TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. May 26, 2016 at 5:18 PM
    #2121
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    Found me a non FFV Tundra and a dealer with a TRD supercharger still in stock so I am hoping the deal works itself out. They just beating me up on my 2016 Tacoma Limited. Thats what happens when you go from a Raptor to a Tacoma. I feel as if i was neutered.
  2. May 26, 2016 at 9:26 PM
    #2122
    ThomasMore66
    Dallas/Fort Worth & Durango
    What?! Who does that?
  3. May 27, 2016 at 10:43 AM
    #2123
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Liking the spec u exhaust alot more now, I had a buddy drive it and outside it sounded really good. I have a video but it wont let me add it
  4. May 27, 2016 at 10:47 AM
    #2124
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    That is the wrong kit. Ours is the M62. I just rebuilt mine and it was about 120$ total. I may have a full rebuild kit up fs soon.
    That doesn't even include the rear bearings either
  5. May 27, 2016 at 10:49 AM
    #2125
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Yeah I noticed yesterday. Thanks
    anthony250f[QUOTED] likes this.
  6. May 27, 2016 at 10:58 AM
    #2126
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    YouTube it. :thumbsup:
    I got an over the phone sound clip, when it was still a prototype. It sounded better than any combo to date. Combined with the Spec- U headers, it sounds like a refined 350Z exhaust, in my opinion.
    JuanitoBonito likes this.
  7. May 27, 2016 at 12:35 PM
    #2127
    GT7
    Grant
    Phoenix
    2013 DCLB
    Torspd and JuanitoBonito like this.
  8. May 27, 2016 at 12:42 PM
    #2128
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Sounds a little.... rice car-like to me
    RogueTRD, Aw9d and GT7[QUOTED] like this.
  9. May 27, 2016 at 12:43 PM
    #2129
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If I were you I would look into ceramic bearings on the rebuild kit before you rebuild it.
  10. May 27, 2016 at 12:48 PM
    #2130
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What are you planning on using for your transmission if you end up going that route?
  11. May 27, 2016 at 12:58 PM
    #2131
    TashcomerTexas
    Thanks for the input. I was reading a lot last night and not many people have opted for those and the price difference doesn't really constitute the price IMO given the steel bearings can last about 100k miles.
  12. May 27, 2016 at 1:02 PM
    #2132
    eon_blue
    Azusa, CA
    Anyone have experience with the URD AFR (air fuel timing calibrator) on the 3.4l supercharger? I'm running a completely stock supercharger setup (no fuel system upgrades) and am getting tired of the occasional pinging I'm getting, especially under high gear/low RPM acceleration.
    I've read that this helps and can also help with it's overall performance, just wondering by how much according to anyone here that's running one?
    Any input would be appreciated thanks!
  13. May 27, 2016 at 1:08 PM
    #2133
    TashcomerTexas
    Apparently there's 4 bearings in the s/c? The 2 in the nose cone, the rotor bearings and supposedly 2 others that I don't see on rolling performance. Would those be vital to replace as well?
    I figure I'll get the nose kit for $75+30 for the coupler+25 for rotor bearings= so for roughly $130
  14. May 27, 2016 at 1:15 PM
    #2134
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't know how much more expensive they are, but if you had the money to splurge I would definitely do it. Of course idk how you feel about splurging on truck mods.
    2 for the nose cone and 2 for the rear drive of the rotors. So yes 4 total. I would replace all bearings while you are in there. The last thing you want to have to do is tear it apart again because the one you didn't replace is crapping out.
  15. May 27, 2016 at 1:19 PM
    #2135
    TashcomerTexas
    Haha yeah I'm definitely not about to drop $175 on a nose kit alone vs $75. So big difference. Edit: $195 vs 75
    My only gripe is this full kit has skf bearings and I'd like to stay Asian with koyos
    http://m.ebay.com/itm/251776486881?_mwBanner=1
    And when you say 2 for the rear drive of the rotors do you mean these?
    http://www.rollingperformance.com/rotorbearings.htm
    Or is it something else cause that eBay kit ^ has 4 and the rotor bearings.
  16. May 27, 2016 at 1:21 PM
    #2136
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Havent looked that far ahead yet, I dont plan on that for at least another decade. Ill pick up another v6 and go all @Torspd on it before then.
    Torspd likes this.
  17. May 27, 2016 at 1:25 PM
    #2137
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Those are the ones good sir! The first set that is. Hell for $200 for a kit I woulddefinitely do it. Fuckkk itttt...!
    Are they really 10k for a crate engine? They have been out for years and years. I don't see why they would be that much.
    For when and if you do, go for a 4L80e trans before a 4L60e... the 60e's are absolute crap.
  18. May 27, 2016 at 1:30 PM
    #2138
    VolcomTacoma
    Jeff
    NorCal
    Like i said, its gonna be 10 years from now, Im sure prices will have changed and things will be different. And Im pretty sure Ill be using a race trans of some sort
  19. May 27, 2016 at 1:36 PM
    #2139
    TashcomerTexas
    Well for $200 it's actually just the nose kit so that wouldn't include the coupler, rear bearings, and rotor bearings and seals. Anyways I'm off all next week so I'm anticipating to spend a butt ton of money.
  20. May 27, 2016 at 2:16 PM
    #2140
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    The new 5.0 L will be a V8 lol. It puts out 400 horse without boost. With... lots of 600 HP rumors floating around.
