TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. May 27, 2016 at 9:29 PM
    #2161
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    And I'm not sure if the Toyota dealer would flash it for a non Toyota charger or not. That might be the route I'm forced to go at this rate
  2. May 27, 2016 at 9:37 PM
    #2162
    APG
    APG Member
    2015 Tacoma AC
    Good luck. I'll keep watching for updates.
  3. May 27, 2016 at 9:42 PM
    #2163
    ThomasMore66
    Dallas/Fort Worth & Durango
    Cruising at a steady 100 mph nets me 10 mpg.
    Sterdog, Torspd, 12TRDTacoma and 2 others like this.
  4. May 29, 2016 at 4:34 PM
    #2164
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Put the 2.85" pulley on today. Can't wait to go drive it in the morning :burnrubber:
    RogueTRD likes this.
  5. May 29, 2016 at 5:41 PM
    #2165
    mightytacoman
    Kel
    4.5L 1grfe
    Finished installed the supercharger today. Toyota was going to reflash it if I could have been done earlier but I'm working in a parking lot with hand tools. Took a few hours longer then I expected. Anyways I'm curious about the 2.85 pulley. I might be going that in a week or so
  6. May 29, 2016 at 5:44 PM
    #2166
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    I advise just skipping the 2.85 pulley and going right to the 2.7.
    VolcomTacoma likes this.
  7. May 29, 2016 at 8:00 PM
    #2167
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Although I dont have the 2.7, I agree with Brian because the 2.85 pulley was pretty unoticable at my elevation 3400 ft
  8. May 29, 2016 at 8:06 PM
    #2168
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    my gauges tell me it is doing something but I seriously doubt people would be able to identify trucks with the 2.85 pulley if they were blindfolded.
    It is an easier pulley to install to that plays into it.
    I don't have any regrets putting it on though. The 2.7 also requires more upgrades
    GT7[QUOTED] likes this.
  9. May 29, 2016 at 8:12 PM
    #2169
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I want to do the 2.85. Hope it won't need a upgraded fuel pump....but probably will and that's fine. The 2.7 as I understand it will or must have upgrades that I won't want to do.
  10. May 29, 2016 at 8:29 PM
    #2170
    ThomasMore66
    Come by my house and help me install the pulley. I'll supply good beer.
  11. May 29, 2016 at 8:32 PM
    #2171
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol....at some point I may be going to visit my sister in San Antonio. When I do, I should swing by if it isn't too far......I like good beer. :cheers:
  12. May 29, 2016 at 8:36 PM
    #2172
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Dude it's SOOO easy. All you need is another set of hands to hold a set of wrenches in place.
  13. May 29, 2016 at 8:58 PM
    #2173
    spithead051
    Patrick
    Fairfax, VA
    Same reason I went with the 2.85, no extra mods required, no snout cutting. Just pull and press.
  14. May 29, 2016 at 9:46 PM
    #2174
    ThomasMore66
    Apparently all my friends suck. Or maybe I'm a bad person. No mechanically inclined friends that are free on a weekend. The all seem to have kid stuff.
    You work in the refinery. I work on the white collar side of that equation. My coworkers mostly have a "guy". Nobody I work with shares this passion.
  15. May 29, 2016 at 9:50 PM
    #2175
    VolcomTacoma
    Jeff
    NorCal
    Literally dont even need anyone mechanically inclined lol. "Here, hold this wrench, RIGHT HERE and don't let it spin", while you install the pulley
  16. May 29, 2016 at 10:14 PM
    #2176
    ThomasMore66
    I have the pulley and the puller. Also need to install my gauges and it seems logical to do that first. They're sitting in my office. And you, little mister, don't get to mock that my projects don't get finished in a timely manner...
  17. May 29, 2016 at 10:36 PM
    #2177
    VolcomTacoma
    Jeff
    NorCal
    I'm not mocking anything! Seriously, if you read the instructions a couple times and just pop the hood and stare at it all for a while, it goes easily. Took us maybe an hour to figure it all out and the longest was getting the pulley off because my pulley puller's arms wouldnt fit and then my dremels battery was dead so we had to keep trying to charge it for a few minutes and then try to trim the arm a hair before it died. So that took like half an hour lol. As long as everyone knows their job during the install it takes all of 2 minutes
  18. May 29, 2016 at 11:45 PM
    #2178
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I don't have a upgraded fuel pump on mine and I'm doing just fine.
    With all the mods I have the lean as I go is 10.8-11.0. If the pump was having a hard time keeping up the AFR would show it by going leaner in the upper rpm's. From the install of the SC to where I'm at now the car has only leaned out about 3/4 of a point.
    JuanitoBonito likes this.
  19. May 30, 2016 at 7:35 AM
    #2179
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    This is good to know. I'm gonna do the 2.85 as soon as I can.
  20. May 30, 2016 at 7:40 AM
    #2180
    VolcomTacoma
    Jeff
    NorCal
    ROFL I keep harassing Gadget @URD on FB about when hes gonna have a UCON for 2015s. Now he just responds with "we need a 2015 volunteer local" Im like, dude send me the UCON and ill datalog everything and livestream whatever you want lol, JUST GIMME
    6xchamps, WOODEX M.E. and GT7 like this.
