U Y-pipe is equal length.
  9. May 25, 2016 at 1:33 PM
    #2089
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, and then blow the transmission on the 5.7L Toyota engine setup. They can't handle the supercharger setup on them from what I know.
  10. May 25, 2016 at 1:34 PM
    #2090
    VolcomTacoma
    Jeff
    NorCal
    Really? I'd like to beg to differ, but lets ask someone with actual proof.
    @jberry813 Hows that transmission doing?
  11. May 25, 2016 at 1:35 PM
    #2091
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh yeah, he supercharged his huh.
    I hear they are glass once you toss a blower on them.
  12. May 25, 2016 at 1:37 PM
    #2092
    VolcomTacoma
    Jeff
    NorCal
    I hear monster stickers give you 50+ hp and pull hoes as well. But I don't have any substantial proof to that claim either.
    Torspd and cdelgado14 like this.
  13. May 25, 2016 at 1:44 PM
    #2093
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    They completely pulled the 5.7 L TRD Supercharger from the Canadian markets years ago before turfing the whole program. In Canada they had too many warranty issues for failed components caused by supercharging the 5.7 L in Canada. I'm guessing the 5.7 L supercharger is riding a thin line and anything, like tough Canadian weather, is enough to cause a failure.
    Plenty of threads on this can be found via Google.
    Torspd likes this.
  14. May 25, 2016 at 1:56 PM
    #2094
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Don't be dumb Jeff.
    Do you know what transmission they have in them? I'm pretty sure it is the Aisin Warner TB-68LS. If they are, those are only supposed to be good for 500 ft. lbs. of torque. The TRD blower pushes the Tundra's torque up to 551 ft. lbs. So it may be pushing it. I'm going to look because I'm curious now.
  15. May 25, 2016 at 2:27 PM
    #2095
    VolcomTacoma
    Jeff
    NorCal
    I'm not seeing anything on any of the Tundra forums about issues with Superchargers and transmissions. So I'm gonna call BS on that. And guess what, if I was gonna drop in a Supercharged 5.7, I wouldnt put a automatic behind it, but I would make sure my clutch was rated for above the horsepower. So your argument is invalid.
  16. May 25, 2016 at 2:34 PM
    #2096
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    http://www.tundratalk.net/forums/tu...cations/464665-14-15-supercharger-canada.html
    Thread about not being able to get a Tundra S/C installed in Canada. Why would Toyota pull the 5.7 L supercharger but not the other TRD superchargers in those years? I bought my kit in 2014 in Canada and had it installed in Canada in my Tacoma no problem but had a long talk with the dealer tech about the supercharger and he talked about the Tundra Supercharger being discontinued due to a high rate of failure in Canada.
    That suggests, to me anyways, that in cold weather when the supercharger makes just a little extra power something was going catastrophically wrong and Toyota was sick of paying for it. I would suggest that if the 5.7 L supercharger is that finicky here it's likely close to the edge everywhere else especially once you start adding mods.
  17. May 25, 2016 at 2:36 PM
    #2097
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    The accumulators when you pull the trans valve body are plastic. I'd hardly call the transmission glass because of one piece. Every thread I have seen that are blowing through those are running aftermarket tunes and/or smaller pullies and/or aftermarket shift kits. Even with that, there's a guy on tundra geeks that sells a shift kit to replace the plastic shit with billet. I drive mine like I stole it every day and no issues. Not gonna stop driving it that way either. It's what I do. Hell replace the clutches and these trans can support upwards of 800 hp. I'd hardley call the ab60e and ab60f transmissions glass.
    Torspd and VolcomTacoma like this.
  18. May 25, 2016 at 2:40 PM
    #2098
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Nope. Ab60e and ab60f
    12TRDTacoma[QUOTED] likes this.
  19. May 25, 2016 at 2:41 PM
    #2099
    VolcomTacoma
    Jeff
    NorCal
    The only issues i read about the Tundra Suoerchargers was there was something about the ECU dialing back power if temps were below 50f or something and TRD issued a reflash to correct that.
    12TRDTacoma likes this.
  20. May 25, 2016 at 2:48 PM
    #2100
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Wasn't really meant to be an argument, even though it may had sounded like one. I have been looking myself on there and haven't seen anything. I could had swore I read an article or read a thread where the engines equipped with the blower were blowing through transmissions like crazy if you weren't careful with it. I might had actually been told it by a Toyota tech when I was at the dealer also though. So idk.
    There was supposed to be an old PCM firmware that would reduce power in cold weather under like 55* for the blower Tundra's. The isue got taken care of, but I don't see how it would affect one year in particular.
    I searched like crazy looking for transmission specs on the AB60E and F variant, and came up empty handed. No horsepower, torque ratings, nothing. Which is sort of weird, given this transmission has been on the Tundra's since 07.
    I did see the mention of those accumulators though. Hell I might had even run into that same shift kit you were talking about. Lol.
    I caught that after that last post. :thumbsup:
