TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. May 27, 2016 at 2:17 PM
    #2141
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Hmm. a 5.0 v8 ecoboost? What's the point? Doubt it will get much better MPGs than a big boy v8 at that point.
  2. May 27, 2016 at 2:18 PM
    #2142
    VolcomTacoma
    Jeff
    NorCal
    It's like when Toyota said My truck gets 21mpg Highway :rofl:
    12TRDTacoma likes this.
  3. May 27, 2016 at 2:18 PM
    #2143
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Ok so I found the part # for the two rear bearings, being as picky as I am I'm going with koyo ala rolling performance for the nose kit, the coupler, and rear needle bearings, and the 2 rear bearings looking around $140. Hoping these will come by sometime next week.
  4. May 27, 2016 at 2:19 PM
    #2144
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    So far it's only confirmed in the Raptor. The point is RAPTOR. More seriously though Ford wants a HO V8 option without bringing back the 6.2 L engine or something V10. So they are going with a boosted V8. It sounds like it will be in the Superduty and primium F150 lineup at some point after the Raptor.
  5. May 27, 2016 at 2:20 PM
    #2145
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yeah, Ford isn't going for fuelly numbers with a twin turbo V8 :p.
    It's just an example of an engine that will be available in your 10 year window.
  6. May 27, 2016 at 2:23 PM
    #2146
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Hey guys, long time lurker. Im trying to install a Magnuson charger on my rig. They come with a Bully Dog gt platinum tuner to reflash the ecu yourself. Anybody have experience with these? First one they sent me was shit and the second one freezes about a quarter of the way through the reflash process. Not in a critical spot luckily. Directions for reflash are from Magnuson however they don't respond to emails and are very difficult to get on the phone. Bully Dog has been good about talking me through things and today they tell me that the Magnuson directions are incorrect and give me a different way to start the reflash process. Cant play with the system till the end of the day though when I leave work. Next question is this: Magnuson states to reflash the ecu BEFORE installing the charger, exact opposite of TRD directions. So if I do manage to reflash the ecu tonight, can I drive it AFTER the reflash but BEFORE installing the charger? Im talking about babying it not WOT since I'm on call till Sunday morning and might have to drive 9 miles to work to help with surgeries. After the reflash I think I'm about 5 hours from completing the install. Thanks guys
  7. May 27, 2016 at 2:49 PM
    #2147
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    IIRC, yes you can drive it after doing the reflash but without the S/C. Your AFR will by wicked fat though. Not something you want to leave like that. It'd be better to just leave it alone until you have time to flash it.
    mightytacoman[QUOTED] likes this.
  8. May 27, 2016 at 3:05 PM
    #2148
    mightytacoman
    Kel
    4.5L 1grfe
    if its running "fat"/rich what do I risk hurting on a 9 mile trip max speed of 50mph?
  9. May 27, 2016 at 3:06 PM
    #2149
    VolcomTacoma
    Jeff
    NorCal
    You can go as fast as you want, just keep your rpms below like 2.5k-3k. and keep your foot waaaay out of the pedal. that way you don't run the risk of going to rich or too lean
    mightytacoman likes this.
  10. May 27, 2016 at 3:21 PM
    #2150
    TashcomerTexas
    Lol I just spent an extra $40 on 1-2 day shipping. Fuck me right. Need them for next week for sure.
  11. May 27, 2016 at 4:55 PM
    #2151
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ehh… It's just money, I like performance and getting buck for my bang (see what I did there) lol. So I would still pay the money for some ceramics. Maybe I got a screw loose. Highly likely actually. :D
    My lie detector test DEFINITELY confirmed that was a lie!
  12. May 27, 2016 at 5:05 PM
    #2152
    VolcomTacoma
    Jeff
    NorCal
    I usually get about 18-20 even in my current configuration If I keep it right around 70 and don't try to pass anything. Normal driving, the way I do, i average 13
  13. May 27, 2016 at 5:43 PM
    #2153
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah MPG doesn't improve a whole lot from city to highway. These trucks just chug gas to get going and stay moving is all it is I guess.
  14. May 27, 2016 at 5:56 PM
    #2154
    APG
    APG Member
    2015 Tacoma AC
    Please let me know how this works out. I'm contemplating the same kit. Thanks.
  15. May 27, 2016 at 6:02 PM
    #2155
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    GT7[QUOTED] likes this.
  16. May 27, 2016 at 6:04 PM
    #2156
    mightytacoman
    Kel
    4.5L 1grfe
    With any luck, it'll be up and running by Monday night..I'll keep y'all posted on my thoughts
  17. May 27, 2016 at 7:29 PM
    #2157
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Mine probably gets around 13-14ish....I really don't care.....id rather look cool getting my crappy mileage. :cool:
    12TRDTacoma[QUOTED] likes this.
  18. May 27, 2016 at 8:39 PM
    #2158
    mightytacoman
    Kel
    4.5L 1grfe
    Just tried what bully dog told me to do to get it to work without making any more progress at all also note, this is the second tuner they've sent me that didn't work :(. :pout:
  19. May 27, 2016 at 9:22 PM
    #2159
    APG
    APG Member
    2015 Tacoma AC
    Thanks for the update.
    Could you have elected not to purchase the tuner and just got the flash done at a dealer? Is that an option? How much did the tuner run?
  20. May 27, 2016 at 9:27 PM
    #2160
    mightytacoman
    Kel
    4.5L 1grfe
    I'm not sure if it's an option or not. When bully dog sent me the 2nd non working tuner they took a 350$ deposit until I send the first non working one back. Looks like I just saved on shipping though. Now I can send both the broken piece of sh!ts back at the same time
